Installed my Cosworth intake manifold
Old Sep 16, 2009 | 11:23 AM
  #61
ADMAN's Avatar
ADMAN
Yeah, I was impressed with the one on the Momentum track vehcile:
Made for easy removal as well:
Old Sep 16, 2009 | 11:28 AM
  #62
tig488's Avatar
tig488
Originally Posted by thom000001
I know I run 30psi on 110gas.
SP runs 38psi to get the 1248rwhp
not sure what Hal is running on the drag car or on his street car.
tom
ok, so 2. just checking. the way you put it made it sound like there were lots.
Old Sep 16, 2009 | 12:34 PM
  #63
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by SH Luciano
brian doesn't have big enough cahones...
You know I do, my motor would have no problem with more power. I don't think my single walbro has big enough cojones...
Old Sep 16, 2009 | 12:35 PM
  #64
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by MardiGrasMax
Very nice Brian.
Neal... weak sauce
Hey Matt....how YOU doing?
Old Sep 16, 2009 | 12:45 PM
  #65
thom000001's Avatar
thom000001
The point being though that some seem to have spark blowout or lack of spark issues at 18psi, when there are those running much more that don't have that issue. If it were a common coil pack issue (i.e. the coil packs just don't have enough juice), then at some point everyone would have this problem, but that doesn't seem to be the case.
just my $0.02
tom
Old Sep 16, 2009 | 12:59 PM
  #66
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by str8dum1
TTforT calculated that the T25 can fully flow 25+ psi. dont be a baby!
+1
Don't let all of the work and time spent go to waste (i.e., going through the calculations, realizing something is wrong with the "A/R" value provided, taking actual measurements, and finally pinning Garrett down on what they mean by "A/R") . The T25 flanges will be fine up until the point the inlet area starts to be larger than 1735 sq. mm. Such turbos will be capable of well beyond 30 psi with our engines.
EDIT: Summary: The T25 flanges will in no way be the limiting factor as far as maximum boost goes. The limiting factor will be the capabilities of the turbos themselves. If someone has HUGE turbos with inlets greater than 1735 sq. mm., only then can they blame the inlet size on holding them back.
Old Sep 16, 2009 | 03:30 PM
  #67
SH Luciano's Avatar
SH Luciano
charles was at your house last week, you should have had him drop off a dual pump hanger too :P
Old Sep 16, 2009 | 04:00 PM
  #68
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I little bird told me your plans for your car changed....I'm on to you...
Old Sep 16, 2009 | 04:06 PM
  #69
SH Luciano's Avatar
SH Luciano
how has anything changed? only thing i know of is jeremy's not fab'ing up an extrenal wastegate. he added a spring to the internal gate and is going to route an extra boost feed line so my car can actually make more tha 10lbs. what did you hear?
Old Sep 16, 2009 | 05:08 PM
  #70
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Shooting for a little more power than you said before eh?
Old Sep 16, 2009 | 06:05 PM
  #71
SH Luciano's Avatar
SH Luciano
i don't really have any power goals per se, i just want to turn the boost up a couple lbs...
Old Sep 17, 2009 | 12:08 PM
  #72
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
UPDATE:
Checked the endcap bolts after 3 heat cycles, and all of them were loose. A couple I could turn with my finger. Good thing I didn't get into boost at all the last time I drove the car. Time for some blue loctite.
Old Sep 17, 2009 | 07:16 PM
  #73
SH Luciano's Avatar
SH Luciano
UPDATE:
yikes that's no good - you put the loctite on the bolts yet?
Old Sep 17, 2009 | 08:12 PM
  #74
ttg35fort's Avatar
ttg35fort
Professional
Let us know how the spring works with the internal wastegate.
I have heard the internal wastegates don't work so well. Hopefully the spring will solve the issue.
Old Sep 17, 2009 | 09:23 PM
  #75
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Not yet, I need to go buy some first.
Old Sep 18, 2009 | 06:21 AM
  #76
SH Luciano's Avatar
SH Luciano
I will def. let you guys know what happens...I'll prob. start my own thread so I'm not hijacking Brians.
I got an update yesterday from the guy doing all the installation/fab-work. He put an extra spring in and got the boost to spike to 14lbs and leveled out around 9 where-as before when just running off spring pressure it would not boost past 8lbs.
Originally I was going to have him fab up an EW but after he looked at the internal design he really liked it. I showed him APS' design and he what he didn't like about it was the ability to flow air through the turbo and EW and the piping was smaller. He thinks we should be good to go on building boost.
Old Sep 18, 2009 | 12:22 PM
  #77
Nealoc187's Avatar
Nealoc187
^^ what the hell does that screen name mean? i just sent you a text btw.
Old Sep 18, 2009 | 01:39 PM
  #78
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
He told me it means: "Hi my name is James and I'm a homosexual"
Old Sep 18, 2009 | 02:47 PM
  #79
SH Luciano's Avatar
SH Luciano
lol, it's an old throw-back to when i used to play the original quake fps in highschool.
Old Sep 18, 2009 | 02:48 PM
  #80
SH Luciano's Avatar
SH Luciano
i'm not gay, you sucked my d**** :P
