My build: Greddy HR TT 350Z
Old Jun 1, 2010 | 11:37 AM
  #121
Barnabas's Avatar
Barnabas
National Z Club President
Frank/Frank get it sorted out?
they are going to be reloading software tonight.
Old Jun 1, 2010 | 12:02 PM
  #122
MDHRZ's Avatar
MDHRZ
Just got off the phone with Frank. UpRev knew exactly what the issue was but for some reason they didn't include it in the documentation. The lightened flywheel was causing the misfire codes which jacked the timing up. Should be an easy fix. Back on the dyno tomorrow.
Old Jun 1, 2010 | 12:27 PM
  #123
03threefiftyz's Avatar
03threefiftyz
Funny enough.......that is exactly what Frank (Hill) thought it would be on Sat night.
Old Jun 1, 2010 | 12:37 PM
  #124
MDHRZ's Avatar
MDHRZ
That man knows his **** for sure. I'm impressed with everything he has done so far.
Old Jun 1, 2010 | 01:11 PM
  #125
JDM_Joe's Avatar
JDM_Joe
great to hear it was a minor issue that will be fixed. i'm still debating whether to just go with osiris or haltech... looking forward to your results!!
Old Jun 1, 2010 | 04:28 PM
  #126
str8dum1's Avatar
str8dum1
if thats the case, then everyone with a light flywheel would have the same problem with misfire codes
whats the solution?
Old Jun 1, 2010 | 04:36 PM
  #127
MDHRZ's Avatar
MDHRZ
whats the solution?
UpRev says it's only an issue with the HR motors being that they are more sensitive . Those codes will be disabled.
Old Jun 1, 2010 | 05:24 PM
  #128
str8dum1's Avatar
str8dum1
disabling the misfire codes? wow. good luck with that...
Old Jun 1, 2010 | 05:34 PM
  #129
MDHRZ's Avatar
MDHRZ
I'll get more details tomorrow. What would be the problem with doing that? Pros/cons? A lot of this is new to me so I'm kind of learning as I go. From what I've read and been told, the UpRev software has the capability of doing that.
Old Jun 1, 2010 | 05:39 PM
  #130
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
For the record, my HR is running a lightened clutch/fly combo (os giken) and I have yet to see a misfire code.
MD, how much lighter than stock is your flywheel?
Old Jun 1, 2010 | 05:42 PM
  #131
MDHRZ's Avatar
MDHRZ
It's over 7lbs lighter than the stock one -> http://www.zspeedperformance.com/Sou...l-SBCHRFLY.htm
Old Jun 1, 2010 | 07:04 PM
  #132
03threefiftyz
Sure, it can, but disabling the codes will also disable your first warning (ses light) if a misfire issue arises. The ecu is likely to catch it before it becomes audible/noticable......thus it put the system into limp mode or shuts it of as a damage prevention. I'd imagine frank will attempt to fix the issue first and foremost.
Old Jun 1, 2010 | 08:22 PM
  #133
08NismoZ's Avatar
08NismoZ
So what mods did you do to your transmission for the new clutch, and have you had any problems with your OS Gilken? I'm going to have Injected Performance look into this because i'm really tired of the stock clutch!
Old Jun 2, 2010 | 02:51 AM
  #134
MDHRZ's Avatar
MDHRZ
Hmm, good point. I'll try to get some more clarification on this when he gets to the shop.
Pretty sure he hasn't had any issues which makes me wonder why I am the only one throwing codes. I haven't seen this issue with any other HR's. More info on the clutch -> https://my350z.com/forum/8402009-post8.html
Old Jun 2, 2010 | 04:53 AM
  #135
Alberto's Avatar
Alberto
Cranky FI Owner
Every car and setup is different. Just because one guy doesnt have an issue doesnt mean that its not the cause of the issue here. LOL @ some peoples comments.
Frank will sort it all out...
Old Jun 2, 2010 | 07:32 AM
  #136
Chris@FsP's Avatar
Chris@FsP
I have done nothing at all to the transmission or CSC assembly, and I have had absolutely ZERO problems with this clutch. Been running it since November.
Old Jun 2, 2010 | 12:55 PM
  #137
MDHRZ's Avatar
MDHRZ
Misfire codes were not disabled. Crank sensor errors were disabled. It made 513whp at 10psi.
Old Jun 2, 2010 | 12:56 PM
  #138
Barnabas's Avatar
Barnabas
sexy!!!!!
  #139
03threefiftyz
Hot damn.....it was hot as **** out today......what psi/power are you going to daily on?
Old Jun 2, 2010 | 01:13 PM
  #140
MDHRZ's Avatar
MDHRZ
Not 10 lol. Frank said he'll set the "a" setting for 7psi. I might just turn the boost controller off and let it run at 5psi.
