Another Powerlab Build on stage 2 motor
Old Dec 2, 2009 | 03:48 PM
  #81
binder's Avatar
binder
so you have an hpx maf?
since it didn't work i'll take it off your hands. PM me and i can paypal you some cash for it!
Old Dec 2, 2009 | 05:26 PM
  #82
qqqqball's Avatar
qqqqball
As you all know the stock ecu runs off voltage from the maf. the way the hpx works it is has 2.5x the cap of stock to measure air using the same voltage.. What happened was that the dyno held the motor alive with the centrifugal force of the dyno behind it. Car was decreased in timing to source problem and tuner was demanding a 90% load in fuel to make it idle at 14.7 A/F. It only peaked 31.6 psi with an air fuel of 22.3 ( i know i know. a car wouldnt even run with this.. and it didn't) before the alarms went off on dyno, accessport and all was shut down. I did however get a free compression/ leak down test which showed the engine to be fine. the only thing that blew was the breather tube that connects the valve covers. . The only reason an accessport was to be used was that being a street/track car it needs to pass emission, in which the "guaranteed to pass" doesn't work, and it needs the stock computer to pass. a utec which keeps the obd2 compliancy still trips the code and car fails instantly, piggyback biased system receive the same treatment. Osiris is the only other option as of this time. Most probable cause for high boost under such conditions was fuel burning outside of cylinders reason for this assumptions was the fire it was shooting out. It looked like someone with one of those flame thrower kits for cars with distributor caps.
Old Dec 2, 2009 | 05:28 PM
  #83
qqqqball's Avatar
qqqqball
might need it I i don't move the car registration to another state
Old Dec 2, 2009 | 05:35 PM
  #84
str8dum1's Avatar
str8dum1
whoever told you running a UTEC or any other EMS will fail inspection is as dumb as running 31psi (which i still think there is no way you did)
Old Dec 2, 2009 | 05:56 PM
  #85
GBoger's Avatar
GBoger
yeah I ran utec with no codes (most of the time anyway). Inspection was a little bit of a fickle process but in the end it wasn't a big deal considering the amount of money i put into actually FI'ing the car...
Old Dec 2, 2009 | 05:59 PM
  #86
binder's Avatar
binder
ya, ss box used on vortech systems and stillen systems still complies with CARB I didn't/don't have check engine lights with my car. I got a code when i went to test pipes but the non-fouler fixed that then i had a loose wire which gave me a misfire. Both had nothing to do with the engine management.
Old Dec 3, 2009 | 03:40 PM
  #87
SlideFox's Avatar
SlideFox
+1 on the EMS... You can go UTEC, Haltech, ProEFI (All are more suited for your application) and not have any problems!! If your going to Injected.... Get a Haltech!!
Old Dec 3, 2009 | 07:25 PM
  #88
GBoger's Avatar
GBoger
have you considered changing your sig lately? They're already talking about firing Wade
Old Dec 3, 2009 | 08:05 PM
  #89
SlideFox's Avatar
SlideFox
Dude, don't go down that road (You will lose), and please don't clutter up this thread.
Old Dec 4, 2009 | 09:43 AM
  #90
Chef-J's Avatar
Chef-J
Booooosstt!!
+1 !!!
Old Dec 4, 2009 | 12:10 PM
  #91
GBoger's Avatar
GBoger
I will lose? or do you mean the cowboys will lose?
Old Dec 14, 2009 | 12:35 PM
  #92
GBoger's Avatar
GBoger
Did I lose yet?
Old Dec 14, 2009 | 12:38 PM
  #93
str8dum1's Avatar
str8dum1
^ha
any dyno updates, or is this build a fail as well?
Old Dec 15, 2009 | 11:59 AM
  #94
frankie945's Avatar
frankie945
In for updates as well.... What happened to this guy?
Old Dec 15, 2009 | 01:39 PM
  #95
GBoger's Avatar
GBoger
the shorter gears in first and second got the best of him
Old Dec 29, 2009 | 06:55 AM
  #96
doug's Avatar
doug
O'RLY? i passed with and FCon
Old Dec 29, 2009 | 06:59 AM
  #97
doug's Avatar
doug
Originally Posted by str8dum1
^ha
in October he said they made 571@ 17 PSI https://my350z.com/forum/7865947-post85.html .. i'm curious too because he lives in the city i grew up and went to high school
Old Mar 28, 2010 | 09:01 PM
  #98
Mr_pharmD's Avatar
Mr_pharmD
wheres the dyno sheet????
Old Mar 29, 2010 | 03:26 AM
  #99
SH Luciano's Avatar
SH Luciano
Originally Posted by Nealoc187
LOLOLOLOL @ T56 internals in an MRA70... you might as well have claimed to replace your VQ with a pair of solid rocket boosters from the space shuttle...
i'm still laughing at this neal...classic.
Old Mar 29, 2010 | 09:25 AM
  #100
kramerbuccs24's Avatar
kramerbuccs24
This thread is RETARDED lol
