no reason to buy a Walbro 255L anymore
Old Dec 1, 2010 | 10:33 AM
Zivman's Avatar
Zivman
Originally Posted by str8dum1
Ya other platforms are already investigating this pump. I also read that it uses much bigger fuel connections compared to the 255. Also read that its the pump used in supercharged LS9 applications. Although it does seem to be stamped with the standard GSS341
The DW pump will be priced similiar (~$175) and flow similar to the bosch 044. If that walbro is shown to flow 385l at 110$ its a no brainer. The supra and DSM guys are on it and they try new things, so it wont be long til more info is available.
I just wouldnt buy a 255L until then if you have a built motor and return system
I just bought and installed this pump in my evo.
supposed to be some sort of 255 replacement with more flow.
it has reverse polarity of a 255, but everything else looks the same. It is MUCH quieter than a 255.
here is the flow chart on this pump
Old Dec 1, 2010 | 10:52 AM
str8dum1's Avatar
str8dum1
the normal high pressure walbro is part # gss342. similar to pt342
more info would be needed on that pump.
here, they say its a protec modified pump and that they will be at PRI.
http://honda-tech.com/showthread.php...5#post43890885
also link here
http://www.dsmtuners.com/forums/vend...044-342-a.html
Forged Performance is going to PRI, so hopefully people will be on the lookout.
Old Dec 1, 2010 | 11:23 AM
binder's Avatar
binder
Originally Posted by thatv35guy
Awww, that’s a bummer…the 325 fuel pump their working on, in theory how much whp would that support on E85?
40% less than it would on pumpgas since 40% more fuel for e85 is required.
Impossible to calculate since every car is different. Hell, my walbro was maxed out at 451hp when some others get their walbro's over 500hp. Everything in the build and car is a variable that effects it.
Old Dec 1, 2010 | 11:33 AM
str8dum1's Avatar
str8dum1
was your max on a supercharger? thats not apples to apples obviously
Old Dec 1, 2010 | 11:49 AM
binder's Avatar
binder
so far yes, i have the twinpump now so i'm not going to come close to maxing it now.
yes, it was on a supercharger and it was also on a DD dyno and everyone argues "this one reads high, this one reads low" blah blah. So technically nothing is apples to apples. Hal has had other s/c systems on his dyno get higher than mine also.
Old Dec 1, 2010 | 12:00 PM
str8dum1's Avatar
str8dum1
i maxed my 600cc injectors at 450whp on a DD. But my fuel pressure was fine with a single walbro. SO you saw your fuel pressure drop from high 50's (or whatever your base+boost was) to low 40s at full boost?
interesting....
Old Dec 1, 2010 | 12:16 PM
rcdash's Avatar
rcdash
My walbro max'd out at 6000 rpms with HKS 1000 cc injectors at 16 psi making 535 whp on a DJ (with a 5AT) - couldn't finish a pull because AFRs would approach 13 no matter what. The greater the injector pulse width I typed in, the more my fuel pressure dropped (down into the 20s). My alternator, fuel, and fuel pump were hot by this time - voltage was 11.6v so that wasn't good either... Complete waste of 2 hrs on the dyno. (FWIW, 520 STD on this dynojet equated to a 475 on Sharif's dyno and 505 on Hal's, all at 15 psi but at different times/conditions). I'll be bumping up the voltage to 17v along with the CJM stage 2 hard line, so hopefully that will provide plenty of headroom.
It would be nice to be able to run E85 at the 500-600 whp level with one pump and a voltage booster...
Old Dec 1, 2010 | 03:04 PM
zmedic16's Avatar
zmedic16
i wonder how well would this work with a stage 0 fuel return.
Old Dec 1, 2010 | 05:38 PM
y0shi's Avatar
y0shi
if its quieter, then its worth it!
Old Dec 1, 2010 | 06:18 PM
Quamen's Avatar
Quamen
If it is true I will be getting two for my fuel cell at that price!
Old Dec 2, 2010 | 05:25 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Ill take 2 and a Kenne Belle boost a pump please
Old Dec 2, 2010 | 09:20 AM
str8dum1's Avatar
str8dum1
if only it was that easy
they dont fit in the dual pump setup sold by CJM.....
so you'll have to take the SP hanger, 2 pumps, and then the BAP, plus -10AN feed and a new EMS to stage the pumps, or a -8AN return with a bigger FPR
Old Dec 2, 2010 | 10:20 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the thread title is a bit of a misnomer though
a 385 lph pump (at what voltage?) is fine...if you need it
if you don't need it, it's utterly useless, and like many new products, particularly a fuel pump, you may be well served to wait and see what reliability is like before taking a plunge vs a known commodity
the only real way to know is how you guys are doing it...datalogs, to see where you start running out (and what is causing it..injector or pump). It's going to be different for everyone based on a number of different factors
Old Dec 2, 2010 | 10:51 AM
str8dum1's Avatar
str8dum1
this is the FI forum, so anyone on here would benefit from a bigger intank.
but ya, not much additional info, so prudent to wait and see. But regardless at worse its a 255L.
Old Dec 2, 2010 | 11:38 AM
binder's Avatar
binder
interesting....
when we started having the rise in a/f ratios no matter how much fuel hal put in he had me watch my fuel pressure gauge while he did a pull. Promptly at 7500 rpms the pressure would drop from the 60's (boost reference) to below 20. It would almost bottom the gauge out.
And also, based on calculations 600 cc injectors will be maxed before a walbro pump.
Originally Posted by binder
math real quick:
800cc injectors x 6 = 4800cc or 4.8 liter/min. x 60 minutes in an hour = 288 liters in an hour
walbro= 255 liter/hour
a single walbro falls short of 800cc injectors by 33 liters per hour so if He has a bad pump he would run out.
6 600cc injectors only flow 216 liter/hour therefore the walbro will flow more than the 600cc injectors.
Old Dec 2, 2010 | 12:58 PM
str8dum1's Avatar
str8dum1
If you FP was dropping then your calculations dont really show that.
I only ran to 6600 rpms to make 460 so thats probably why I didnt appear to be outta pump only injector.
Old Dec 2, 2010 | 01:44 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Guess you missed my comment in ashtons thread? The flow rating drops as pressure increases. 255lph is best case.....it only gets worse from there. Your assumption that the walbro will flow more than the 600cc injectors may be incorrect for the actual pressures being used.
Also remember injectors are rated at a certain pressure too. If you increase the pressure at an injector then the cc rating should increase as well.
Old Dec 2, 2010 | 02:12 PM
  #38
str8dum1's Avatar
str8dum1
for reference, here's flow charts. i figured it was widely known that walbros dont do well at high pressures compared to like the bosch 044
6 600s outflow the pump right around 60psi at nominal car voltage. pretty much what you experienced.
Old Dec 2, 2010 | 06:52 PM
  #39
Zivman's Avatar
Zivman
well, got some info on the PT342 from JayRacing.
My evo went in for a tune today and I just heard from my tuner. Ran out of pump about the same level as a 255.
28 psi on an FP Red on E85 428 hp on a dyno dynamics
Old Dec 2, 2010 | 09:17 PM
  #40
Blackbird CPV35
Maybe ill just stick to the 2x255 with a BAP running on a pressure switch, that sounds too complicated
