Another Powerlab Build on stage 2 motor
Old Nov 23, 2009 | 04:01 PM
qqqqball's Avatar
qqqqball
Default Another Powerlab Build on stage 2 motor
Another powerlab thread i know.... but when doing the kit I noticed that besides Jeffie and Idanielson doing the build on a relatively stock block there has been little to no publication or threads on a build block one other than Intensepower's
This is a dairy of the build, not only to help those DIYers but to start that which their is none of.
Before the build started it dyno with kinetix V+ full exhaust with test pipes at a whopping 214RWHP
When they say long block they mean just the block a little shocking when looking at it all together
Old Nov 23, 2009 | 04:07 PM
qqqqball's Avatar
qqqqball
Default Starting the pull
Pulling the engine is rather straight forward drop tranny, crane engine out
the engine bay looks really big when there isn't one in there no wonder people choose to put a small block chevy motor into here... but thats no way to be respected in the Z category
Old Nov 23, 2009 | 04:11 PM
qqqqball's Avatar
qqqqball
Taking a break from getting complacent on the motor we mock up the intercooler and big koyo radiator
I had to put up the cut for the crash bar for all of those who read the directions referring to a template( non existent)
Old Nov 23, 2009 | 04:16 PM
qqqqball's Avatar
qqqqball
engine back in we start the putting the turbo in... tried to do it outside the car and drop it in but that was hopeless... unless you pull the entire front of car off and slide engine with tranny attached in.
If you want more information on the install of the pipes see jeffie's or idanielson's as it has been beaten to death.
Old Nov 23, 2009 | 04:22 PM
qqqqball's Avatar
qqqqball
Default To the exhaust
Having invested money into getting exhaust geared to a twin system a single down pipe put us at odds with ourselves, they talk of a reverse y pipe, but pictures are sparse at best.
Attachment 267238
Old Nov 23, 2009 | 04:27 PM
qqqqball's Avatar
qqqqball
Started the car for the first time today and to say that the single downpipe into a dual sounds anything but interesting would be a travesty. It does seem to have the best of both worlds of the nissian and the sti.. it has an z tone at idle but with a little more of a lobe to it thanks to the c2 cams, but at speed it sounds like a sti on roids.
More pictures of the completed project to come once it stops raining
Numbers to come Dyno appointment on 30nov should have 1k miles on it by then ..
Old Nov 23, 2009 | 04:31 PM
Vas_Z33's Avatar
Vas_Z33
you should post some bigger pix!
Where in danbury CT?? Iam so close! i deff wanna check this out when its done.
Old Nov 23, 2009 | 05:08 PM
ImWeeZzel's Avatar
ImWeeZzel
+1 for bigger pics, cant wait to see end results...
Old Nov 23, 2009 | 05:14 PM
qqqqball's Avatar
qqqqball
Right over the NY boarder exit 2 on 84
i've got my old air cooling guide if you want it
cars done just putting miles on it
Damn Mac won't let me post bigger pics, when the suns out i will use my other camera that actually has windows drivers
Old Nov 23, 2009 | 06:03 PM
IIQuickSilverII's Avatar
IIQuickSilverII
facking awsome man! if u can do video to hear exhaust time.....it will sound awsome with turbo spooling I bet
Old Nov 23, 2009 | 06:09 PM
Vas_Z33's Avatar
Vas_Z33
no ****!!! I hang around there all the time.. iam 15 min from it.. whens all done or w/e we should get coffe at bux on exit 2
yeah deff!
Old Nov 23, 2009 | 06:29 PM
IIQuickSilverII
lol .....vas putting on the moves!
Old Nov 23, 2009 | 08:50 PM
SlideFox's Avatar
SlideFox
Sick!! +1 for bigger pics
In for the numbers!!
Old Nov 24, 2009 | 01:30 AM
marra23's Avatar
marra23
Biuld block, what boost you're planing on? and besides the kit what other mods....more detail plz.
In for the results
Good luck
Old Nov 24, 2009 | 06:20 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
In for dyno results! We have a customer in the shop currently awaiting a built longblock with Powerlab GT35R and I'm excited to see the outcome.
Old Nov 24, 2009 | 07:53 AM
Vas_Z33's Avatar
Vas_Z33
Lolol i just got a new HD camera n i wanna try it out! What better place to record!.. A powerlab kit on a build motor!. I got the same setup coming in spring so
Old Nov 24, 2009 | 09:14 AM
escobar929's Avatar
escobar929
very cool
Old Nov 24, 2009 | 12:19 PM
qqqqball's Avatar
qqqqball
-------------engine---------
Wiseco Pistons .020 over
Eagle H Beam Rods
ARP Rod Bolts
Moly coated Race Spec main bearings
Moly coated Race Spec rod bearings
Ported exhaust and intake runners
JWT C2 Cams
JWT Heavy Duty Valve Springs
koyo radiator
powerlab plenum spacer
AAM Stage 1 Fuel return
---Engine dress up------
red coolant hoses
rdz custom bolt kit
polished plenum
JDM harness cover
air cooling guide
Home made red grounding cables
---------Turbo-------------
single Powerlab turbo
tial q bov
custom Y-pipe to Bassani true duel
----Drive train--------------
rps light weight segmented flywheel
rps clutch
LSD (carbonetics)
nismo adjustable short throw shifter
Built 06 manual tranny
braided steel clutch line
-------Suspension--------
stance gr+ coilovers
hotchkis sway bars
cusco front camber arms
kenetix rear toe/camber arms
greddy strut tower brace
stillen brake booster
stainless steel brake lines
-------exterior------
seibon hood
carbon creations c1 front bumper
all around tints 15%
custom CF nismo style spoiler
custom tsw 18's time attacks 9.5 front 11 rear on nitto invos
blacked out tail lights and turn signals
CF rear Diffusor
sparco hood pins
s2k antenna
------interior-----
all gauges made blue led
blue defi boost/egt
blue a/f wideband innovative products
Jvc kw-710
blitz boost controller
Old Nov 24, 2009 | 12:21 PM
qqqqball's Avatar
qqqqball
In for the results
Good luck
17 psi.. if no problems 20
Old Nov 24, 2009 | 12:23 PM
qqqqball's Avatar
qqqqball
will definitely post result eta Tuesday the 1st of December
