EGT guage vs Oil Temp guage
Old Jan 28, 2010 | 07:22 AM
Synjn's Avatar
Synjn
Default EGT guage vs Oil Temp guage
I looked a little, couldnt find a thread on this. Don't flame me.
I want another guage to monitor my engine. I have an aem a/f and boost guage. I'm new to FI, and I dont particuly like how random the A/f reading is. At wot i'm at a steady 11.5, yes, but it flutuates so much. I take my foot off the throttle and it may jump to 16 for a sec then level off at 14.5 or so. I feel like can't rely on it.
Would it be a bad idea to take out the a/f guage and replace it with a egt and oil temp?
What i'd really like is a cylinder head temp guage to monitor "cold shock" to the top end. Any thoughts?
Old Jan 28, 2010 | 07:58 AM
Darkstreets's Avatar
Darkstreets
EGT will give you a HINT as to what your a/f ratio might be. **Higher then average** gas temperature could mean a Lean ratio and vice versa.
By a/f gauge tell me you mean Wideband..... because actual a/f gauges arent precise worth ****. Aem has been know to have wideband sensors AND gauge goes bad (Aem UEGO). If its possible try and swap it out for one you know works well and see if that changes anything. But a wideband is a must to monitor your A/f at all times.
** there edited...
Old Jan 28, 2010 | 08:21 AM
Synjn's Avatar
Synjn
http://www.avweb.com/news/maint/egt_..._198791-1.html
Old Jan 28, 2010 | 08:46 AM
FineWine's Avatar
FineWine
If you want to add a EGT, by all means... but I would not replace the AFR with an EGT. My AFRs will be in my cubby, so I'll only be actively monitoring them during spirited driving. I'll be adding an EGT ans swapping it into my pillar pod, so I can see quickly if it spikes.
Old Jan 28, 2010 | 09:42 AM
thom000001's Avatar
thom000001
This has been addressed in some other threads
Downfall to EGT gauges is there is no good benchmark for what is safe vs not safe.
Placement of the gauge means everything.....if you have the exact same setup as someone else, and have the gauge in 1inch different position in the collector vs that other setup, that could be a huge temp difference (like 300degrees)....
EGT would be ideal if you had one in each runner!!!!!!!!
Don't get me wrong, I'm not saying its a bad gauge to have, its just a hard one to judge against others.
Tom
Old Jan 28, 2010 | 09:49 AM
str8dum1's Avatar
str8dum1
i think oil pressure is the next most important, followed by fuel pressure. LIke Thom said, placement is key, so the only safeguard you'd have would be your own historical knowledge
Old Jan 28, 2010 | 09:54 AM
captj3's Avatar
captj3
It is not abnormal for your afr to fluctuate. It is normal for your gauge to go lean when you release your gas pedal. Pretty much the way you are describing how the gauge reacts is normal, whether you are boosted or not. As for the aem gauge or the sensor being bad I have had mine for 4 yrs and it is still dead on when I have the car on the dyno.
Old Jan 28, 2010 | 11:20 AM
jonnylaw's Avatar
jonnylaw
yes, afr is supposed to go lean when releasing the throttle.
But, I am experiencing something different. When releasing the throttle, my AFR runs to ~9.8-10, before going lean. dunno?
Old Jan 28, 2010 | 11:31 AM
FineWine's Avatar
FineWine
I don't see anything wrong with that. You're suddenly closing the throttle, which means there's going to be a shortage of air, and management hasn't adjusted yet. MAP/MAF's resolution isn't the speed of light.
What EMS are you using?
Old Jan 28, 2010 | 11:35 AM
FineWine's Avatar
FineWine
(And, I believe TPS is only used to _add_ fuel when the throttle is opened quickly)
Old Jan 28, 2010 | 12:11 PM
jonnylaw's Avatar
jonnylaw
f-con vpro, also have a uprev reflash
Old Jan 28, 2010 | 12:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
your AFR gauge is working exactly as it should - it reads things in real time, so the data will constantly change as your throttle inputs change
that is the most important gauge you have - I wouldn't replace it
oil temp is nice to have if you're tracking the car, or it's driven during very warm outside temps
I find EGT useless on a street car with a wideband in place - before widebands became so affordable, they were somewhat useful in that it could be used to correlate data with a datalogger. I think they have lost their practical use given the affordability of the widebands though
Old Jan 28, 2010 | 12:56 PM
rcdash's Avatar
rcdash
What? LOL. It fluctuates because of your foot! Welcome to the world of FI! It's a great learning experience for many of us.
Seriously, now that I have stopped chuckling (sorry), as others have said, the AFR is most important, then oil pressure. Either one out of whack (in the appropriate context) and the motor is finished.
I miss not putting in an EGT gauge, but only because I've gotten into tuning and I'd like to be able to confirm how the combustion cycle is altered when changes are made to the tune...
Old Jan 28, 2010 | 01:16 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Get the oil temp and call it a day
Old Jan 28, 2010 | 08:22 PM
Darkstreets
I have to agree with oil press being a must have for any built/FI engine. ive gone through 2 AEM UEGO gauges, wasnt a wiring issue just bad gauges. Might have just been a bad batch cause its the most popular wideband Gauge ordered round here! and ive only seen a few including mine go bad. but then again i've had my share of badluck with other electronics.... such as the Apex'i AVCR boost controller... injector pinout fried upon startup installed following very precisely the diagram given by Apex'i for my specific application
Old Jan 28, 2010 | 09:09 PM
boosted99gst's Avatar
boosted99gst
This is the truth! back in my DSM days (on a budget) i used to street tune my s-afc based on my EGT temps and other variables. Considering affordable widebands are all over the market now-a-days, EGT gauges have lost thier worth. As stated earlier, having an EGT probe on each runner is ideal, but does anyone know which cyl. runs the hottest on the VQ? I remember on the 4G63, the #1 runner burned hottest and I used that as my failsafe, anyone care to offer factual insight to those who may find this thread on a search?
Old Jan 28, 2010 | 10:29 PM
Synjn's Avatar
Synjn
I'm runnin the stock ecu with GTM reflash and tune.
apex locator
Jul 23, 2021 02:27 AM
SharX59
Sep 27, 2015 09:23 AM
