Installed my Cosworth intake manifold
Old Sep 30, 2009 | 12:27 AM
  #81
marra23's Avatar
marra23
Any results yet?
Old Sep 30, 2009 | 05:03 AM
  #82
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by marra23
Any results yet?
Yes, but I forgot my USB thumb drive when we went to the dyno, and the shop is in the process of moving this week, so I didn't want to post anything until I had the dyno files in hand.
But, I did move my peak power up 700rpm and held power all the way to 7000rpm. I'll post the dynos as soon as I get them.
Old Sep 30, 2009 | 08:07 AM
  #83
SH Luciano's Avatar
SH Luciano
brian's car is moving out pretty good...we had a shot last night at a certain G35 sedan that was built not that long ago and it turned out to be pretty close
Old Sep 30, 2009 | 09:31 AM
  #84
MardiGrasMax's Avatar
MardiGrasMax
Nice, got video, please say you did! Dont get me wrong, I beleive you... I just wana see
Old Sep 30, 2009 | 09:35 AM
  #85
Jay'Z's Avatar
Jay'Z
Originally Posted by ADMAN
Made for easy removal as well:
I love easy access!!
Old Sep 30, 2009 | 09:37 AM
  #86
MardiGrasMax
Originally Posted by BriGuyMax
You know I do, my motor would have no problem with more power. I don't think my single walbro has big enough cojones...
Brian, I just read this and you have the bost-a-spark, why not a boost-a-pump? At 70psi a GSS342 is capable of flowing 73gph at 16.5v. Thats enough fuel for over 800chp.
Old Sep 30, 2009 | 09:43 AM
  #87
thom000001's Avatar
thom000001
Brian,
I was suprised how "small" the cosworth looks in person.
For some reason pics of it installed make it look HUGE.
Looks good though.
tom
Old Sep 30, 2009 | 12:05 PM
  #88
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Yes, just have to upload it from the camera.
Old Sep 30, 2009 | 12:15 PM
  #89
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I just figured I'd eventually go with the CJM dual in tank pump. I don't want to have feed issues in the surge canister.
Old Dec 7, 2009 | 03:23 PM
  #90
str8dum1's Avatar
str8dum1
did you ever post up a sheet showing your solid gains with your cosworth?
get those axles in yet?
Old Dec 7, 2009 | 03:52 PM
  #91
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Don't have the sheets. The shop that I dyno'd at moved the next week and it's about a 45 minute drive now. Haven't gotten down there to get them.
Car is put away for the winter, axles will go in @ the same time I do the rest of my little winter projects. This winter couldn't be over fast enough.
How are your axles?
Old Dec 7, 2009 | 04:02 PM
  #92
str8dum1's Avatar
str8dum1
dunno, cars been in the air for over a month. I did install RcDash's yesterday. No clicks etc and everything seems fine. He drove home and txt'd me that they didnt fall off.
Def tell its a small company. His 2 hub convertor plates were machined differently but everything still lined up.
Be interesting to see if anyone else has the driver's side axles fitting very tight when mounting them to the diff. Pass side is cake, but i had to nudge both mine and Raj's with a rubber mallet to slide up the diff stubs
Old Dec 7, 2009 | 09:17 PM
  #93
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Interesting, I'll have to see how mine go...
Old Dec 8, 2009 | 06:53 AM
  #94
rcdash's Avatar
rcdash
Thanks for all your help str8dum1! I'm glad I sought your help. I would've spent all day trying to figure out how to get enough room to fit the axle through the tight quarters on the passenger side. Dropping the spring was brilliant - quick and easy fix. DSS should have put the hub plates on before shipping and just packaged it appropriately. Then they would notice that the holes don't quite line up!
Axles seem to be fine. No unusual noises, vibrations, etc. I'll check the bolts again for tightness this weekend.
Old Dec 8, 2009 | 10:12 AM
  #95
str8dum1's Avatar
str8dum1
^excellent. everything should be solid. doing mine 1st really streamlined getting yours done. those bolts with blue locktight should stay nice and tight.
Old Feb 21, 2010 | 06:15 AM
  #96
GreenGoblin's Avatar
GreenGoblin
Question, I am reinstalling my cosworth manifold, and want to seal it up good. I see that you are using blue loctite, what are you torquing the bolts to? Also you guys are ditching the cos gasket in favor of black rtv?
Old Feb 21, 2010 | 07:16 AM
  #97
rcdash's Avatar
rcdash
Torque to recommended specs - hopefully the loctite will hold it. Use black rtv in addition to the o-ring. Kind of hard not to get a little messy, but try to get a thin application on there without missing any spots. You only need a little because it will squish out the sides if too much...
Old Feb 21, 2010 | 07:46 AM
  #98
xzotklr's Avatar
xzotklr
[QUOTE=BriGuyMax;7745602]Finally finished the install of my Cosworth IM and my alkycontrol meth kit today.
Went out and did some street "tuning" with the UTEC. My AFRs stayed nice and fat. 11.0-11.3 so I didn't have to add any fuel (AFRs before the manifold were mid 10s).
Boost dropped from 14psi on spring pressure to 12.5psi on spring pressure. I'm assuming this is because of the dramatic increase in flow.
Car now feels nice and strong above 5500rpm whereas it fell on it's face BAD after 5500 before. I'll be putting it on the dyno and turn on the meth sometime in the next couple weeks so I will hopefully confirm what my butt is telling me.
So far I'm very happy with the Cosworth. It REALLY cleans up the engine bay and looks dead sexy. Now I can actually see my coil packs so plug changes will be a piece of cake.
What is the circled piece mounted on the bottom of the support bar??? Is that a pump for your oil cooler??
Old Feb 21, 2010 | 08:37 AM
  #99
Zivman's Avatar
Zivman
meth injection
Old Feb 21, 2010 | 09:16 AM
  #100
GreenGoblin
Raj do you know the tq specs, I cant find my install instructions I probally tossed them, I remember it being in/lbs
