Jtran Studios Presents turbo kits (fabrication thread)
Old Apr 2, 2011 | 06:45 PM
  #281
tiguy99's Avatar
tiguy99
Originally Posted by Jtran Studios
below pics are actual manifolds that we have built. two different sr20det manifolds and one evo manifold. will be posting pics up of the actual 350z end of today. just finalized one of the runners to the actual t4 divided flange already. ic has been done already also.
On a sidenote...Would you guys be able to make one of these with an HFC for a Toyota 1mzfe V6 motor? I have it installed in my 91 MR2 and I'm going with a Holset HX35 twin scroll turbo.
If you're interested, can you PM me? I'm very excited & would love to see what you guys can do with this
Old Apr 2, 2011 | 07:50 PM
  #282
bldg250z's Avatar
bldg250z
Originally Posted by bldg250z
Did a trial run tonight ... one of my axles didnt hold on my second run but I will be going back to the track sometime next week hopefully to be able to get a clean run....
I made one pass but let off after a vacuum line popped loose ... basically ran a 12.11 coasting a third of the 1/4 mile(more or less) and a 7.9 at the 1/8, i spun the tires of the two step but managed a 1.9 60'... ill post time slips ltr... again wasnt a full run and for the first time handling this power and not being at the track in over a yr its not to bad IMO!
side note this was on low boost set up at about 15 psi...
thanks JT for keeping me focused tonight!
theres a bit more info to share but ill let Jt tune in to explain whenever he gets a chance... apparently... there was more in that run that i didnt get to run...
Old Apr 2, 2011 | 07:52 PM
  #283
bldg250z's Avatar
bldg250z
Def give them a call to get you a quote!
Old Apr 3, 2011 | 05:36 AM
  #284
tiguy99's Avatar
tiguy99
Definitely will do! Thanks man.
Old Apr 3, 2011 | 06:06 AM
  #285
binder's Avatar
binder
Originally Posted by str8dum1
Do you have the wastegate plumbed like diagram 2? I controlled 35+psi on 1 bar springs that way. Simple fix if you dont.
I might have to try that. It appears this cannot be used if you turn off your wastegate and just run spring pressure since the upper part of the wastegate is blocked off from the atmosphere. Is that correct?
Old Apr 3, 2011 | 02:57 PM
  #286
str8dum1's Avatar
str8dum1
dunno, always used wastegate control. but it works to hold big boost on small springs
OP, sounds like a solid run will display the awesomeness of this kit. cant wait!
Old Apr 4, 2011 | 06:16 AM
  #287
bldg250z's Avatar
bldg250z
thanks, looking at my run i Log i was slipping quite a bit and the vacuum line to my meth kit popped out since the beggining of my run could of been much better ... plus i need to improve my sixty foot... here is the time slip
Attached Thumbnails Jtran Studios Presents turbo kits (fabrication thread)-photo-1-.jpg
Old Apr 4, 2011 | 07:09 AM
  #288
gotagetmyZ's Avatar
gotagetmyZ
I say we slap on some slicks and let her rip. That'll bring that 60' down for sure
Old Apr 4, 2011 | 07:29 AM
  #289
bldg250z's Avatar
bldg250z
FO SHo DAve! lol
Old Apr 4, 2011 | 05:27 PM
  #290
chaparro78's Avatar
chaparro78
Thumbs up
Just want to give JTran a bump. I was lucky to have him build the fuel system for my car and I saw him go the extra mile when it wasn't needed. He invited me into his home and is always willing to pick up the phone when I call for stupid questions. I will never let anyone else touch my car and will trailer my car to Houston from Dallas ( i have ) if it needs to be worked on.
Old Apr 5, 2011 | 06:21 AM
  #291
ColecatZ's Avatar
ColecatZ
Nice, that's the kinda feeback that is good to hear. Thanks man.
Old Apr 5, 2011 | 08:14 PM
  #292
bldg250z's Avatar
bldg250z
great words, i couldnt of have put that in better words... Jt did the same for me and if I had to do it all over again i would of cut everyone else and gone straight to him without skipping a heartbeat... same goes here no one touches my car excpt JTran Studio's
Old Apr 5, 2011 | 11:40 PM
  #293
ekelly36's Avatar
ekelly36
HR Kit?
Old Apr 6, 2011 | 09:32 AM
  #294
binder's Avatar
binder
Originally Posted by ekelly36
HR Kit?
i think this was a custom install therefore there isn't a kit at all.
Old Apr 7, 2011 | 06:39 AM
  #295
bldg250z's Avatar
bldg250z
It is a custom kit.... but i know Jtran is willing to build a kit for an HR!....my car has been running like a champ! pulls hard
Old Apr 7, 2011 | 07:40 AM
  #296
gotagetmyZ's Avatar
gotagetmyZ
Pulls Hard huh???
Let's see how hard. Comparison to a PowerLab/Built/15 PSI coming soon ;-)
I don't mind loosing. Lol. It's just for funzies anyways and were buds
Old Apr 7, 2011 | 10:47 AM
  #297
midz350's Avatar
midz350
Pulls Hard huh???
Good luck breaking the 500whp
Old Apr 7, 2011 | 11:06 AM
  #298
rh_334's Avatar
rh_334
I was thinking the exact same thing
Old Apr 7, 2011 | 07:32 PM
  #299
binder's Avatar
binder
hahahhaa
and the fact that the powerlab is a gt35r turbo verses this 4088r. Nice size difference in turbo.
Old Apr 7, 2011 | 07:44 PM
  #300
gotagetmyZ's Avatar
gotagetmyZ
Me and the OP are good friends. My comment was meant more for a comparison that I'd like to see aswell as all our other friends. The OPs build is by far superior when compared to the POWERLAB kit. I really just want to see how bad he whoops me at 16 PSI and then on his high boost 22PSI MAP.
BTW. My Z made 508RWHP on JTs Mustang Dyno several months ago. Not bragging or anything just solidifying the fact that it's very difficult to break the 500rwhp barrier w that kit ;-)
