My Vortech 2.87 setup & dyno numbers =)
Old Jul 15, 2009 | 06:23 PM
  #121
Chef-J's Avatar
Chef-J
Booooosstt!!
You are getting troubles much as me. Lol
Old Jul 15, 2009 | 06:32 PM
  #122
str8dum1's Avatar
str8dum1
ya like I thought earlier, possibly poor seal install. Apparently it wasnt as easy as you thought
Old Jul 15, 2009 | 07:29 PM
  #123
tylerxfire's Avatar
tylerxfire
Originally Posted by str8dum1
this is belt slip. Only making 5psi is most likely NOT slip. That means he'd be slipping completely at like 4000 rpms. His entire motor would be COVERED in belt dust if that was the case. He didnt put something back together properly, pushed on the valve on his bypass valve, or something else. Need to do a leak test.
thanks man, i figured someone here would have somethin to show...
  #124
tylerxfire's Avatar
tylerxfire
its def. gotta be the blower itself
Old Jul 15, 2009 | 07:46 PM
  #125
binder's Avatar
binder
if it's leaking oil into the air ducts then there has to be air coming in that case that's causing it to blow oil into the ducting. So there is your boost leak, which would be in the compressor. Maybe an oring got pinched putting it back together or something.
Old Jul 15, 2009 | 08:43 PM
  #126
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Originally Posted by ;7553551
if it's leaking into the air ducts then there has to be air coming in that case that's causing it to blow oil into the ducting. So there is your boost leak, which would be in the compressor. Maybe an got pinched putting it back together or something.
There is no oil or anything coming from the case.. I have to check my input shaft seal because there is only oil coming form there... if it was the case or the output shaft seal I would have oil in back of my blower and in top of my hood ( like I had before )
Old Jul 16, 2009 | 06:37 AM
  #127
str8dum1's Avatar
str8dum1
i dunno what seal was leaking when my blower went, but there was only oil in the IC tubes, nowhere else on the motor/blower etc.
either way, boost leak the system when the blower is off.
Old Jul 16, 2009 | 08:00 AM
  #128
Vas@Extended
yes sir. thats the plan
Old Jul 16, 2009 | 09:49 AM
  #129
Vas@Extended
here is the video from yesterday..
looks right about 9 psi
View My Video
Old Jul 16, 2009 | 10:49 AM
  #130
cc1012's Avatar
cc1012
utec logs would be way more helpful.
Old Jul 16, 2009 | 11:00 AM
  #131
Vas@Extended
untill i fix the blower oil issue i cant get any logs =(
Old Jul 16, 2009 | 02:56 PM
  #132
binder's Avatar
binder
why can't you get logs because of a leak? doesn't the utec have a MAP sensor hooked to it?
It sounded like you shifted pretty quick. What rpm was that at? i saw it hit what looked to be 10psi which is about 6k rpms which sounded about right for that video. Then again, it IS a video so i can't really tell the difference between 500rpms from a video.
Old Jul 16, 2009 | 04:19 PM
  #133
Vas@Extended
I can't log because the blower is out of my car, and it's not drivable lol.
At that video I shifted at 6500. It definitely wasn't at 10 at 6000 though =\
Old Jul 16, 2009 | 04:31 PM
  #134
Bahraini350Z's Avatar
Bahraini350Z
I agree here... happened to me and had Vortech fix it under warranty
Old Jul 16, 2009 | 04:42 PM
  #135
tylerxfire's Avatar
tylerxfire
what gear was that starting in?
Old Jul 16, 2009 | 05:41 PM
  #136
Vas@Extended
Low 2nd to end of 3rd
Old Jul 16, 2009 | 06:02 PM
  #137
binder's Avatar
binder
that's a good reason...lol
Old Jul 16, 2009 | 06:11 PM
  #138
str8dum1's Avatar
str8dum1
no warranty work here though as he took the blower apart and did seals himself.
I do all my logs in 3rd gear. start off at 1500 rpms, floor it to redline.
Once you get your blower back in, do that, log it and post back.
Old Jul 16, 2009 | 08:11 PM
  #139
Chef-J's Avatar
Chef-J
Booooosstt!!
I used to start off at 2000rpms, anyway it took me few runs to get a right logs and understand how to use it. .
Old Jul 16, 2009 | 08:32 PM
  #140
Vas@Extended
lol yeah.. if i get a ticket , im blaming the supercharger.. fingers crossed!
