my 2011 and Beyond! build thread.
Old Feb 12, 2013 | 10:46 AM
  #921
jerryd87's Avatar
jerryd87
If leak down is fine then shouldn't be piston rings. Is it just on first fire up or all the time? Would think it sounds like valve seals.
Originally Posted by dikspiel
leak down is fine
Old Feb 12, 2013 | 10:51 AM
  #922
dikspiel's Avatar
dikspiel
Chestons Toilet
All the time. GearHeinz replaced the valve seals while the engine was still in the car few weeks ago. Still smokes. Maybe the valve guides?
Old Feb 12, 2013 | 11:52 AM
  #923
Crom's Avatar
Crom
Engine pull ? Yikes...
Old Feb 12, 2013 | 12:05 PM
  #924
jerryd87's Avatar
jerryd87
Potentially, caddy northstars have this issue too much slop letting oil seep in, gona be a pain though to determine.
Old Feb 12, 2013 | 12:32 PM
  #925
Resmarted's Avatar
Resmarted
*****. Keep us updated with the diagnosis.
Old Feb 12, 2013 | 01:11 PM
  #926
350z006's Avatar
350z006
How does it manifest its oil consumption? Just lower oil levels? Excessive smoke out of tailpipe during startup?
Old Feb 12, 2013 | 01:53 PM
  #927
dikspiel's Avatar
dikspiel
Chestons Toilet
Ya large smoke cloud when the car is on
Old Feb 12, 2013 | 07:22 PM
  #928
350z006's Avatar
350z006
When you said oil was coming out of piston 2 and 4, what did you mean? And what did Howard recommend?
Old Feb 13, 2013 | 05:12 AM
  #929
djamps's Avatar
djamps
Turbo seals maybe?? You didn't say how the oil was 'leaking' from the cylinders, maybe it was just the valve cover seals letting oil in around the plugs and not the actual issue. I find it hard to believe compression and leakdown is fine if there's a serious oil leak into the combustion chamber.
Old Feb 13, 2013 | 09:40 AM
  #930
dikspiel's Avatar
dikspiel
Chestons Toilet
It is definitely coming from the motor and not the turbo.
I'm not sure on the specifics of where he found the oil but he is removing piston #2 and #4 this week to check the piston rings. If they look ok we are probably going to take apart the heads.
Old Feb 17, 2013 | 05:26 PM
  #931
Ruthless18x's Avatar
Ruthless18x
Does your car ever not have a problem?
Sux though.
Old Feb 20, 2013 | 03:46 PM
  #932
dikspiel's Avatar
dikspiel
Chestons Toilet
Shortblock was torn down and the issue is being resolved by Technosquare. I don't want to say anything further for the time being.
Old Feb 22, 2013 | 06:43 PM
  #933
Chebosto's Avatar
Chebosto
meanwhile...
when you gotta go--you gotta go!
Old Feb 22, 2013 | 06:50 PM
  #934
2k6-z33's Avatar
2k6-z33
Old Feb 23, 2013 | 11:54 AM
  #935
BoomerZ33's Avatar
BoomerZ33
cheston
good luck with the repair Dik
Old Feb 25, 2013 | 04:44 AM
  #936
VQpwr03z's Avatar
VQpwr03z
Originally Posted by Chebosto
meanwhile...
this is priceless
Old Feb 25, 2013 | 12:00 PM
  #937
dikspiel's Avatar
dikspiel
Chestons Toilet
Can't find a Cosworth 96mm headgasket anywhere, lead time from cosworth is 4 weeks. Any suggestions what I do instead? I am thinking just OEM HR headgasket since my engine has the mod already.
Old Feb 25, 2013 | 12:09 PM
  #938
350z006's Avatar
350z006
How about other brands like HKS or Cometic? Also out of stock?
BTW, if you're interested I do have 1 passenger side Cosworth 96mm HR Headgasket, but only for the passenger side...
Old Feb 25, 2013 | 12:19 PM
  #939
dikspiel's Avatar
dikspiel
Chestons Toilet
i dont think HKS makes a HR headgasket, I'd rather use the oem then the cometic. Tomei makes a 96.7mm but thats too big.
Old Feb 25, 2013 | 01:00 PM
  #940
ace32x's Avatar
ace32x
You blew up to late I just sold my 96mm cosworth hr head gasket to Davejackson on here a little bit ago
