My BP Single Turbo Kit Review
Old Nov 26, 2010 | 07:02 AM
  #61
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
OP and Sasha...what gear where your dyno runs done in??
Old Nov 26, 2010 | 07:27 AM
  #62
Boosted Performance's Avatar
Boosted Performance
Both were in 4th gear.
Old Nov 26, 2010 | 08:03 AM
  #63
Vince@R/TTuning
Thats gonna make the difference...
VAS was done in 5th gear for the final pull...i Can see if i can do a 4th/5th gear overlay and post it up..
Old Nov 26, 2010 | 08:32 AM
  #64
BCs350z's Avatar
BCs350z
correct, mine was done in 4th gear.
Old Nov 26, 2010 | 09:06 AM
  #65
Vince@R/TTuning
http://www.flickr.com/photos/4314748...5528/lightbox/
Same tune Run 27 was done in 4th and Run 28 was done in 5th...both at 80*C...
Old Nov 26, 2010 | 09:09 AM
  #66
binder's Avatar
binder
no picture vince.
and i'm not sure if it's because i was tuned on a DD instead of a DJ but 4th and 5th were close enough together that i couldn't tell the difference on mine.
I guess if it's inertia based like a DJ then the gearing of the car would determine the load on the engine where as a DD is a load based dyno so it can keep the load constant. In that case you would have a faster spool on the DJ when using a higher gear due to the increased load, correct?
Old Nov 26, 2010 | 09:16 AM
  #67
Vince@R/TTuning
^^^ Yes sir... I typically tune in 4th and then verify in 5th gear. I will be doing more testing as we just acquired a Mustang dyno so i will be able to do true Mustang vs Dynojet comparisons...
Also the pic hosting was giving me issues so i just added a link..
Old Nov 26, 2010 | 09:21 AM
  #68
str8dum1's Avatar
str8dum1
regardless, peak trq is still at the same rpm.. the OP's car is making boost appropiate power, just lagged.
Same rpm for peak trq
compared to the OP's peak trq 800 rpms later
Old Nov 26, 2010 | 09:31 AM
  #69
Vince@R/TTuning
^^^ there is a slight difference in spool between gears.. but you are correct his peak torque is off but quite a lil bit..
Old Nov 26, 2010 | 11:20 AM
  #70
BCs350z's Avatar
BCs350z
Here's a pic of a gasket from one of the hot pipes. Looks like a leak. I replaced that gasket and retightened all the bolts. i was able to get 3/4 to a full turn on every bolt i touched including the 4 bolts on the t4 flange and the 3 bolts at the end of each header. It definitely seems to respond better but it was hard to tell because when i took it out for a test drive, it was like 40 degrees out and i was seeing 11.3 psi instead of 10 like i usually do. I also saw my afr's go into the low 12's which i never saw before. Normally i always saw 11-11.4.
Old Nov 26, 2010 | 11:49 AM
  #71
CRIDDA's Avatar
CRIDDA
That should fix her right up
Old Nov 26, 2010 | 11:57 AM
  #72
Quamen's Avatar
Quamen
It is always a good idea to re-torque down the hot side once or twice after you heat cycle it a bunch. Certain things like to warp, seat or straighten. Sometimes this causes leaks like the one you just found. Good find and best of luck! I hope it fixes it!
Old Nov 26, 2010 | 12:06 PM
  #73
binder's Avatar
binder
+1 on this
also, did you check the 3 bolt flanges? those seem to be the most problematic since they are in a tough location to get them tight.
Old Nov 26, 2010 | 01:27 PM
  #74
350zion's Avatar
350zion
Professional
Lucky ****! Looks like u found ur problem...
Old Nov 26, 2010 | 02:14 PM
  #75
str8dum1's Avatar
str8dum1
good deal! i know i hated to keep steppin on necks to get this resolved
Old Nov 26, 2010 | 02:44 PM
  #76
Boosted Performance
Well thank you, I can finally breathe.
Old Nov 26, 2010 | 03:43 PM
  #77
str8dum1's Avatar
str8dum1
haha, i hate to see unused potential! esp with the turbo i love
Old Nov 26, 2010 | 09:17 PM
  #78
Vas_Z33's Avatar
Vas_Z33
op, sick!! Ill pm you about the duty cycles!
p.s- hey Jeff, hows that haltech? mhaha
Old Nov 26, 2010 | 09:20 PM
  #79
Vas_Z33's Avatar
Vas_Z33
vince, every time i run into ur name on the forum i automatically look at the phone, thinking if i should do that meth tune appt. fmll
Old Nov 27, 2010 | 07:24 AM
  #80
Boosted Performance
I would consider a larger turbine housing at this point as well. At least the .68 a/r.
