no reason to buy a Walbro 255L anymore
Old Dec 15, 2010 | 07:40 PM
  #61
ashtrojan2008's Avatar
ashtrojan2008
Originally Posted by binder
oh, so those are like 800 LPH pumps. would the walbro intake supply the surge tank fast enough for that thing to keep up?
that's the point of the sump, so you can get rid of the in tank single walbro. no feeder pump, the large pump draws right out of the sump.
ross
Old Dec 16, 2010 | 06:48 AM
  #62
str8dum1's Avatar
str8dum1
supra guys just tap the bottom of their fuel tank, thats all we'd have to do. You'd keep the buckets, so your fuel level senders wouldnt be affected and you'd return the fuel back thru the bucket as well, just like it is now.
Old Dec 16, 2010 | 06:58 AM
  #63
binder's Avatar
binder
interesting.
sounds like a good setup. Wonder why nobody put effort into that? Couldn't they use the second tank top and make an adapter so you wouldn't have to tap the tank? That way it's a bolt in piece.
Old Dec 16, 2010 | 07:03 AM
  #64
midz350's Avatar
midz350
BUT, that would mean sucking the sludge and filth in the tank
Old Dec 16, 2010 | 07:04 AM
  #65
str8dum1's Avatar
str8dum1
you could do that as well i think. Obviously someone like Phunk would have a better idea on how this could be done.
theres just little interest as a community to go with that kinda fuel system. twin pumps are enough for 99% of the cars on here.
just a FYI, the driver and passenger baskets use the exact same fuel float. SO you could make an easy triple pump setup by just using the stock basket with a 250LL and attach the fuel sender to that. That way you'd be pumping out of both sides of the tank.
Old Dec 17, 2010 | 01:55 PM
  #66
Chris@DW's Avatar
Chris@DW
Should have some nice tech info about our new pump to post early next week. We've gathered some good data this week and should have some time over the weekend to put it together.
Old Dec 17, 2010 | 03:42 PM
  #67
Chris@DW's Avatar
Chris@DW
Here's a bit from the first round...
Old Dec 17, 2010 | 04:23 PM
  #68
djamps's Avatar
djamps
Hmmm me likey... for those who are stock block FI and want to run E85 without twin pumps (me!)
Old Dec 17, 2010 | 04:40 PM
  #69
phunk's Avatar
phunk
CJ Motorsports
DeatschWerks: How many different models/applications of your pump are you planning? please contact me at the number in my signature if you have any spare time, id like to see if you have one on the way that will be compatible with our twin pump assembly.
Old Dec 18, 2010 | 02:28 AM
  #70
midz350's Avatar
midz350
So, what is the WHP limit with this new pump in our cars?
Old Dec 18, 2010 | 08:14 AM
  #71
str8dum1's Avatar
str8dum1
maybe 50 whp more. still in the 600 range
Old Dec 20, 2010 | 09:40 AM
  #72
str8dum1's Avatar
str8dum1
flow chart now listed for the Jay racing pump
http://www.jayracing.com/index.php?m...oducts_id=2619
Old Dec 28, 2010 | 12:40 PM
  #73
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Question
BUMP
Any update on this?
Old Dec 28, 2010 | 01:00 PM
  #74
Chris@DW's Avatar
Chris@DW
Right now, the DW301 is going to be the workhorse.
I can see us possibly doing other fitments and lines in the future, but for now we want to focus on getting DW301 off the ground and established.
Thanks for the question.
-Chris
Old Dec 28, 2010 | 01:19 PM
  #75
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by RudeG_v2.0
BUMP
Any update on this?
Hello, Just wanted to let you know I got your voicemail!!
DW and I did get in touch last week. For now, there will not be a DW pump that is compatible with our twin pump. I believe they are considering the application that our twin pump requires, but havent moved on it yet. We will see what the future holds!
Old Dec 28, 2010 | 01:28 PM
  #76
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Bummer that we'll have to wait a while for that.
A CJM twin pump assembly upgraded with either a version of the DW301 or new Walbro 325lph pump would be an attractive option for those of us trying to push 700+whp on E85.
Old Dec 28, 2010 | 01:34 PM
  #77
phunk's Avatar
phunk
CJ Motorsports
Well, in terms of 700, I think you are no problem... I *think* you should be able to run just over 800rwhp on e85 with it as is
Old Dec 28, 2010 | 01:38 PM
  #78
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Cool! That's significantly more than I expected!
Old Dec 28, 2010 | 01:41 PM
  #79
phunk's Avatar
phunk
CJ Motorsports
well, i suppose it depends on the dyno type. but I would be insanely shocked to see our twin pump as it stands run out before well into the high 700s rwhp on a dynojet... but without having done it, i cant say for sure.
Old Dec 28, 2010 | 02:21 PM
  #80
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
ProEFI uses a Dynojet and I still plan on doing a C16 tune too. So I should be fine... for now.
