My Vortech Supercharged 350Z Dyno
Took my lady to the dyno and done some fine tunning to it using pump gas (91oct) + water/meth (50/50). Managed to get 455whp/355wtq
http://www.youtube.com/watch?v=3OpM5Bn5YyU
http://sphotos.ak.fbcdn.net/hphotos-..._5390695_n.jpg
Special thanks going out to:
Hosam Al Taib (MC Performance)
Kyle Puckett (Import Parts Pro)
Ebraim Bin Hashir (Bin Hashir Motorsport)
Salman Mahmood (Drift King)
Ali Moosa (Master Exhaust)
Ebrahim Al Qattan (M&M Dyno)
another fine example of solid USABLE power from a vortech!but umm, i'd be concern how on your AFR on water/meth into the higher rpms! Thats a good way to make a dyno queen #, which might have been the case. But I would not run that tune on the street!!! That engine failure all over it!!!
We managed to sustain it @ 11.9-12:1 the whole WOT using the Fcon's AFR/knock amplifier.
Running a low compression engine 8.5:1 & 800cc dw injectors.
When I came to build this engine, I wanted a safe setup for pump gas to be run on tracks (road racing) givin that we have a crappy 91oct pump gas
Another thing, I also wanted a setup that could (when I can afford) handle 600whp twins that might get fixed in the future
I got ya what kind of set up are you running 2.87 on the stock blower?
2.87 pulley. However, I have sent my SC for a rebuild due to a seal issue and had the impeller changed to give 2~3psi more. The dyno run was at 15psi.
Trying to remember the name of the shop that buil my blower. Was a couple of years ago. Will post it once I find it
I guess I could gain more HP with race gas at the same setup with a bit more timing.
Looking at my torque level and HP, this amount of power is very drivable and fun on a fairlady
Walbro 255, CJ stage 2 fuel system, deachwerks 800cc injectors controlled by an HKS Fcon along with the HKS AFR/knock amplifier. Tunned by Hosam Al Taib from MCC Performance.
Using a snow performance meth kit running the second nozzle with 50/50 water/meth ratio and 91oct pump gas
SC rebuild was done using an ABEC 7 kit with a $179 SC impeller upgrade at www.superchargerrebuild.com
