And so it begins...Finaly!
Old Jan 11, 2010 | 06:47 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
....and so it begins
Good luck with your project, I'm sure you will invent new curse words along the way.
Old Jan 11, 2010 | 10:12 PM
CAB350z's Avatar
CAB350z
So new injectors, quite alot bigger then stock, i didnt realize the difference.
New injectors hooked up with stock fuel rail
So while I may be decent at performing mechanical services, I fail hard at anything electronic. This is confusing the **** out of me, I would like suggestions on how to hook up the new plugs to the injectors
Old Jan 12, 2010 | 07:40 AM
350z006's Avatar
350z006
You look like you have RC injectors, just like mine...since you're not electrically inclined I would suggest buying their denso adapters so you can just plug it in and not have to solder it in...
http://www.rceng.com/Denso-Clip-Connector-P48C9.aspx
You may be able to buy these adapters cheaper at other places...
Old Jan 12, 2010 | 07:56 AM
BoostedProbe's Avatar
BoostedProbe
If you want, send them to me in Edmonton. I will solder it all up for you. No charge, you just pay the shipping. I did this for a living and went to school for it, so I am good at it.
Old Jan 13, 2010 | 10:24 PM
CAB350z's Avatar
CAB350z
My roomate can solder but he is very ill and very busy all the time, so if that is starting to be something i need done super fast i will send it to you sasha. Ive seen your build thread, so i beyond trust your work... probly would have gotten your kit if i didnt get the sfr one.
But update: No pictures today will take pictures when i make real progress. However I have started the process of taking off the drivers side header + Cat... so much rust... and i am starting to wish that i had pulled the engine. There is one screw on the header that just makes me want to
Old Jan 14, 2010 | 05:59 AM
str8dum1's Avatar
str8dum1
wow, if you are having problems there, have fun with the rest.
You are also going to need a really long 8mm hex on a socket to tighten the 4th bolt on the turbos to the headers. may even wanna try studding the header and using nuts.
pulling the motor just makes putting the headers on properly easier. the challenge is when everything is back in the back and getting the turbos and charge pipes aligned and bolted
Old Feb 3, 2010 | 11:44 AM
CAB350z's Avatar
CAB350z
Sorry for the delay with updates. I got my *** handed to me by school,work and the girlfriend so i haven't had a lot of time to work on my car. I don't know how many people are still following this however... I can spare maybe 2-3 hours a week to work on it so progress is slow... but tonight I am hooking up the passenger side Headers+ turbo and if i have time the Dump as well. Ill post pictures
Old Feb 3, 2010 | 01:09 PM
Goo$e's Avatar
Goo$e
The only threads I like...are ones with pictures.
Old Feb 3, 2010 | 01:41 PM
str8dum1's Avatar
str8dum1
few more hints in nor particular order....
make sure you install the dump tube before you put up the turbo.
You'll have to figure out a way to get to the 4th bolt connecting the turbo to the header. YOu might want to try using bolts instead of the allen heads.
make sure you have your oils lines on also before mounting the turbo and in such orientation that they dont hit the housing when the turbos are up.
I would also take that silver metal piece off the motor mounts for more room.
Have you tried shoving that flex hose for the passenger turbo on yet? Make sure you can get that on. You'll want to have that already on the turbo before you mount it.
Cutting that silicon hose for the driver's side intake will also take a good bit of time as well. start too long and work your way down. You will probably have to grind an 'ear' off the upper oil pan to make enough room to fit the clamp on there.
its easier to work if you take that black metal tube brace off the bottom of the car. Chances are you'll have to grind that as well if your turbos are clocked in a particular way.
make sure to leave that bolts on the turbos loose when you mount them. YOu'll have to move the CHRA to be able to get to that 4th bolt.
oh, make sure you are 100% sure thats the clutch you want, as you basically have to take everythinig off to remove the tranny.
Old Feb 3, 2010 | 08:18 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Post the pictures tonight, i am stuck at work and bored out of my mind
Old Feb 4, 2010 | 09:44 AM
CAB350z's Avatar
CAB350z
Sorry nothing got posted last night, the internet went out. So I really don't know how SFR got all of this to fit in. Couldn't get the header to go in with the wastegate on... so had to put in the header with out the waste gate then reassemble it. Once that happened the header its self wont go onto the headers screws, so i had to take those out pull up the header and put them in, i have it on for the most part but it seems to be caught on something...
Oh and the instructions that come with the turbo have a few pictures and are not that detailed ahah. My cosworth plenums instructions are more detailed.
Old Feb 4, 2010 | 10:59 AM
str8dum1's Avatar
str8dum1
remember, thats still the easy stuff. make sur eyou test fit tha tflex hose onto the turbo. That will really f' you if you cant get it on after the turbos are mounted
Old Feb 4, 2010 | 11:06 AM
Boosted Performance's Avatar
Boosted Performance
Sounds like a real PITA...glad I don't have to do it.
Not sure why the are still using the old school wastegates. Just comparing the two:
I use the one on the right, very easy to lighn things up because there are no bolts.
Old Feb 4, 2010 | 11:33 AM
CAB350z's Avatar
CAB350z
They are the ones that came with the kit unfortunately ahah. Sasha where were you when i wanted to buy a kit! i would have taken the week off to go to Edmonton and have you build my car for me lol
Old Feb 4, 2010 | 11:37 AM
Boosted Performance
Hey, I offered...
A week? 6 hours of work and I would have had you ready for dyno.
Old Feb 4, 2010 | 11:45 AM
CAB350z's Avatar
CAB350z
Lol it was after i bought my kit though ahah, 6 hours?
Old Feb 4, 2010 | 11:48 AM
Boosted Performance
Yup, that is all it would take. 8 hours at most, keep in mind that I don't have to look at the instructions... Just pass me the wrenches..
Old Feb 4, 2010 | 12:03 PM
  #38
CAB350z's Avatar
CAB350z
I Haven't looked much at the SFR instructions...They have words missing,typos and words spelled wrong all over the place and they are missing steps and certain instructions.
Wanna install my turbo for me
Old Feb 4, 2010 | 12:05 PM
  #39
rcdash's Avatar
rcdash
You guys are nuts for doing this on your own in the middle of the winter... I can see blood in the pics above! Props though and good luck!
Old Feb 4, 2010 | 12:10 PM
  #40
CAB350z's Avatar
CAB350z
Its just me and that was from having to take gloves off to fit my hand in certain places
