Cass007.... ver 5.0
Old May 9, 2011 | 03:13 PM
  #621
djamps's Avatar
djamps
Originally Posted by RudeG_v2.0
^ Moderator in an e-***** smackdown.
muahahhaa
Old May 9, 2011 | 03:32 PM
  #622
Cass007's Avatar
Cass007
For IslandZavage:
Cass007.... ver 5.0-p5091431.jpg Cass007.... ver 5.0-p5091432.jpg Cass007.... ver 5.0-p5091433.jpg
There is a scuff mark on the timing cover (pic one top center), not sure from what, but the mark could not be seen with the plenum on. I had no idea it was there till I looked at the picture.
Old May 9, 2011 | 03:36 PM
  #623
Cass007's Avatar
Cass007
The white spots on the underside are just water marks, they wipe right off.
Cass007.... ver 5.0-p5091434.jpg Cass007.... ver 5.0-p5091435.jpg Cass007.... ver 5.0-p5091436.jpg Cass007.... ver 5.0-p5091437.jpg
I just went to the garage and confirmed that the mark on the front left of the top of the plenum was just dust - not a scuff mark.
Old May 12, 2011 | 03:19 PM
  #624
Cass007's Avatar
Cass007
Per request of an interested party:
Cass007.... ver 5.0-p5121441.jpg Cass007.... ver 5.0-p5121442.jpg Cass007.... ver 5.0-p5121444.jpg Cass007.... ver 5.0-p5121445.jpg
You can see the is some orange peel on the drivers side rear cover... this is covered by the intake pipe going over the top of it.
Old May 14, 2011 | 03:48 AM
  #625
Cass007's Avatar
Cass007
Intake, DW 800cc injectors, valve covers and APS Plenum up for sale in the classifieds.
Old May 17, 2011 | 10:45 AM
  #626
Cass007's Avatar
Cass007
Need a little help. Does anyone know how I can remove the crank pulley with the car already on jack stands and the driveshaft removed? I want to sell my fluidampner pulley as soon as I can get it off the car.
Old May 17, 2011 | 10:58 AM
  #627
Glex25's Avatar
Glex25
Use a oil remover tool but the one with the chains and a rag wrapped around the pulley and hit it with a impact gun. You can also try doing this with a belt of sort.
On my sons car I had to take off the pulley and had to construct my own tool to hold the crank from turning
Some thing like this
If you got the new style like mine
I wonder if it's possible to put a socket on the pulleys for the cams so the motor won't turn
and you can get the pulley off
Old May 17, 2011 | 11:16 AM
  #628
Cass007's Avatar
Cass007
I have the valve covers off and can get a 24mm wrench on the pass side cam and use the side of the car to stop its progress, but I was worried I would snap the cam before the bolt gave way
Old May 17, 2011 | 11:19 AM
  #629
rh_334's Avatar
rh_334
You should be fine, just hold the cam, and the first time the impact hits (assuming you have a decent impact) it will likely break loose.
Old May 17, 2011 | 12:32 PM
  #630
Cass007's Avatar
Cass007
Impact didn't work, I tried an electric gun and then an air gun at roughly 90psi and nothing. Can I use the cam and a breaker bar?
Old May 17, 2011 | 12:35 PM
  #631
rh_334's Avatar
rh_334
Yes you can, but just make sure its a good wrench and a tight fit on the cam, you dont want to round it off.
Old May 17, 2011 | 02:45 PM
  #632
DaveJackson's Avatar
DaveJackson
Master
I had a brutal time removing mine, but if you can remove the starter, apparently there is a tool you can jam in there to lock everything up. It also helped to put the torch to the bolt.
Old May 17, 2011 | 02:56 PM
  #633
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
I would not put a torch to the bolt. This will cause it to expand and make it even harder to pull out.
When using heat to remove a stubborn bolt, you always heat the female side of the thread and not the bolt itself. In this case it is not possible because you would heave to heat the crank.
Old May 17, 2011 | 03:35 PM
  #634
Cass007's Avatar
Cass007
- no torch as the dampner is what I want to sell and I want it to be in pristine condition.
I just tried the breaker bar and starter trick... no dice. The bar got to the frame and just stopped
If I put the driveshaft back on will the parking brake give me the resistance I need to break this loose? I just don't want to do that work for nothing, its bad enough I already re-installed the starter for the last attempt. Stupid blue pile of FAIL!!
Old May 17, 2011 | 03:41 PM
  #635
Sylvan Lake V35's Avatar
Sylvan Lake V35
give the breaker bar a couple inches of slack from the frame rail and try the starter a couple times, it worked for mine when an impact was not availible.
Old May 17, 2011 | 05:17 PM
  #636
Glex25's Avatar
Glex25
When I have a stubborn bolt like that I use the breaker and I take the upper half of the shaft for the hydraulic jack and put it over the breaker bar (Basically making the breaker bar longer) to give it more leverage and usually it pops right out
Old May 17, 2011 | 06:08 PM
  #637
Cass007's Avatar
Cass007
I will try this in the morning, thanks gord
Glex - the bar is already 3' long. Its not that I don't have the leverage, its that I don't have anything giving the engine resistance against turning.
If Gord's idea doesn't work I will put the driveshaft back in and try it that way or see if someone local has some serious air tools and a portable compressor.
Old May 17, 2011 | 06:37 PM
  #638
str8dum1's Avatar
str8dum1
you just need a better impact. i used my buddies Snap on impact with 120psi and the bolt came right out.
getting the pulley off the crank was a whole different matter though...
Old May 18, 2011 | 07:28 AM
  #639
XKR's Avatar
XKR
Good luck on your next move Chris...Hope to see you at 2012 ZdayZ
Old May 18, 2011 | 09:53 AM
  #640
jerryd87's Avatar
jerryd87
Ingersoll rand thunder gun(sp?) i had one worked as good as my bosses snap on but cost me only $240 on the tool truck when they first came out(think stores where about 300 at the time) i guarantee you it will take the bolt out np if you have the air supply for it. used to snap shackle bolts on ford rangers when the shackle would snap since the bolt wouldnt come out.(about 1 inch bolts)
