Most HP made with stock headers
look at the difference in fuel during spool up between red and blue graphs. The red graph is 12.0 afr @ 2200 rpm while the blue graph shows not touching 12.0afr till 4000 rpm. Im not a tuner or a guru but that to me seems like a considerable factor in spool that should be adressed when comparing the two. I dont know what it means but maybe u tuners can enlighten us.
Bryan, that's a nice looking collector - what is the outlet diameter? For a cross sectional area provided by 1.75" tubing x 3, an outlet of 3" would seem optimal just crunching the #s but that seems like overkill preturbo and would probably hurt velocity. Also I would think that smaller diameter tubing would increase velocity and spool but decrease top end. So not sure how increased spool with your headers would equate to top end flow. Perhaps it's more a matter of equal length tubing more evenly spacing out pulses that is contributing to the earlier spool. Thinking in terms of pulses is another reason perhaps a 3" outlet is suboptimal. Would love to hear your thoughts on the design decisions that went into the headers - really a sweet looking piece.
You don't need the fuel until you've got the air - look at the boost curves.
I'm not the guy who designed them, but there was a lot of CFD analysis that went into the design, I'll get that data from R&D at a decent hour tomorrow and post it up
the collector outlet diameter would not need to match the area of all three primary tubes because only one cylinder is firing at a time on each bank. i would want the outlet diameter to match whatever hfc/test pipe i had to keep turbulence minimized and velocity up. well, i should say that in reverse, i would want the hfc/test pipe diameter to match the collector outlet diameter i guess. all imo tho.
edit, previous post wasnt there when i typed this. that outlet diameter is perfect considering most hfc and test pipes use that 2.25". how much are these headers? pm me please if necessary to stay on topic. great thread
agreed, should be equal tunes to be apples to apples
i wonder if it would be worth a shot to cut up the stock manifolds, work the inside of them to get everything open and smooth, then weld them back together..... sounds ghetto, but if it works, i prefer oem looking parts anyway
Vendor - Former Vendor
WHAT?
With the number of header brands out there why would you do that?
It would cost yo more to get the OEM headers cut/gutted/welded than a decent aftermarket header, and you would still be left with a shi..ty OEM header that has now been welded.
Here is your cut up OEM header:
8" long section of this:
You can see how long that 1.5" section is:
yes, you are right, i was thinking that collector was closer to 2" with the outside material. im out of town now so i cant go out in my garage and look at the ones sitting there. but looking at the pictures, it seems that even if a guy was able to clean out that long collector, the part where the primaries merge does NOT look like a good arrangement to promote scavenging anyway. i fail
I fail often too.
cool, so now thats its been beaten to death, how about someone actually get this kit installed properly with all the necessary add-ons and make some good numbers
There are supras to clown
I believe that this kit is capable of some very good numbers with the 67mm turbo.
still no tuners explained the diff in fuel graphs. comparing a 8 psi to a 10 psi seems dumb, then add the fact that one is a complete tune and the other is a bolt on and hit the gas tune makes it a even more usless comparison. sorry.
people have open minds here, and use them, as witnessed with multiple products, kits, companies, etc. that all had great success and followings. this outside the box thinking, when used well, will produce successful results, as witnessed with momentum and boosted performance. but what you stated made almost no sense. now go with the outside the box thinking, and work on developing a header kit that produces numbers, and market them. we always could use a wider selection of parts.
i do'nt think there is a supporting mod left to put on my car (that would alter engine performance)
BP - Since your ST bolts up to the factory manifold, wouldn't it be pretty simple to put on a set of DC or any short style headers and test the hypothesis? If you see hp gains at higher rpm, then that pretty much proves the restriction.
In the mean time, I am looking at headers, clutch, and a larger FMIC, although a 7” and 9” core will be tested for thermal efficiency.
