Finally, tuned my PROCHARGER..look inside!
Old Oct 2, 2003 | 01:11 PM
keepupp's Avatar
keepupp
Default Finally, tuned my PROCHARGER..look inside!
I just got home from Paul's Automotive in Cincinnati and got a chance to dyno tune my car with the Procharger and Borla Dual exhaust. Needless to say, I was impressed with the numbers....We dynoed in 4th and 5th gear, with 4th yielding the most power....370.8 Horsepower and 299.2 ft/lbs of torque!! The conditions were great, about 60 degrees and low humidity. Our baseline run without tuning the FMU yielded 343 horsepower, meaning an extra 27 HP just from SLIGHT tuning! I have the dyno graph if someone is willing to host I can send through e-mail...thanks!
Dan
Old Oct 2, 2003 | 01:12 PM
Conceyted's Avatar
Conceyted
Default Re: Finally, tuned my PROCHARGER..look inside!
Dan
IMPRESSIVE!
Old Oct 2, 2003 | 01:17 PM
kurt leonce's Avatar
kurt leonce
I"M glad for you Dan, how does it feel
Old Oct 2, 2003 | 01:18 PM
bk_r0x's Avatar
bk_r0x
I wonder if you'd be able to hit over 400rwhp with the rest of the bolt-ons...
Old Oct 2, 2003 | 01:20 PM
keepupp's Avatar
keepupp
Feels like it' ready to run with some lS1's!! I will be taking it to the strip tomorrow night so I will let you know...hopefully it cracks 12's. This is only the beginning though...internals and injectors are next...then it will be time to boost the crap out of the VQ
Old Oct 2, 2003 | 01:23 PM
keepupp's Avatar
keepupp
400 shouldnt be impossible with the other bolt-ons such as :
1. crawford Plenum
2. Cams
3. Headers (sitting in my garage)
4. Grounding Kit
5. Iridium Plugs
6. Larger injectors (they seem to be maxed out looking at the dyno curve...there are spots where it looks like the engine is starved for fuel)
Time will tell.....
Dan
Old Oct 2, 2003 | 01:33 PM
SirMikel1's Avatar
SirMikel1
great power keepupp. I had mine tuned too and yeilded 374.6 with a borla as well on 5th gear
Old Oct 2, 2003 | 01:35 PM
keepupp's Avatar
keepupp
SirMikel, what was your torque?
Old Oct 2, 2003 | 01:41 PM
350Z-RED's Avatar
350Z-RED
awsome dude
Old Oct 2, 2003 | 01:42 PM
SirMikel1's Avatar
SirMikel1
i'm at work right now so i don't remember, but i'll give you my torque as soon as i get home.
Old Oct 2, 2003 | 01:57 PM
narkotic's Avatar
narkotic
Right on, I'll take some torque from you as well if you feel generous!
Old Oct 2, 2003 | 04:29 PM
whosdady's Avatar
whosdady
I assume you have a 5AT? Your numbers are almost identical to mine (368 rwhp and 298 rwtq). I assume you have a 5AT only because autos seem to have a greater varible between hp and tq. I have the stillen exhaust and thats it. I'm ready to put high flow cats, crawford plenum and ecu upgrade as soon as it is an option. 400rwhp should be an easy number to hit. With these upgrades, first night at the track I got a 13.1 with 90 degree temps.
Old Oct 2, 2003 | 04:52 PM
keepupp's Avatar
keepupp
I have the 6MT.
Old Oct 2, 2003 | 06:26 PM
whosdady's Avatar
whosdady
Default Thats strange
I would have expected a smaller variance between your hp and tq with a 6 MT. If you look at others that have posted... You will see guys with 6 MT's that have 345 rwhp and 296 rwtq or 360 rwhp and 299 rwtq. Your rwhp is much higher while your rwtq is average for a 6MT. The lower numbers could be caused by different dynos but the smaller varience?
Old Oct 2, 2003 | 07:02 PM
spazpilot's Avatar
spazpilot
keepupp:
those are some great numbers if you ask me. Hope you are liking it
Old Oct 2, 2003 | 11:15 PM
N4Spd's Avatar
N4Spd
Default af
keepupp,
How did they measure your AF. Did they stick a sniffer up
the tail pipe or did they install a wide band o2 sensor?
Also, what AF ratio did you get throughout the rpm range.
thanks,
rob
ps. congrats on those awesome numbers!
Old Oct 3, 2003 | 12:47 AM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
What does that give you at the crank?
Old Oct 3, 2003 | 04:40 AM
keepupp's Avatar
keepupp
They used a wideband o2....it was at 12:1 most of the way through the rev range. The Aeromotive FMU kinda sucks cuz you cant adjust the fuel enough. It would be nice to adjust every 500 rpm or so. 370 rwhp is about 450-455 at the crank.
Old Oct 3, 2003 | 05:03 AM
Juztin's Avatar
Juztin
Do you guys think the DFMU & SAFC-II would be a good combination? I would think you woul first be able to set the general fuel range with the DFMU, then modify it by +/- 20% in increments of 200rpms. Kinda like to give the the fuel system a little nudge as the boost hits towards the end of each stage where it probably beingins to lean out a bit.
--Justin
Old Oct 3, 2003 | 05:48 AM
Guru's Avatar
Guru
S-AFC II would be perfect to dial everything in perfectly. Fuel presssure is so innacurate even run to run. The S-AF probably wo't net much power up top but shodul be able to smooth things out nicely.
