Installed my Cosworth intake manifold
Sep 15, 2009 | 01:21 PM
Sep 15, 2009 | 02:42 PM
Quote:
Originally Posted by
JAM3Z
May be worth holding out for Charles' new plenum, pending results of course.
While Charles' plenum will be badass, it is geared toward serious, big turbo builds turning very high rpm. It also moves the TB to the front and will require a good bit of custom work to integrate.
Sep 15, 2009 | 02:43 PM
Nealoc187
weak
Shut your dirty whorish mouth
Sep 15, 2009 | 03:56 PM
Ouch, but well deserved!
Sep 15, 2009 | 04:57 PM
thom000001
I think lots of people need to address their ECU, grounding , and spark plugs/gap first.
The cars running the most boost, thus SHOULD have the hardest time igniting that a/f combo are NOT running boost-a-sparks.
My car doesn't fall on its face at all, all the way to 7200rpm (and thats on stock cams/springs)
tom
On my build, I'm considering running a wire from the battery ground to a distribution block under the dash, and grounding the ECU, Haltech, etc. there.
Sep 15, 2009 | 05:20 PM
ttg35fort
Neal works on my car with me frequently....and he thinks he's funny.
Sep 15, 2009 | 06:36 PM
How much more boost you plannin to run with the meth on?
Tom
BriGuyMax
Sep 15, 2009 | 06:53 PM
thom000001
Cars running 30+ psi on here don't have these problems.
and who on here would be running 30+ psi.
Sep 15, 2009 | 07:05 PM
I know I run 30psi on 110gas.
SP runs 38psi to get the 1248rwhp
not sure what Hal is running on the drag car or on his street car.
tom
tig488
Sep 15, 2009 | 08:18 PM
thom000001
Tom
As much as the little T25s will take. Probably around 18lbs. Have been running 14-15 for the last 2 years.
Sep 16, 2009 | 04:51 AM
BriGuyMax
Your retort: weak
Sep 16, 2009 | 05:02 AM
BriGuyMax
Brian change your sig, you neither have spark blow-out nor a busted 3rd gear anymore
Hrmm...I wonder what your excuse is going to be when I pull you 4 football fields on 355 :P
Sep 16, 2009 | 06:44 AM
you're doing a dyno on current boost before upping the boost?...in for comparison.
Sep 16, 2009 | 07:12 AM
TTforT calculated that the T25 can fully flow 25+ psi. dont be a baby!
BriGuyMax
Sep 16, 2009 | 07:16 AM
Turn that shizzle up!!!!!!!!!
tom
BriGuyMax
The APS turbos (GT2860/71 hybrid?) are out of efficiency much past 21 psi.
Sep 16, 2009 | 09:39 AM
Very nice Brian.
Neal...
weak sauce
Sep 16, 2009 | 10:31 AM
marra23
We'll do plenty of comparisons on boost alone (at all different boost levels), then with meth to see how much power we can make. Perhaps test Meth/water mix vs 100% methanol too.
Sep 16, 2009 | 10:43 AM
That settles it, 21psi it is!!!!!
tom
rcdash
Sep 16, 2009 | 11:17 AM
thom000001
tom
brian doesn't have big enough cahones...
