20g potential
Old Apr 23, 2010 | 09:23 AM
  #301
str8dum1's Avatar
str8dum1
well remember that the 20g's have the same hot side as gt3076s and the cold side of a about a GT3071.
You are definitely not being limited by the hot side with a true 20g!
Old Apr 23, 2010 | 11:50 AM
  #302
TwoFiveBar's Avatar
TwoFiveBar
Originally Posted by thom000001
Interesting to see where the 20G's run out of breath...
Tom
Originally Posted by TwoFiveBar
SPE's GT-R put down 866awhp/849awtq with the TD06SH20Gs.
2 Bar, C16.
9.6@150mph w/ Drag Radials
However, I am not sure if they are using the standard hot side (IIRC 8cm^2) or one of the larger options GReddy offers.
I'd imagine this is approaching if not past the limit of the compressor. I've seen GT28 series Garretts hold boost and never lose power on the same platform all the way to 7500rpm at 27psi (about 750/750). So from the looks of it, that's about it for those 20gs. But again, it hard to tell without being there during the testing, looking at the boost curve, data etc. Remember, this graph is from an awd vehicle with (iirc) stock heads/cams. No doubt the car is fast as hell though. LOL, even with 18s and drag radials, 9.6 in pretty much street trim is ridiculous.
Old Apr 23, 2010 | 06:41 PM
  #303
meatbag's Avatar
meatbag
Originally Posted by rcdash
meatbag, where is your battery and what is in its place in that compartment?
Nice piping and catch can setup!
(I don't see check valve preventing boost from going backwards through the catch can - just use stock PCV I presume? So you're catch can sees 18 psi etc?)
The battery is in the trunk and the bulk of the fuel system is in that compartment now. I use the stock check valve but im seeing its limits and need to put one inline before the catch can and just drill out the stock one.
Old Apr 23, 2010 | 07:55 PM
  #304
eltness350's Avatar
eltness350
The Untouchable
Holy crap nice - how much boost was that? Tell me that was done in the winter in ATL! If it was during hot weather, you can easily add 15% to compare to Dynojet STD. In cold weather with no correction on Sharif's DD dyno, the readings are more comparable depending on how cold...
it was done in high 60's low 70's weather so idk?
it was 18-19psi and yea sharif was pretty pumped when he texted me the numbers! i have bc stage 2cams/ little bit of polish and porting along with ferrea 1mm oversized valvetrain to help her breathe a bit
Old Apr 26, 2010 | 11:51 AM
  #305
350zzzgunnar's Avatar
350zzzgunnar
Hey I'm in a big hurry for 20G's, but Im unsure if the bolt right up to my 18's exhaust manifold and AAM 3"DP's. Do anyone know if and what I need to rebuild to make them fit? Are gaskets the same?
Old Apr 26, 2010 | 02:11 PM
  #306
rrmedicx's Avatar
rrmedicx
Mine were upgraded from 18 to 20 G's and they bolt right up no problem. No worries. If done properly, the gaskets to the DP may need to be opened up slightly but that's it.
Old Apr 26, 2010 | 03:24 PM
  #307
meatbag's Avatar
meatbag
I hope some other people could run on a dynojet to see what the numbers are.
Old Apr 26, 2010 | 03:38 PM
  #308
IslandZavage's Avatar
IslandZavage
have u guys who upgraded from 18 to 20g's try to see if you could swap/buy the whole turbo out for a true 20g instead of modifying your 18g to a 20g?
Old Apr 26, 2010 | 04:56 PM
  #309
meatbag's Avatar
meatbag
Its cheaper to have them upgraded then to buy new turbos from greddy.
What I want to know is if the TD06-25G with the 16cm back housing will fit with the greddy manifolds. Its the same 3-bolt pattern but does it clear everything else.
Old Apr 27, 2010 | 12:32 AM
  #310
350zzzgunnar
Thanx
I had my 18G's upgraded but they really ****ed up Short story; they destryed them, not possibel to rebild.
So I just ordered genuine 20G's. GReddy said that I need TD06 flanges and TD06 gaskets so I went for those too.
Enine is in engine dyno and will be tuned aprox in 2 weeks.
Old Apr 27, 2010 | 03:14 AM
  #311
IslandZavage
Thanx
what placed F'ed up your rebuild? where did u get/order the genuine 20g's from? cost? I sent an email to Greddy but their response had absolutley nothing to do with what i asked them..
Old Apr 27, 2010 | 11:56 AM
  #312
350zzzgunnar
The shop that F'ed up said that they is going to make it up for me so at this time I prefer to give them a chance, but I'm not convinced that they'll do it...
I deal w/ Concept Z Performance, newer F'ck up. Price is $1650 / turbo.
Old May 15, 2010 | 02:01 PM
  #313
midz350's Avatar
midz350
A friend of mine just made 620whp with twin 25G's on 16 PSI (I think its 4.2L) on pure 95 RON (90-91 AKI) and his car has some ECU problems that's some times retard timing.
will try to get more info and dyno sheet later this week.
Old May 15, 2010 | 02:04 PM
  #314
midz350's Avatar
midz350
Oh.. and his tuner told him to fix his car and bring some C16 and he will be in the 800-900whp no sweats.
Old May 15, 2010 | 04:19 PM
  #315
binder's Avatar
binder
lol, depending his supporting mods.
i don't think he'll get there this week if his ecu is pulling timing. he's either knocking or having other issues that might require a standalone ecu. So either knock or bad ecu.
Most tuners won't push a vehicle to that hp if they are having issues getting the timing stable. Too risky on their pocketbook.
Old May 15, 2010 | 04:55 PM
  #316
midz350's Avatar
midz350
I think he has stg 3-4 heads (maybe the cosworth) and custom 30? dur set of cams.
He is running the HKS F-CON V PRO but the problem is that he is running a DE engine with RevUp ECU and flash (he swapped his transmission from AT to MT)
Old May 15, 2010 | 05:29 PM
  #317
binder's Avatar
binder
well i thought the vpro was full standalone so it should be doing the timing.
and it's defintely a no no to run a rev up ecu with a de motor. why would he do that? a manual swap shouldn't mean change the ecu from a non-rev to a rev ecu. he should have put a manual non-rev ecu in there.
Old May 17, 2010 | 01:13 AM
  #318
Super G35's Avatar
Super G35
Old May 17, 2010 | 01:24 AM
  #319
Super G35's Avatar
Super G35
Dear Midz,
make sure when you quote other car modifications and horsepower is real because the information that you post is not accurate; by the way I will post my new project results soon.
Thanks
Old May 17, 2010 | 04:09 AM
  #320
Alberto's Avatar
Alberto
Cranky FI Owner
LOL
