Clutch Recomendations on build
Old Feb 6, 2010 | 06:07 PM
bldg250z's Avatar
bldg250z
Default Clutch Recomendations on build
im getting ready to upgrade my clutch from the stage 1 jwt setup.... i plan to keep the jwt flywheel and just replace the plate.
What clutch are you guys using , my plan is to try to make 500 plus rwhp.... i was already planing to buy the fidanza 4.3 clutch which i believe holds 700+ torque.... any suggestions i know twin disk is always recomended but trying to get the close to stock clutch feel
thanks for your input
Old Feb 6, 2010 | 06:09 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
A twin disc is going to give you more of a stock feel than a heavy single.
Old Feb 6, 2010 | 07:08 PM
bldg250z's Avatar
bldg250z
what brand do you think is a good bang for buck?
Old Feb 6, 2010 | 07:40 PM
captj3's Avatar
captj3
Have you looked into JWT's other clutch disc? I believe it is rated to 700ft lbs of torque. Plus it has the same feel as a stock clutch for a fraction of a twin disc.
Old Feb 6, 2010 | 08:37 PM
bldg250z's Avatar
bldg250z
no i hadnt seen this i will look into it!
Old Feb 7, 2010 | 10:50 AM
eltness350's Avatar
eltness350
The Untouchable
spec twin disc would be great for that setup....close to stock pedal feel and will hold gobs of powa
Old Feb 7, 2010 | 01:08 PM
binder's Avatar
binder
For a single setup stay away from Comp Clutch. I had their stage 4 single and it was really heavy. I switched to an OS giken twin disk and it's lighter than the comp clutch stage 4. *talking about clutch pedal feel*
I don't have a recommendation for a single disk. I only have my "un" recommendation for you. lol
*cough* twindisk *cough*
Old Feb 7, 2010 | 10:25 PM
wannabuy350z's Avatar
wannabuy350z
try stage 5 F series southbend. if your looking best bang for your buck
Old Feb 8, 2010 | 11:54 AM
thom000001's Avatar
thom000001
DXD Southbend will hold more power and be cheaper than anything else in the range. If you are going for 650+rwtq they do have a new version but it will be less driveable.
My Stage 5 full face held 700+rwtq on highboost, and 600rwtq daily for 10K miles....not bad for a $500 clutch.
Tom
Old Feb 8, 2010 | 01:21 PM
captj3's Avatar
captj3
Call them if if you don't see it on there website. I have it and it holds great so far @460 ftlbs.
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
