Head Gaskets
Old May 12, 2010 | 03:27 PM
BOOCKER's Avatar
BOOCKER
Default Head Gaskets
HI guys, does anyone know what kind/brand of head gasket do i should buy, my car has a small leaking, i´ve a vortech SC, i think thats why is leaking and i want to change it, but i dont know wich would be the best for my car.
some suggestion?
Old May 12, 2010 | 03:32 PM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
We typically use Cometic here. Just sold a set to "binder" on here...hes making roughly 500hp on his vortech set up. We stock all the common sizes. PM me if interested.
midz350's Avatar
midz350
VQ35HR OEM Head Gasket is cheap and has been tested up to 600whp.
Old May 12, 2010 | 04:34 PM
streetzlegend's Avatar
streetzlegend
HR head gasket with coolant passage mod! and if you throw on L19's your good to go. Somones running 9's on HR gasket and L19s. But HR head bolts are good too, id say for bout high 500's
Old May 12, 2010 | 04:39 PM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Cometic and HKS are two both very good head gaskets. Not sure who is running 9's on HR gaskets and L19s. HR gaskets can turn into costing quite a bite more than the gaskets above if they fail (rebuilding a motor, decking a block that uses a timing chain, etc). IMHO the HR gaskets haven't been tested enough to be a good alternative quite yet.
Old May 12, 2010 | 04:53 PM
streetzlegend
They havent been tested enough, I agree, but I cant think of any known failures except maybe just one, just giving different options. https://my350z.com/forum/8042349-post1.html " L19 Head Studs" "HR OEM Head Gaskets"
Old May 12, 2010 | 05:03 PM
BOOCKER's Avatar
BOOCKER
mmm... so i think that i ll go for cometic, but do i should buy the standard head gasket.
Cometic Gasket
Part: Multiple Layer Stainless Steel Head Gasket
Part #: C4345-030 (Left Side), C4361-030 (Right Side)
Bore Size: 96mm
Thickness: 0.8mm (Standard)
that´s a good option?
Old May 12, 2010 | 05:38 PM
midz350's Avatar
midz350
I think I saw more Cometic failures than the HR.
Old May 12, 2010 | 06:04 PM
streetzlegend
Triple layer + fire ring > cometic!
Old May 12, 2010 | 06:59 PM
ttg35fort's Avatar
ttg35fort
Professional
Some people have had issues with Cometic head gaskets. HKS headgaskets seem to have the best track record, but they are pricey. The HR headgaskets have not been out as long, and thus don't have the proven track record like the HKS headgaskets, but so far they seem to be holding up well.
Old May 12, 2010 | 08:04 PM
BOOCKER's Avatar
BOOCKER
mmm... I am confused
Old May 12, 2010 | 09:18 PM
streetzlegend
Bottom line, is money as issue for you? If no, then get HKS. if your doing a budget build like I did, get HR gasket.
Old May 12, 2010 | 10:12 PM
BOOCKER's Avatar
BOOCKER
im not saying that money isn´t a problem for me, but i wanna ´ve the best option in my car, i dont want to waste time and money, thats why im asking.
i´ve used a cometic gaskets, when i had my turbo civic Si, but i dont know if is the same or the best option for the vq35de.
but thnx to all, i´ll check, cometics, hks and hr gaskets.
Old May 12, 2010 | 11:11 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
some suggestion?
What exactly is a small leaking?? and why do you think its a head gasket?
Old May 13, 2010 | 04:14 AM
ttg35fort's Avatar
ttg35fort
Professional
If you want the best option for your car, then the choice is clear, get HKS headgaskets. They are somewhere around $300.
If price is an issue, but you still want something good, get the HR headgaskets. They are somewhere around $70.
Here is a very informative thread. OP, read through this:
https://my350z.com/forum/forced-indu...eadgasket.html
That thread includes links to one or two other threads where different people were having various issues with Cometic headgaskets.
EDIT: One more note: Here is a link that shows the HR headgasket in comparison to the first and second generation headgaskets. http://www.jimwolftechnology.com/wol...HEAD_BOLTS.pdf
If you run the HR headgaskets, there is a small cooling passage modification that needs to be made, as shown in the document.
FYI, I am running the HR headgaskets with ARP L19 headstuds on my new motor. I know of a few guys running this combination with north of 15 psi of boost. So far, I have not seen anyone post any issues with it. I went with the HR headgasket because of the improved coolent flow pattern. If the coolent flow pattern is not a concern for you, then stick with the HKS headgasket, which is the most proven for the VQ35DE motor.
Pleask
Dec 21, 2021 03:17 PM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
