question about bov placement
Old Feb 27, 2010 | 06:18 AM
t6378tp1's Avatar
t6378tp1
Default question about bov placement
I am building a custom turbo kit and the maf will be post turbo. I was wondering if it really matters if the bov is before or after the intercooler. I have a buddy with a honda and his in mounted directly on the intercooler
Old Feb 27, 2010 | 06:56 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
IMO, it really doesn't matter.
Old Feb 27, 2010 | 07:57 AM
suprasam's Avatar
suprasam
wouldn't you need two if you put them before the intercooler on a twin snails setup? e.g. one for each pipe between the turbo and I/C...
Old Feb 27, 2010 | 08:00 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
only if you have 2 throttle bodies
Old Feb 27, 2010 | 08:50 AM
str8dum1's Avatar
str8dum1
mines on the IC as well
Old Feb 27, 2010 | 12:23 PM
t6378tp1's Avatar
t6378tp1
guess I'll put it between the intercooler and tb, I was told the closer it is to the turbo the louder it will be and I want to keep the noise down.
thanks for the input guys
Old Feb 28, 2010 | 08:41 PM
phunk's Avatar
phunk
CJ Motorsports
from dynos tons of cars and noticing how hot the air is that blows out of the BOVs... i originally put mine before the intercooler... figuring there must be some negligible gain in efficiency by blowing off hot air rather than air already passed through the intercooler.
that said, this time around im going to be running much higher boost. so I will be putting them closer to the throttle body for faster response... i dont want to be one of the unfortunate souls to have a throttle shaft snap, running plate screws thru the engine (havent seen it with the VQ yet, probably because very few VQs run high boost)... but in other communities, while rare, it does happen.
there is a big *** pressure surge at the throttle plate when you close throttle under boost, combined with immediate vacuum in the intake manifold... creating a rather powerful pressure differential that can snap a throttle shaft on large or poor designed throttles.
Old Feb 28, 2010 | 08:48 PM
Spork's Avatar
Spork
Try recirc?
Depravity
Oct 1, 2015 04:49 PM
