Need suggestions on an oil cooler
Old Mar 9, 2010 | 02:44 PM
themadhatterxxx's Avatar
themadhatterxxx
Wow thats hot..I have the Stillen one, my temps never even got up to 200 in the summer..but your average temp during the summer is probably higher than mine
Old Mar 9, 2010 | 08:15 PM
xzotklr's Avatar
xzotklr
Originally Posted by Nexx
debating Stillen or GTM. I'm open for all suggestions. oil temps during the summer hit 240F just driving around town in 100F heat.
Both of these kits source other manufacturers parts. The most important piece is the cooler itself. Mocal & Setrab are two of the best brands of oil coolers; meanwhile AeroQuip braided hose is an original & one of the best.
My advice is to put together your own kit.
I would suggest:
Mocal oil sandwich adapter
Setrab/Mocal oil cooler - 19 row (minimum)
AeroQuip stainless steel braided hose- will need two pieces (6ft min)
AN fittings
Mocal oil pump(only really required if you are using +10ft of SS braided hose)
Old Mar 10, 2010 | 01:52 AM
maXmood's Avatar
maXmood
Under Boost!
ok, dumb question probably, but how can i tell if i can fit any of those kits on my SC setup?
got the koyo rad 36mm, and B&M trans oil cooler with an SC-trim (dunno how big is the intercooler that comes with the sc kit).
any ideas?
Old Mar 10, 2010 | 05:29 AM
Zazz93's Avatar
Zazz93
Alot of these kits you can mount anywhere that gets a decent ariflow. I've seen some save space and mount in front of or directly behind radiators and intercoolers. There should be somewhere to mount it.
Old Mar 10, 2010 | 05:51 AM
JasonZ-YA's Avatar
JasonZ-YA
subscribed...
Old Mar 10, 2010 | 05:54 AM
str8dum1's Avatar
str8dum1
any ideas?
you will still have your bumper brace, so you can mount it to that. you could run a 30row and still be fine
Old Mar 10, 2010 | 06:26 AM
Vas_Z33's Avatar
Vas_Z33
Whats wrong with the mishmoto one? Looks like it comes with everyhing according to their site.. I have a few of their parts and there good quality pieces. Not expensive
Old Mar 10, 2010 | 06:43 AM
Zazz93's Avatar
Zazz93
I have the Mishimoto kit and would suggest people to steer away from it until it gets updated. I and a few others have had a problem with a whine. I recieved great service from the guy at Mishimoto who propmtly sent me another kit free of charge but the same thing occured. I then heard a rumor that they were creating a new kit with updated pieces. When I called they said there may be one coming but it was not available at that time. So I ended up ordering new lines/fittings and a Mocal thermo adpater (what I believe is the biggest culprit in the kit) and reassembled. Now, the Mishimoto cooler core is attached to the other components and they work great. But I could have done this a little more cost effectively if I started out piecing it together.
Old Mar 10, 2010 | 06:46 AM
0jiggy0's Avatar
0jiggy0
What is the part number of the mocal t-stat adapter that would be needed?
Old Mar 10, 2010 | 07:17 AM
Zazz93's Avatar
Zazz93
If I remember correctly its this 20 mm part,
http://www.racerpartswholesale.com/p...Sandwich_Plate
Additionally, I do recommend the Mocal Adaptor fittings, they do make it a no brain affair when assembling the pieces leak free.
Old Mar 10, 2010 | 07:47 AM
0jiggy0's Avatar
0jiggy0
I think im going to build one in the next month or so, anytime I find out I can DIY something like this I just have to jump on it... lol.
Old Mar 10, 2010 | 07:55 AM
Zazz93's Avatar
Zazz93
Good luck, sounds like you're doing the homework and that should make sure it goes together well.
