Another Powerlabs DIY and picture diary
Old Sep 22, 2009 | 05:58 PM
idanielsan's Avatar
idanielsan
Default TurboXS UTEC install
TurboXS with MAP sensor, software
Stock computer with bracket
Computer, bracket, with TurboXS attached
Where I cut the boot to run the MAP sensor
about to install in the dash
I hope this fitment is the same for everybody. It was so tight that I bent back some of the metal under the dash so it wouldnt scrape. The carpet against the firewall is so thick I had to shove it in and risk bending something
Old Sep 22, 2009 | 06:11 PM
bldg250z's Avatar
bldg250z
[/QUOTE]Not sure if I like the sag, but it looks way better than the open spot on the passenger side with no exhaust there[/QUOTE]
try bolting up into the crash bar i used three screws and it gave me a straight line as long as you dont mind drilling into your bumber
Old Sep 22, 2009 | 06:25 PM
0jiggy0's Avatar
0jiggy0
I <3 DIY's
Old Sep 22, 2009 | 06:35 PM
idanielsan's Avatar
idanielsan
Default Fuel Pump
Removing from factory location behind the seat
removing the bracket
This little thing is easy to lose
side by side of the stock (left) and the walbro 255 (right)
Trimmed the white tabs to make the longer fuel pump fit. I didnt have to modify the plastic bracket at all, it actually fit fairly snug
Old Sep 22, 2009 | 07:03 PM
IIQuickSilverII's Avatar
IIQuickSilverII
wow
i heart this thread!
Old Sep 22, 2009 | 07:18 PM
idanielsan's Avatar
idanielsan
Default A/C Lines
Stock lines before, Drivers side
Stock lines before, below windshield
Another view below windshield
Lower AC line vs powerlabs (longer)
Upper line vs powerlab (top)
Upper line with powerlab ac line installed
Lower line from powerlab only seems to fit going under the sway bar. Glad I didnt remove it now, makes it easier to figure out.
top down view of new lines installed on compressor.
Old Sep 22, 2009 | 07:46 PM
idanielsan's Avatar
idanielsan
Default Injector and plug install
Removing the upper plenum (motordyne plenum previously installed)
the plenum spacer is the white border
lower plenum removed
Preparing to remove the injectors from the fuel rail and install the new ones
comparison pic, deatschwerks on bottom
since i was in there, I replaced the injectors with http://www.summitracing.com/parts/NGK-6619/ Heat Range 6, Not easy to come by.
Back 2 cylinders had oil in the plug tunnel. Seems to be a common issue, I havent seen any oil burning. Not planning on changing the valve gaskets yet, hope it lasts a bit longer
Torquing the lower back on, what a tedious chore. 40 INCH lbs, then 80, then 100.
finally back together again after another round of torquing. Have to make sure not to squeeze the oil grommet in between plenums. already made that mistake once
Old Sep 22, 2009 | 07:55 PM
BoostedProbe's Avatar
BoostedProbe
Good to see you doing this yourself. You will see the benifit if something goes wrong down the road (hope it doesn't) , but you never know. It is a proven kit, just a bit too tight for my liking.
Good luch.
Old Sep 22, 2009 | 07:58 PM
idanielsan's Avatar
idanielsan
Default Oil Pan Spacer
Stock oil pan
Oil pan off
Before removing the sealant gunk
about as clean as I could get it
Installed the inside spacer before laying the sealant
I know its prob too much sealant, it was my first attempt. Hard to get a steady bead without a gun
Driver side view installed
Passenger side view installed
Old Sep 22, 2009 | 08:10 PM
idanielsan's Avatar
idanielsan
whew, thats about where I am at for the moment. Thanks for the comments it helps keep me motivated. Future posts will take a bit longer since I have some dental work to be done in the next few days. Also for whatever reason what takes one person 1 hour , it takes me 3. Its taken me weeks to get to this point.
Old Sep 22, 2009 | 08:32 PM
Aced16's Avatar
Aced16
looks great man, keep up the great work, and congrats on the purchase! cant wait to see it up and running
Old Sep 22, 2009 | 09:11 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Awesome picture diary.
Old Sep 23, 2009 | 08:15 AM
tiguy99's Avatar
tiguy99
Congrats! No worries. Take your time and it'll be all right! Your posts keep us motivated
Old Sep 23, 2009 | 12:16 PM
ttuberz's Avatar
ttuberz
what are you doing about the windshield washer? completely taking it off or do you have a replacement that will work with the kit?
Old Sep 27, 2009 | 06:18 AM
citymunky's Avatar
citymunky
Thumbs up
Good Work, and pic's.
Old Sep 27, 2009 | 06:49 AM
binder's Avatar
binder
awsome! it makes me honestly miss the days of doing my vortech install. I hated some things about it, but it was fun.
i'm curious what the washer tank has to do with anything? is it for intercooler fitment?
Old Sep 27, 2009 | 08:45 AM
frankie945's Avatar
frankie945
^^You have to totally remove the windshield washer tank to fit the massive 3 inch intake piping that comes off the intercooler to the intake. And also the radiator overflow tank gets removed and replaced with a smaller one.
Old Sep 29, 2009 | 01:37 PM
  #38
deeznutts23's Avatar
deeznutts23
Nice writeup so far! I can't wait to put this on my G35!
Old Sep 29, 2009 | 02:57 PM
  #39
350Z400rwhp's Avatar
350Z400rwhp
Did you do the mod to the siphon valve and regulator when you installed the Walboro 255?
Old Sep 30, 2009 | 04:47 AM
  #40
idanielsan's Avatar
idanielsan
Do you mean drill holes in the side of the "bucket" ?
Yes, but I forgot to take pictures of it
or are you referring to the Swirl Jet mod?
I didnt drill out valve with a bit. The powerlab instructions dont mention it.
If I have fuel pressure probs I may have to go back and update it.
These instructions?
http://cj-motorsports.com/342install.htm
