procharger grinding at low idle?!?!
Old Nov 10, 2003 | 09:01 AM
noahbuddy's Avatar
noahbuddy
Default procharger grinding at low idle?!?!
Anyone else with a procharger get a lot of grinding noise ( kind of like a low frequency growling ) when sitting in idle? I've got only 600 miles on it, but it doesn't seem to be going away. There's also a lot of vibration at idle. So much that I can feel it in the clutch pedal.
Also, when I put the car in neutral, the rpms drop very low and bog down the engine. Did the rest of you guys get the idle rpm raised or do you experience the same issues?
I'll try to post a sound clip if I'm not making any sense.
Old Nov 10, 2003 | 09:13 AM
evilz's Avatar
evilz
dude i get the same sound on my charger ..the noise is coming from the snail itself....i called ati, they want me to rip it out and send it in for warranty repair....it sounds like a grind and the noise kicks in the hardest at idle and in reverse right?
Old Nov 10, 2003 | 10:07 AM
noahbuddy's Avatar
noahbuddy
exactly. at speed it's fine. it's only at idle, up to about 1200 rpm
Old Nov 10, 2003 | 10:18 AM
evilz's Avatar
evilz
do u get it the worst in the initial seconds in reverse?pm me ur numer or aim so i can talk to u about this
Old Nov 10, 2003 | 10:44 AM
N4Spd's Avatar
N4Spd
anyway you too could post sound clips?
Old Nov 10, 2003 | 12:08 PM
evilz's Avatar
evilz
sorry man i have no way of posting a sound clip =(
Old Nov 10, 2003 | 12:25 PM
keepupp's Avatar
keepupp
I think the noise is coming from the belts. Mine has it at times, but mainly when the accessory pulley is being used to run the air conditioner, defroster, etc. It seems that when the blower belt are running slowly they chatter....I could be wrong.
Old Nov 10, 2003 | 06:43 PM
noahbuddy's Avatar
noahbuddy
ok, here is a sound clip (10 mb each). This is me rocking back and forth in 1st and reverse. I'm going slow, like you would if you were backing out of a spot with 2 suv's parked on either side.
http://cyberpnk.virtualave.net/1st_r...ow_rock_ac.wav
and here's one of me reving the engine in neutral. not very interesting and you can't hear much besides the normal whine and air.
http://cyberpnk.virtualave.net/idle_rev_neutral.wav
Old Nov 10, 2003 | 06:51 PM
Ralphus's Avatar
Ralphus
Didn't MaxHax and that other guy say they had a chatter/vibration at low RPMs before their motor blew?
Search for the MaxHax thread I believe he says something like that.
Old Nov 10, 2003 | 07:04 PM
keepupp's Avatar
keepupp
I think MaxHax had a rough idle though.....mine for example has a perfect idle, but when I gently depress the clutch to start rolling and the rpms drop below 1000, the belts seem to make noise.
Old Nov 10, 2003 | 07:32 PM
skk100's Avatar
skk100
write a letter to ATI and tell them how pissed you are. Have they been contacted already? That is f'ed up. I would be pissed. I was at Stillen when they first installed my SC and they finally paid attention.
Old Nov 10, 2003 | 07:39 PM
noahbuddy's Avatar
noahbuddy
did anyone with the ati get the idle rpm raise?
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
