Powerlab GT35R 8lbs
Old Jul 15, 2010 | 07:54 PM
  #81
Elperuano's Avatar
Elperuano
Thanks guys Still boosting strong over 3k miles now
Old Jul 16, 2010 | 05:30 AM
  #82
Slick 6MT's Avatar
Slick 6MT
Any videos yet?
BTW: How are those blue lugs holding up?
Old Jul 16, 2010 | 05:41 AM
  #83
Vas_Z33's Avatar
Vas_Z33
thats awesome! good stuff! =)
Old Jul 16, 2010 | 08:25 AM
  #84
Elperuano's Avatar
Elperuano
I'll try to upload a vid I got on da camera.
Blue lugs holding up nicely. No problems there lol
Old Jul 16, 2010 | 06:16 PM
  #85
ffwturboZ's Avatar
ffwturboZ
Hey guys, just picked up a turbo heat blanket and some titanium heat wrap. Im concerned about high heat intake temp since the turbo is so close to the intake pipe. Im hoping to get better power with the cooler temps. Has anyone done this?
Sorry for the thread jack..
Old Jul 16, 2010 | 06:52 PM
  #86
Elperuano's Avatar
Elperuano
no prob. I was thinking of doin the same wit my set up but I had it installed soon as I got it. Honestly I haven't seen my temp gauge go up but I'm sure wit da blanket would be lower. Let me know how it goes.
Old Jul 17, 2010 | 10:38 PM
  #87
Elperuano's Avatar
Elperuano
Quick question, didnt wanna start a thread so im hoping maybe someone can chime in...
My car sat without being turned on for lil more than a week n upon start-up i thought i heard some "clank" kinda noise which went away after a bit.... Also i park my car wit the e-brake so it made lotta noise to when i disengaged it. Went out n hit full boost as always n everythin was perfect... had some spirited driving n everythin was fine never had any problems... Also been noticing upon cold start-up i'll let the engine warm up n go and the first boost run i do i'll be able to see very light smoke come out the exhaust but then after that it's all good... only smokes a lil on first boost run of a cold start-up..
So guess my question is should I make it more of a habit to not let my ride sit for a few days without at least turning it on n warming it up? Also i got plans to install catch can real soon so im sure that will get rid of the lil smoke i get on the first boost run on a cold start-up.
Old Jul 18, 2010 | 06:36 AM
  #88
binder's Avatar
binder
a little oil is going to get past the seals when it sitting. That is one of the reasons and the other is since you don't have a catch can you're getting oil in your intake. Normally it's all over the walls of the plenum when you run it but when it sits it pools in the bottom of the plenum. When you fire it up it will suck that in and it's enough to make it smoke.
When you install a catch can you'll need to take your plenum off and clean it really good in order to start fresh and have no oil in your intake. It will also get backed up and gum up your throttle body so the oil can make your car idle crappy. Mine was nasty black from oil before i had a catch can. Caused some bad idle problems.
Not sure about the "clank". Once it just 1 clank or did it tap for a while? a clank i wouldn't worry about, but if it's making some noises on startup i'm not sure. Sometimes i lifter will stick and that can tap for a while until it builds hydraulic pressure back up.
Old Jul 18, 2010 | 08:00 AM
  #89
jeffie7's Avatar
jeffie7
My car sits for a month at a time, the brake rotors will get funky but that happens on any car after a few days.
As far as the clank, who knows. could be anything from nothing related to the motor to the motor, you did what I'd do, if I questioned my motor I'd do a full throttle run, if it still runs then yay.
Old Jul 18, 2010 | 11:53 AM
  #90
marra23's Avatar
marra23
Recently I noticed mine sounding like this.....should I be worried?
Old Jul 18, 2010 | 02:13 PM
  #91
Elperuano's Avatar
Elperuano
Thanks for da feedback guys. I'm pretty sure it was jus engine noise now, car started up fine today wit no noise n no problems at all doin some runs. Probably what binder said about da hydraulic pressure. Maybe when it sat for awhile without being turned on caused for da noise.
Lol jeffie, exactly what I do. Always do a full throttle run if I question anything but it pulls hard n thas all dat matters
Old Jul 19, 2010 | 05:54 AM
  #92
jonnylaw's Avatar
jonnylaw
Noob question: does the powerlab kit require cutting/modification to the front crash bar/bumper support? How about the GTM and Greddy kits?
Old Jul 19, 2010 | 06:34 AM
  #93
Mr_pharmD's Avatar
Mr_pharmD
Yes it does...small amounts of cutting but I actually still had to add spacers in front of the bar so it wouldn't rub against the fins of the IC.
I believe the GTM doesn't allow u to use it and greddy i'm not sure.
Old Jul 19, 2010 | 08:01 AM
  #94
james12345pt's Avatar
james12345pt
You can use 3/4 hollow square bar between the mount and the alum bumper brace to save the brace and get flow to the top portion of the FMIC.
Old Jul 19, 2010 | 12:21 PM
  #95
binder's Avatar
binder
not if it's a lifter but i'd have to hear the noise to know.
plus, a lifter losing hydraulic pressure will stop after it builds pressure again. It won't continue to make the noise for days or anything like that.
Old Jul 19, 2010 | 12:40 PM
  #96
marra23's Avatar
marra23
Only for a few seconds on start up when cold.....I was thinking maybe the timing chain/tensioner.
Sorry for the hijack, OP.
Old Jul 19, 2010 | 07:15 PM
  #97
Elperuano's Avatar
Elperuano
Good to know, i only heard it on a cold start that was about a week n a half.. Ever since then that noise is gone.. Pretty sure it was this.
No problem... hope u get it resolved
Old Jul 20, 2010 | 03:03 PM
  #98
superchargedg's Avatar
superchargedg
Damn Noobs
With the Greddy kit the crash bar is gone.
Old Jul 22, 2010 | 10:06 PM
  #99
Elperuano's Avatar
Elperuano
teaser vid...
http://www.youtube.com/watch?v=n0c4sc32fyQ
btw my crashbar was removed... i figured it was pretty useless and any accident ima be in (god willing i wont be in one) i doubt that crash bar would serve any purpose on a boosted ride.
Old Jul 23, 2010 | 04:05 AM
  #100
str8dum1's Avatar
str8dum1
hope thats your BOV and not compressor surge. Sounds really fluttery. I seem to remember you werent using a Tial though. the solid pshh from the tial is nice
Sounds like you have excellent traction
