Another Powerlab Build on stage 2 motor
Old Mar 29, 2010 | 11:15 AM
  #101
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by qqqqball
As you all know the stock ecu runs off voltage from the maf. the way the hpx works it is has 2.5x the cap of stock to measure air using the same voltage.. What happened was that the dyno held the motor alive with the centrifugal force of the dyno behind it. Car was decreased in timing to source problem and tuner was demanding a 90% load in fuel to make it idle at 14.7 A/F. It only peaked 31.6 psi with an air fuel of 22.3 ( i know i know. a car wouldnt even run with this.. and it didn't) before the alarms went off on dyno, accessport and all was shut down. I did however get a free compression/ leak down test which showed the engine to be fine. the only thing that blew was the breather tube that connects the valve covers. . The only reason an accessport was to be used was that being a street/track car it needs to pass emission, in which the "guaranteed to pass" doesn't work, and it needs the stock computer to pass. a utec which keeps the obd2 compliancy still trips the code and car fails instantly, piggyback biased system receive the same treatment. Osiris is the only other option as of this time. Most probable cause for high boost under such conditions was fuel burning outside of cylinders reason for this assumptions was the fire it was shooting out. It looked like someone with one of those flame thrower kits for cars with distributor caps.
Just noticed this. I passed OBD emissions testing in IL once with my original Unichip and twice with my TurboXS UTEC. So, you are wrong, the UTEC and other piggybacks will NOT instantly make the car fail an OBD emissions test.
Old Mar 29, 2010 | 03:02 PM
  #102
superchargedg's Avatar
superchargedg
Damn Noobs
What a giant FAIL.
Old Mar 29, 2010 | 03:16 PM
  #103
hydroflip's Avatar
hydroflip
lol
Old Mar 29, 2010 | 09:52 PM
  #104
QuicksilverZ33's Avatar
QuicksilverZ33
He's been online...but no response to this thread...sucks, cause I wanted to see the results of a high boost powerlab setup
Old Mar 30, 2010 | 04:34 AM
  #105
jeffie7's Avatar
jeffie7
Building the 350Z trans is fail. When I needed a better trans I just swapped the 7 speed from a wrecked Benz into the z, sure its an automatic but the 7 gears are so close together it makes up for it. I love having a super close ratio trans!
Anytime I start feeling sporty I just kick the auto trans in manual mode and own the streets like no other. Albertos got nothing on my auto in manual mode shifting skills.
Old Mar 30, 2010 | 03:17 PM
  #106
superchargedg
Damn Noobs
Jeff we all want some of the drugs you have.
Old Mar 30, 2010 | 03:52 PM
  #107
Barnabas's Avatar
Barnabas
National Z Club President
where do you come up with this stuff jeff
Old Mar 30, 2010 | 04:00 PM
  #108
jeffie7's Avatar
jeffie7
Have you ever had sex with a Viet woman? it will blow your mind man!
Or just try working with Tina that will fry it also but not in the good way the yellow tacos do it.
Old Mar 30, 2010 | 04:11 PM
  #109
Barnabas's Avatar
Barnabas
Old Mar 30, 2010 | 04:29 PM
  #110
0jiggy0's Avatar
0jiggy0
Wow, never read this thread before. Nothing even makes sense. My head hurts.
Old Mar 30, 2010 | 09:09 PM
  #111
Elperuano's Avatar
Elperuano
ROFL!!!! WHAT DA FUDGE?!?!!?!?!?!
There's some creative thinkin for ya a$$!
Old Mar 31, 2010 | 05:22 AM
  #112
jeffie7's Avatar
jeffie7
What can I say, yellow is my drug of choice!
Old Mar 31, 2010 | 06:42 AM
  #113
str8dum1's Avatar
str8dum1
wait, so there was no 7 speed benz trans swap. This thread really fails.
LOL
350Z_Al
Oct 29, 2020 07:44 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
