my compression test
Old Jul 15, 2009 | 12:43 PM
SmallTuner's Avatar
SmallTuner
Default my compression test
i tune the car, its not making any power more than 570 to the wheels.
any thing more than 16psi is a waste.
power is dropping from 5500 RPM
i checkd the timing, and the cold lash for the rockers its normal
then, i did a compression test.
it was really reallllllly bad
1 = 95
2 = 91
3 = 91
4 = 85
5 = 91
6 = 91
the engine temperture is normal, but its overheating
the overflow tank is allways full with dirt
ill start all over again and rebuild the engine
im not sure how this is happend, bad luck with my darton sleeves.
N E way, i just like to share with u guys
Old Jul 15, 2009 | 12:46 PM
turbo-crx's Avatar
turbo-crx
sounds like the rings didnt seat properly if this is a freshly built motor.
Old Jul 15, 2009 | 12:51 PM
vthao's Avatar
vthao
Damn, those numbers are really bad. Anyway, good luck on your next build.
Old Jul 15, 2009 | 12:52 PM
SmallTuner's Avatar
SmallTuner
not really.
the short block is built by built z motors.
the engine is overheating, but the sensor is showing normal temperture.
Old Jul 15, 2009 | 12:53 PM
SmallTuner's Avatar
SmallTuner
i hope so
Old Jul 15, 2009 | 02:13 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Fairly consistent numbers though, so the problem is uniform. Describe what you did exactly for your compression test.
Old Jul 15, 2009 | 02:28 PM
SmallTuner's Avatar
SmallTuner
first, i run the car for 6 minz to reach normal temperture.
then
fuel pump fuse is removed, injectors discconected, coils are removed.
throttle is open.
cancking 4 to 6 times.
and thats it. i used a compression test guage.
this is one of the runs, no need to tune more than that its a waste.
Old Jul 15, 2009 | 04:12 PM
tylerxfire's Avatar
tylerxfire
what should the compression be at
Old Jul 15, 2009 | 04:14 PM
JTinFL's Avatar
JTinFL
Do a leakdown. I think your numbers are way too consistent for such low numbers.
Then also do a compression and crank 5 times and then 10 times and see what you get.
Compression with 9 to 1 pistons should be around 150ish on this engine.
Lastly, pull your engine apart if the numbers are bad and check the deck heights on the mating surface to the heads and then on the mating surface on the sleeves and see if there is a difference. Good luck with everything.
Old Jul 15, 2009 | 05:25 PM
westpak's Avatar
westpak
SFZCC
then
throttle is open.
should remove spark plugs as well
Old Jul 15, 2009 | 05:54 PM
str8dum1's Avatar
str8dum1
good luck getting it repaired. Seems like everyone with big turbo kits are having alot of problems lately.
Old Jul 15, 2009 | 06:12 PM
djamps's Avatar
djamps
+1 those numbers are way too close. Try a different gauge, then a leakdown as suggested.
Old Jul 15, 2009 | 06:25 PM
turbo-crx's Avatar
turbo-crx
a leakdown test will tell you exactly your problem.....
its not a headgasket/mating surface issue since all the numbers are uniform.
Old Jul 15, 2009 | 10:53 PM
Dynosty's Avatar
Dynosty
Can you consistently reproduce that dyno chart? If so, I again don't think it is an engine problem - but rather something else (such as tuning etc)
Old Jul 16, 2009 | 04:39 AM
turbo-crx's Avatar
turbo-crx
how does that explain the compression numbers?
Old Jul 16, 2009 | 04:44 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Hal is saying if the dyno can be reproduced consistantly, then they low compression issue could an issue with the gauge being used, or the method
Old Jul 16, 2009 | 04:45 AM
Z1 Performance
Former Sponsor
Quick and easy way to see if its block related. Take a few drops of trans fluid, squirt it in before connecting the gauge, then crank again. If the #'s shoot up, your issue is in the block. If the #'s stay the same, the issue is in the heads
Old Jul 16, 2009 | 05:16 AM
Dynosty's Avatar
Dynosty
It doesn't.. I am curious to know if that motor let go at 5750rpm on that dyno pull causing the drop in power and poor compression numbers (still weird they are so consistent), or if it will consistently draw that same curve producing over 500tq and something strange in high rpm. If it can keep doing the same exact curve it leads me to believe there is something else going on.
Old Jul 16, 2009 | 06:48 AM
JTinFL's Avatar
JTinFL
I watched a guy do a compression test on a car with two different gauges being broken. Then the third one ended up being correct.
Also, some people will argue how many times you are supposed to let the engine turn over during the test, as long as you are consistent across the board then you can find a weak cylinder.
Old Jul 16, 2009 | 07:06 AM
rrmedicx's Avatar
rrmedicx
Did you buy the Long Block or just a short block? Who did the timing of cams?
