Powerlab 35R kit will not make 500 HP
I would think carefully before spending too much $ chasing #s. At 15 psi (with my 700bb kit on a 5AT)) I made 482 whp on Sharif's dyno, 505 whp of Injected's DD (at ZdayZ), and 523 whp on a local Dynojet with STD correction. Dyno readings vary all over the place when it's different days, conditions, etc.
When you're ready for a jump in power - you'll need a big jump in power to feel it, whether it's from 465 or 500.
I think you may get the most bang for the buck from a good meth injection setup - that seems like the most practical choice since it will allow you to run the turbo out a little more and cool the intake charge at the same time. Good luck.
so why is your goal to max out a single pump walbro?
you def don't want to get to that range. it gets super expensive. try 2400$ for a stage 3 fuel system (twin pump). i know, i'm there and there is a HUGE price difference to make any noticable power gains just like RC said.
Also, this thread title should be closed, especially since the OP now admits he hit 500whp on pump gas.
I have a question about Meth injection. Where the gain in power made? Timing or Increasing the Boost?
you have to tune for it but you can advance timing due to higher octane along with increasing the boost due to the cooler air temps. Increasing boost won't really do a whole lot if you are already outside of the efficiency range of the turbo though.
most of meth is power due to advanced timing. meth decreases AIT along with increased octane are 2 reasons timing can be advanced.
both.
If the AITs could be dropped, there may be a little room for increased boost. All I would like to achieve at this point is the 40-50 whp that I thought the kit would have achieved since I will be out of fuel by that point. What Meth kit would you recommend to achieve an extra 40-50hp without breaking the bank?
snow stage 2
coolingmist varicool
aem
40-50hp is asking a lot for a turbo that's already out of its effeciency range (noted by the severe increase in IAT).
I am weighing out the cost to benefit ratio. If I can produce the extra hp with a ~$500 Meth kit that I can install and then Have IP do a simple retune that may only cost me an extra ~$100-200 vs $2000 turbo, have IP install that turbo since I couldn't drive the car to them if I change to turbo out first, and an $400-500 retune. I know the gt37 can product more power than the meth kit but I don't know if I will have enough fuel at that point and don't plan on buying an twin pump and upgrade lines from stage 1 to stage 3.
Just wondering, if i were to upgrade the turbo to a t67 could I keep all the piping that came with the original PL kit? What would have to be changed to run this bigger turbo? Is it just drop n play or would it require different piping n all?
should be the same if the flange is the same, and all the connectors are the same.
If I am understanding this thread correctly, the turbo itself is the limiting factor, not the piping.
Where would you sell a GT35R and how much could you get for it?
I think you could modify the intake pipe to connect to the intake of the GT37
It is still quite disappointing to see this kit unable to use a built motor without meth or race gas
+10000000 I wouldof been very upset if I bought this kit Ithinking I was gonna make 550whp+++ on 93 pump. I guess we truely find out the real numbers of kits when users put them to the limit. Good luck OP wish your performance wishes come true without costing you an arm and a leg.
This comment and this thread are ridiculous. Just because HIS kit with HIS build didn't make the power he wanted (it actually did), doesn't mean it can't be done. Several components of his build are limiting and have been mentioned. The kit has produced the power claimed by the manufacturer on multiple cars. He first said it WONT do 500whp, which it currently IS doing! Secondly, why would he NOT put in a couple gallons of 110 or C16 to see what the car puts down? that's like complaining that you can't get enough power on 87 and refusing to try 91/93! I assume he has more than a couple of dollars into his car, so he shouldn't go broke with a few gallons of Q16 even at $15/gallon. Proper advice from his original and current builder/tuner or even this forum or a friend or anyone would have helped this guy avoid a lot of heartache.
It's ridiculous to see people indulging such ignorance... as if it's realistic or reasonable/prudent to expect 500-550whp on a DD dyno (which equates to 550-600+whp on a DJ dyno) while using only pump gas with a turbo that maxes out at ~650whp on a DJ dyno with C16 fuel.
"The Choke Line is the right hand boundary of the compressor map. For Garrett maps, the choke line is typically defined by the point where the efficiency drops below 58%. In addition to the rapid drop of compressor efficiency past this point, the turbo speed will also be approaching or exceeding the allowable limit. If your actual or predicted operation is beyond this limit, a larger compressor is necessary."
In other words, even if you can get the hp numbers, the turbo is going to have a shorter than expected life.
One more note, there are different versions of the GT3582R turbo. Some versions have a ported shroud, which shifts the choke line lower along the pressure ratio axis. This would help turbo efficiencey, and thus lower the IAT, in this particular case. In other words, it will help with the power issue.
