Water/Methanol + Vortech. I'm having problems.
Old Sep 14, 2010 | 05:30 PM
GT-ER's Avatar
GT-ER
Originally Posted by 350z 6spd
Did you try moving the nozzle so the outlet is facing straight up from the bottom of the intake piping? It took me months to finally figure this out so that it wouldn't start pooling. It's the only way mine will work.
I would have to drill a new hole for that and would have to plug the old one. I'd have to do it over the weekend if nothing else works.
Old Sep 14, 2010 | 06:35 PM
booger's Avatar
booger
Cant remember the size of the nozzle I had with mine . But under boost and off and on the gas was no problem at all .
Were is your nozzle located at ?
Old Sep 14, 2010 | 06:54 PM
GT-ER's Avatar
GT-ER
Mine is located in the elbow that goes after the maf, before the TB.
Old Sep 14, 2010 | 07:50 PM
350z 6spd's Avatar
350z 6spd
That's what I ended up having to do. At first it didn't work and I was quite angry lol. Then I moved the tee fitting down and the problem went away.
Old Sep 14, 2010 | 08:47 PM
maXmood's Avatar
maXmood
Under Boost!
pics for ref..
thanks
Old Sep 14, 2010 | 09:08 PM
streetzlegend's Avatar
streetzlegend
How high are the tanks you guys have in relation to the nozzle? is it almost same level?
Old Sep 14, 2010 | 09:16 PM
GT-ER's Avatar
GT-ER
My tank is in my trunk floor.
Old Sep 14, 2010 | 09:23 PM
streetzlegend
What kind of line are you using? is it a plastic line?
I made the mistake of putting a rubber line the very first time I did my install and since it expands with pressure when the pump turns off it closes back up and continues to push the fluid into the nozzle.
Old Sep 15, 2010 | 04:39 AM
GT-ER's Avatar
GT-ER
it's plastic.
Old Sep 15, 2010 | 06:14 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Do you think that placing the nozzle further away would give it more time to atomize and smooth things out, especially those last brief moments when you let off and it seems to still be spraying?
I run my nozzle in the charge pipe lower than the level of the headlight coming off the FMIC, never had an issue.
Old Sep 15, 2010 | 07:17 AM
str8dum1's Avatar
str8dum1
mine spray 3" and 6" from the TB with no issue.... so i doubt physical distance is the issue, esp since direct port is very popular as well.
Old Sep 16, 2010 | 02:06 AM
HotRodG35's Avatar
HotRodG35
I also run a coolingmist inj system with a vortech. My nozzle mounted on bottom of pipe 1" before TB, boost activated @5 PSI and no issues with hesitation.
You may try mounting nozzle on bottom of pipe and adjust boost swich for higher PSI to ensure engine loaded.
Old Sep 16, 2010 | 04:42 AM
GT-ER's Avatar
GT-ER
I'm going to place it on the bottom today or tomorrow and check it out.
HotRodG35...you have no solenoid?
Old Sep 16, 2010 | 07:37 AM
HotRodG35's Avatar
HotRodG35
I do have a solenoid instead of a check valve. My coolingmist kit came with a solenoid.
I agree with sr8dum1 that distance to TB is not the issue.
BTW the Vortech kit you purchased from Chris M (CUX350z) I'm helping him with the TT swap in his Z, small world.
Old Sep 16, 2010 | 08:14 AM
GT-ER's Avatar
GT-ER
Hmmmm....looks like I'm gonna have to get the solenoid then. It's another $50.
It is a small world...
Old Sep 29, 2010 | 10:02 PM
maXmood's Avatar
maXmood
Under Boost!
updates??
Old Sep 30, 2010 | 03:58 AM
GT-ER's Avatar
GT-ER
I'm in the US right now until the 6th so it'll have to wait till then. I already have the solenoid however so I hope my problems will end with this.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
oicw
Jun 19, 2003 03:34 AM
Chebosto
Jan 17, 2003 11:59 PM
