Jtran Studios Presents turbo kits (fabrication thread)
Old Nov 11, 2010 | 09:43 AM
  #241
str8dum1's Avatar
str8dum1
ouch, a garrett rebuild alone is $$$$$.
good luck!
Old Nov 11, 2010 | 10:55 AM
  #242
Vas_Z33's Avatar
Vas_Z33
yikes
Old Nov 11, 2010 | 11:32 AM
  #243
CRIDDA's Avatar
CRIDDA
Damn that sucks
Old Nov 11, 2010 | 12:05 PM
  #244
failsafe306's Avatar
failsafe306
What is with all the spun bearings lately?
Old Nov 11, 2010 | 12:59 PM
  #245
bldg250z's Avatar
bldg250z
what to do............ what to do
Old Nov 11, 2010 | 01:15 PM
  #246
str8dum1's Avatar
str8dum1
I guess figure out if the turbo and entire engine is wiped from the metal in the oil....
Old Nov 12, 2010 | 10:42 AM
  #247
binder's Avatar
binder
wow, that sucks. IDK what is with all the spun bearings. I put mine through it's paces with no problems on the engine part.
Old Nov 12, 2010 | 04:06 PM
  #248
bldg250z's Avatar
bldg250z
i dont know but motor was good through the first 5000+ miles ive put in it!
bottom end i had was from forged performance and reputation on them are good as far as i know.
Old Nov 13, 2010 | 08:07 AM
  #249
binder's Avatar
binder
hmm, i doubt these are all build problems. seems like it has to be something else like a restriction or someone screwed something up along the way. hard to tell what it could be though.
Old Nov 13, 2010 | 09:18 AM
  #250
rcdash's Avatar
rcdash
5k miles and then a spun bearing? Hmmm... Just curious if you know what the oil temps were.
Sorry to hear - good luck man.
Old Nov 14, 2010 | 02:18 PM
  #251
Chef-J's Avatar
Chef-J
Booooosstt!!
Sorry to hear that...Good luck...
Old Nov 14, 2010 | 02:52 PM
  #252
bigcloud's Avatar
bigcloud
Sorry to see your motor die man. Why would you call it quits? I would sell what you can and pursue OTHER power options besides a built motor w/FI. Just putting a thought out there....
Old Nov 15, 2010 | 06:35 AM
  #253
bldg250z's Avatar
bldg250z
Nah no quits guys I was in a state of depression for a day or two but I will finish this car and hopefully everything turns out good!! Just hate to be down another few months ... I will keep you guys posted on what happens next.
Old Nov 15, 2010 | 07:26 AM
  #254
midz350's Avatar
midz350
Sorry to hear man.
I'm thinking about ditching the stupid VQ and put a RB26 OR 2JZ in my car. (but hopefully nothing major in mine and just failing oil pump )
Old Nov 15, 2010 | 08:40 AM
  #255
bigcloud's Avatar
bigcloud
Originally Posted by midz350
Sorry to hear man.
You're better off putting in an LS motor. Multiple off the shelf kits for the swap. The RB doesn't have an off the shelf kit. The 2JZ does, but why put those older motors in there? There are some other hurdles to overcome to finish the install, but it's not as difficult as putting in an RB or 2JZ OBDI system. Unless you can swap in older motors legally where you live I wouldn't do it.
Old Nov 15, 2010 | 05:59 PM
  #256
binder's Avatar
binder
and the fact that who says the 2jz or rb26 you get won't fail? You do realize that supras and GTR's have engine failures also, right? Just have your engine built, it's much cheaper than buying a different engine, hvaing that engine built to handle the hp then trying to fit it with all the extra parts into your car.
If it's mechanical and you screw with it, it will eventually fail.
Old Nov 16, 2010 | 06:43 AM
  #257
bldg250z's Avatar
bldg250z
IMO.... i agree all motors can have engine failures...
well got back from houston last night went over with Jt on what was next and well im hoping that we got only a spun bearing and nothing else bent... they will pull the motor out disassemble and send it to the machine shop for a report on what happened ... after that put it back together and break in the motor and if all goes well start enjoying this project car!
only down side is holidays are coming up and i hope the machine shop dont take that much longer ... so i might be looking at another couple of months... ill keep you guys posted on the progress!
heres the last video i got a few days before the issue!
http://www.youtube.com/watch?v=_rPL8iic5rA
Old Nov 16, 2010 | 09:29 AM
  #258
str8dum1's Avatar
str8dum1
so he is not concerned that bearing material went thru your turbo?
Old Nov 16, 2010 | 10:21 AM
  #259
bldg250z's Avatar
bldg250z
Good question I'll figure that out!
Old Nov 16, 2010 | 11:09 AM
  #260
binder's Avatar
binder
nobody cares about that, at least not on these forums.
and not just turbo, heads, cams, oil squirters into the cylinders. Talk about abrasive.
