20g potential
Old May 17, 2010 | 05:23 AM
  #321
nyqueenz's Avatar
nyqueenz
Just completed my 20g build car put down..
384whp 340lb tq on waist gate presser for break-in @8psi
522whp 466lb tq @ 15 psi.
Way more room for higher numbers but fuel was becoming an issues with my single MB pump. If I upgrade to twin pumps and bigger injectors I could see in the 700 range.
Old May 17, 2010 | 05:38 AM
  #322
IslandZavage's Avatar
IslandZavage
originals or 18g's upgraded to 20's?
Old May 17, 2010 | 05:53 AM
  #323
nyqueenz's Avatar
nyqueenz
org 20g kit for the VQ DEs
BTW i will be down in Miami this Aug so look for me..
Old May 17, 2010 | 06:25 AM
  #324
midz350's Avatar
midz350
Originally Posted by Super G35
Dear Midz,
make sure when you quote other car modifications and horsepower is real because the information that you post is not accurate; by the way I will post my new project results soon.
Thanks
That's why I used:
Originally Posted by midz350
I think
maybe
and I'm really sorry if that's upset you
Old May 17, 2010 | 06:28 AM
  #325
Alberto's Avatar
Alberto
Cranky FI Owner
Why not do the proper fuel to support the greater potential the 20G's offer?
Do you plan on doing that? What cams do you run?
Im not dissing you because you arent the only one but I have yet to see a legit 20G setup - fuel, cams, EMS, that has shown this community reason to actually want them over 18G's.
All I ever see is 18G like numbers and "hopes" of 700-800whp later.
Old May 17, 2010 | 06:42 AM
  #326
nyqueenz's Avatar
nyqueenz
I have a stage 2 fuel set up.. all I need is to run another pump nothin too hard to put together. No cams. I choose not to run cams because I wasn't sure of what my HP goals where and shop told me that I should be fine with the Headwork I had done and also with the Cosswoth Pleumen. I know now that I was gonna pay for it later but O well let me have some fun break-in times with her before I open her up again for some extreme shyt. I could do cams later but not in any rush now. let's see what I can do without them 1st.
Old May 17, 2010 | 07:07 AM
  #327
str8dum1's Avatar
str8dum1
for the power levels that basically everyone runs with the greddy's (mid 500s), the 18g are a much better option. Problem is you need to drop a lot more money into the 18g kit up front. You need the 3" downpipes and wastegate relocation kit. Thats very pricey.
At that point, you can get a brand new 20g kit with the bigger IC and updated pipes for the same price. And then its all back to "hopes" of 700-800hp later over better power curves now.
Old May 17, 2010 | 07:58 AM
  #328
nyqueenz's Avatar
nyqueenz
The thing wit me is... and the reason why i went with the 20g ova da 18g.. 1) Its brand new kit at the time it came out, 2) I got the kit dam near "at cost" of what you would pay for an 18g.. Cant beat that.
Old May 17, 2010 | 01:17 PM
  #329
meatbag's Avatar
meatbag
Can someone spec the inducer and exducer of the compressor and turbine wheels on the 20g's that they have had upgraded? Not people that bought 20g units from greddy.
Old May 17, 2010 | 01:40 PM
  #330
str8dum1's Avatar
str8dum1
umm read the 1st post
Old May 17, 2010 | 02:00 PM
  #331
eZg's Avatar
eZg
I have read a few posts that mention the need for the wastegate relocation kit witht he 18g kit. Is the reason boost creep? Lowering the turbulence of exhaust gases? what exactly?
Thanks
Old May 17, 2010 | 02:08 PM
  #332
IslandZavage
Thanks
good info brought to you by SEARCHING : https://my350z.com/forum/forced-indu...ions-done.html
  #333
meatbag's Avatar
meatbag
Edited. Meant to say to the people that have had their turbos upgraded.
Old May 17, 2010 | 02:52 PM
  #334
binder's Avatar
binder
you have a cjm stage 2 fuel setup with what injectors?
odd that you think are running out of fuel at 540hp when cass put down 100hp more with a single walbro.
so ya, what size injectors and what duty cycle? something's amuck
Old May 17, 2010 | 02:54 PM
  #335
Barnabas's Avatar
Barnabas
National Z Club President
cass is running dual walbro's
lance has a single 255 with DW 600 injector
Old May 17, 2010 | 02:55 PM
  #336
binder's Avatar
binder
Originally Posted by Barnabas
cass is running a dual walbro
didn't he dyno high before he went dual setup?
i could have swore there was someone here that dynoed around 600hp with a single setup on a large return system.
Old May 17, 2010 | 03:03 PM
  #337
Barnabas's Avatar
Barnabas
Im sure with some modification and running larger injectors/larger lines it could be possible but its smarter to run a dual pump setup.
Old May 17, 2010 | 04:05 PM
  #338
str8dum1's Avatar
str8dum1
cass only had 1 pump and meth and hit 630 on the DD. A single walbro and 800cc injectors should get you over 600 on a DJ depending on fuel pressure, timing and obviously AFR
Old May 17, 2010 | 04:22 PM
  #339
binder's Avatar
binder
ya, maybe i'll just throw an inline 044 on there. I have an inline walbro but i'm not sure how much it would actually help. I guess it couldn't do any harm
Old May 17, 2010 | 04:26 PM
  #340
Barnabas's Avatar
Barnabas
Good luck!!!!!
