no reason to buy a Walbro 255L anymore
Old Dec 1, 2010 | 04:10 AM
str8dum1's Avatar
str8dum1
Default no reason to buy a Walbro 255L anymore
Buy this instead
http://www.euroexportinc.com/store/a...fuel-pump.html
Probably the same pump that Deatchwerks is rebadging.
Old Dec 1, 2010 | 04:39 AM
Frosty87's Avatar
Frosty87
Too late ordered walbro last week lol
Old Dec 1, 2010 | 04:58 AM
GreenGoblin's Avatar
GreenGoblin
Nice find Rich
Old Dec 1, 2010 | 06:20 AM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Nice find. This will be a good option for the 6765 (along with 750cc injectors) for those looking at maxing out a stage 1 block.
Now I have to look in to this..thanks for sharing.
Old Dec 1, 2010 | 06:29 AM
Sodero's Avatar
Sodero
Thank you! This was perfect timing.
Old Dec 1, 2010 | 06:39 AM
konrad's Avatar
konrad
so approximately how much power would this be able to support over the 255
Old Dec 1, 2010 | 06:55 AM
Vas_Z33's Avatar
Vas_Z33
i wonder how much power can one of those handle
Old Dec 1, 2010 | 07:00 AM
Boosted Performance
Well, it's 385lph pump. This would be about 35% more than the 255lph pump. I would guess (since we know the 255 is maxed out at 550whp on a DJ) that this pump should do about 700whp.
Hence my post about maxing out a Stage 1 blocks .
Old Dec 1, 2010 | 07:04 AM
ashtrojan2008's Avatar
ashtrojan2008
hmmm... makes me want to swap out my 255. nice find Rich
Ross
Old Dec 1, 2010 | 07:21 AM
Vas_Z33's Avatar
Vas_Z33
sickness.
Old Dec 1, 2010 | 07:25 AM
thatv35guy's Avatar
thatv35guy
Nice! Won’t need two fuel pumps to make 600whp.
Old Dec 1, 2010 | 07:45 AM
Boosted Performance
From my pump supplier:
" Walbro does not make a 385 lph pump, I just got off the phone with Walbro and they are working on a 325lph pump but it will not be available as a pump by itself until Late March"
So, it sounds like a mistake was made on that site.
Even at 325lph, it would still be good (in theory) for mid 600whp.
Old Dec 1, 2010 | 08:01 AM
thatv35guy's Avatar
thatv35guy
Awww, that’s a bummer…the 325 fuel pump their working on, in theory how much whp would that support on E85?
Old Dec 1, 2010 | 08:44 AM
Vas_Z33's Avatar
Vas_Z33
bahhhh =((
Old Dec 1, 2010 | 08:53 AM
rcdash's Avatar
rcdash
I called the seller and he says it exists and it's made for a Chevy Typhoon truck. I asked for a Walbro part number and he said to call him back tomorrow and he'd have it ready.
Old Dec 1, 2010 | 09:04 AM
GoJira33's Avatar
GoJira33
NICE
Old Dec 1, 2010 | 09:42 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I don't think this is a Walbro pump. DW has a prototype in the works that we're about to test for them. Stayed tuned.
Also keep in mind, these very high flow pumps should only be used with return fuel systems, until someone tests base fuel pressure with the OEM returnless assembly. That little hole that is drilled into the OEM FPR will likely have to be larger, in order to maintain a reasonable base fuel pressure.
Old Dec 1, 2010 | 09:49 AM
PV350Z's Avatar
PV350Z
bummer
Old Dec 1, 2010 | 10:05 AM
thatv35guy's Avatar
thatv35guy
Looks like someone bought it already: http://starcityracing.com/Forums/showthread.php?t=37276
Edit: Their post with pictures is about half way down.
Old Dec 1, 2010 | 10:21 AM
str8dum1's Avatar
str8dum1
Ya other platforms are already investigating this pump. I also read that it uses much bigger fuel connections compared to the 255. Also read that its the pump used in supercharged LS9 applications. Although it does seem to be stamped with the standard GSS341
The DW pump will be priced similiar (~$175) and flow similar to the bosch 044. If that walbro is shown to flow 385l at 110$ its a no brainer. The supra and DSM guys are on it and they try new things, so it wont be long til more info is available.
I just wouldnt buy a 255L until then if you have a built motor and return system