Old Mar 10, 2010 | 08:08 AM
BornSlippyZ's Avatar
BornSlippyZ
+1 on doing this DIY. Aeroquip is great for hoses but pretty expensive. I would use Stainless braided hydraulic hose with the PTFE inner lining (you can buy at most hyd hose shops). Use crimp fittings instead of re-usable fittings. (Big price difference)
Old Mar 10, 2010 | 08:23 AM
- bigc -'s Avatar
- bigc -
Originally Posted by str8dum1
i think people are crazy to shell out that kinda money for a oil cooler.
All GTM has done is package OTS products, mark them up again, and resell. Thats an excellent business plan and it has seemed to work superbly! You can get all those components from Jegs/Summit for cheap and make your own -AN lines from ebay.
Heck even this would work perfectly http://cgi.ebay.com/ebaymotors/ws/eB...m=370288418608
you may just want to swap to a thermostatic sandwich plate.
Better yet, send me 550$ and I'll make you a oil cooler kit
I would suggest:
AN fittings
+++1 for what these guys said. I put together my own kit with an Earl's cooler for far less than those pre-made kits. Its really not hard - just basic plumbing and attaching the cooler to the bumper brace.
Cheston's thread was a big help to me when I put together my kit:
https://my350z.com/forum/forced-indu...56k-pwn3d.html
Old Mar 10, 2010 | 09:53 AM
Mr350Z's Avatar
Mr350Z
I bought the B-Line oil cooler kit about a year ago for my JWT 350ZTT race car and have had zero problems. They have 2 sizes, both are priced the same at $375. I have the 25 row cooler and it keeps track day oil temps to about 250-260 in hot southern CA.
http://www.blinemotorsports.com/oilcool.html
Old Mar 10, 2010 | 10:47 AM
JasonZ-YA's Avatar
JasonZ-YA
Okay here my advice on it:
I have been *tasked to do oil coolers before and have done some home work on them:
1. Mount on the passenger side of the car for shortest run possible in lines...would stay at about 4-5 foot per line. not in front of rad/intercooler, etc...
2. Keep the oil cooler no lower than the level of the oil filter sandwich.
3. would get an oil cooler and angled lines to where the fittings are on top! -Not on bottom - don't want to hit something on the road or on course that would accidentally break a line off the cooler. oil out everywhere instantly!
4. Nexx is in Texas, he doesn't need a thermostatic oil sandwich adapter...
5. SS lines and quality fittings. Many good suggestion on this thread!
6. minimum AN10 size fittings.
7. Setrab/Mocal oil cooler - 19 row (minimum) - I agree
8. Would purchase a sandwich adapter with a port (usually 1/4 NPT) so that i you can get the added protection of an oil "pressure gauge".
If your on the highway or on a course and run off track, hit a cone, etc and damage your oil cooler and all your oil is dumped then you can have an oil pressure gauge "beeping and flashing" telling you that your out of oil......
Sure thats a rare event - but the addition of lines and fittings means more points of failure........oil pressure gauge on the sandwich adapter tells you pressure right then and there "IF" Nexx's high dollar motor is out of oil.....
small line of protection..........
See the added port on these sandwich adapters:
-J
Old Mar 10, 2010 | 11:26 AM
Nexx's Avatar
Nexx
if i remember correctly i already have some sort of sandwich adapter, not sure exactly what for possibly the oil temp gauge? i gotta take a look at that today.
Old Mar 10, 2010 | 11:34 AM
  #38
JasonZ-YA's Avatar
JasonZ-YA
cool then you most likely have a free port you can use, just gotta verify what size it is so you can add an oil pressure gauge..
-J
Old Mar 10, 2010 | 12:01 PM
  #39
- bigc -'s Avatar
- bigc -
^ the advice you posted above is spot on. i'd still recommend he get a thermostatic sandwich plate, however. it gets very cold in dallas from late november through february.
Old Mar 10, 2010 | 12:05 PM
  #40
0jiggy0's Avatar
0jiggy0
But does he drive the car then or is he driving his g37?
