Water Temp
Old Jul 31, 2010 | 06:54 AM
SV1098's Avatar
SV1098
Default Water Temp
Guys,
Whats the normal operating temp, on your water temp gauge? Right now its between 190-210 degrees, during normal driving conditions..
Thanks
Old Jul 31, 2010 | 08:15 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
will depend on your speed, ambient temp, airflow to radiator, etc, but that is in the normal range
Old Jul 31, 2010 | 08:36 AM
graffkid732's Avatar
graffkid732
That is about what I run, 180-200 and I usually hit 205-215 if sitting in traffic when hot/humid out. Goes down as soon as I start moving.
Old Jul 31, 2010 | 10:31 AM
binder's Avatar
binder
mine usually sits in low 190's average. Cruising on the highway it's down low 180's. When i'm boosting it barely breaks 200. I think 207* is the max i've seen on logs.
Old Jul 31, 2010 | 04:38 PM
SV1098's Avatar
SV1098
Thanks guys. The car is just soo much hotter under the hood now. I feal like I'm going to have a BBQ'd CF hood..LOL
Old Aug 1, 2010 | 07:22 AM
binder's Avatar
binder
what are you water temps?
heat soak is a *****. If your engine is the same temps as your coolant then you could imagine that all the pieces would be close to 200*. That's pretty hot to touch. Mine gets that way, after driving around for a few hours my plenum is almost too hot to touch.
Old Aug 1, 2010 | 07:27 AM
SV1098's Avatar
SV1098
Strange thing: the car runs cooler with the A/C on!
Old Aug 1, 2010 | 07:35 AM
binder's Avatar
binder
cause it runs both fans the entire time the a/c is on. Without the a/c on the fans only kick on when the car is hot.
engine bay temps will probably still be high though because the compressor and condenseor will be giving off a lot of heat.
Chris350z03
Oct 8, 2023 07:19 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
