my 2011 and Beyond! build thread.
Old Apr 26, 2011 | 02:28 PM
  #201
SQBassHead's Avatar
SQBassHead
Nice!!!
Old Apr 28, 2011 | 11:13 AM
  #202
dikspiel's Avatar
dikspiel
Chestons Toilet
Just wanted to give an update:
-All piping is installed
-Fuel Rails Installed
-Injectors Installed
-Fuel Pump installed
-Spark Plugs installed
-Currently installing 60mm DEFI gauges
Up next is the haltech bits, oil cooler, oil catch can, and then they begin tuning. =)
Old Apr 28, 2011 | 12:03 PM
  #203
suprasam's Avatar
suprasam
Looks great! Your engine looks so clean and the cosworth is sick. I'm getting one on my next round!!
Old Apr 28, 2011 | 12:17 PM
  #204
dikspiel's Avatar
dikspiel
Chestons Toilet
Nice!
No matter how much planning you do there always going to be little pieces you have to order.
I ordered my turbo kit without the TiAL BOV so I can save a few bucks (I already had the synapse) and the piping came with the 50mm flange that works with the TiAL but not the synapse. Vibrant makes an adapter to fit the Synapse which I ordered for overnight delivery just to find out I failed to realize I was also going to need the TiAL V-Band Clamp and O-Ring for their 50mm bov. Had to just order those parts for next day delivery. There goes my savings :P
Old Apr 28, 2011 | 12:56 PM
  #205
themadhatterxxx's Avatar
themadhatterxxx
^^ Make sure they remove the bubble wrap from the intercooler before they turn anything on.
Old Apr 28, 2011 | 01:25 PM
  #206
SQBassHead's Avatar
SQBassHead
Old Apr 29, 2011 | 12:20 PM
  #207
suprasam's Avatar
suprasam
Originally Posted by dikspiel
Nice!
I hear you. It can be an endless money pit as things add up or something new comes out. I had a pretty good build the first time, now I want more boost and some stronger parts for tracking.
Old Apr 30, 2011 | 04:29 PM
  #208
dikspiel's Avatar
dikspiel
Chestons Toilet
random pictures of the install
Old Apr 30, 2011 | 08:58 PM
  #209
suprasam's Avatar
suprasam
good progress!! gotta love it when a plan comes together!!
Old Apr 30, 2011 | 09:10 PM
  #210
dikspiel's Avatar
dikspiel
Chestons Toilet
gimme ur motor!
Old May 1, 2011 | 11:35 AM
  #211
suprasam's Avatar
suprasam
^^^U need one? ha ha.
She's been good to me so far, so I plan on driving this one to the very end!
Old May 2, 2011 | 06:01 PM
  #212
dikspiel's Avatar
dikspiel
Chestons Toilet
Car is alive as of today. Shop says they will need a day to tune and a day to double check everything so most likely to picking up Thursday. Shop is having trouble finding a t-adapter locally to mount the DEFI water sensor in the upper radiator tube. Hopefully pepboys has something.
Old May 2, 2011 | 07:10 PM
  #213
dikspiel's Avatar
dikspiel
Chestons Toilet
Crom is telling me to install the DEFI water temp sensor at the stock location.
Anyone have any info on doing it this way instead of doing it to the upper radiator pipe?
22630 is where the stock coolant sensor is installed
Old May 2, 2011 | 07:18 PM
  #214
suprasam's Avatar
suprasam
i've seen some setups that place a pipe with a threaded opening in the middle of the upper radiator hose coming from the radiator that you can screw a sensor into. Or perhaps you could tap into the factory wiring, if you could calibrate the gauge to read the stock signals.
Old May 2, 2011 | 07:34 PM
  #215
dikspiel's Avatar
dikspiel
Chestons Toilet
I'd rather not tap into the factory wiring, I don't see the point of having the gauge unless its using its own independent sensor.
Old May 2, 2011 | 07:42 PM
  #216
suprasam's Avatar
suprasam
i gotcha, just throwing it out there. could you have a bung welded on the front brass portion of the upper radiator pipe? right after the front hose?
Old May 3, 2011 | 06:57 AM
  #217
str8dum1's Avatar
str8dum1
very common
http://www.glowshiftdirect.com/Water-Hose-Adapters.aspx
Old May 3, 2011 | 08:47 AM
  #218
dikspiel's Avatar
dikspiel
Chestons Toilet
Originally Posted by str8dum1
Yea thanks I found something similar but nothing local.
Old May 3, 2011 | 02:09 PM
  #219
Vas_Z33's Avatar
Vas_Z33
very nice!! its coming along! itll be fun!! be safe
Old May 3, 2011 | 03:18 PM
  #220
dikspiel's Avatar
dikspiel
Chestons Toilet
Thanks looks like we are starting to wrap things up. I plan to pick up the car on Thursday if things go smoothly. I'll post dyno etc.. as soon as its done.
