3.5 VS 3.3 Final Drive
Old Feb 8, 2011 | 03:21 AM
rh_334's Avatar
rh_334
Originally Posted by ashtrojan2008
Awesome! But wasn't Alberto's and others' cruise control not working after the swap? Supposedly it was the mph not agreeing with the expected rpm. Is there a Difference between the g and the z? I really have got to find out because if so I'll be in the market for a 3.3.
To my knowledge the cruise and VDC (if equipped) are identical. Not sure why theirs wouldn't be working. I used mine for almost 40 miles with no problems, and i would think that the ECU is supposed to work with either since 5ats come with the 3.3 stock.
Old Feb 8, 2011 | 05:00 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Your CC will not work in 6th gear, but if you choose to use 5th it will. VDC will be normal as long as the tire differences are in spec.
People need to stop comparing a Z's time to a G35's time. And dont mention the "rule" of 100lbs = only .1 of a second because Ive found its more than that.
Old Feb 8, 2011 | 05:06 AM
rh_334's Avatar
rh_334
Interesting, mine is working in 6th... i cruised ~40miles in 6th gear and thats when that last pic was taken... Maybe a year difference? or maybe im just lucky that mine works?
Old Feb 8, 2011 | 05:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I dunno if the tire size has anything to do with it. Mine wouldnt work with a 285/35/19 rear, maybe it does now that I run a 295/35/19??
Old Feb 8, 2011 | 05:11 AM
rh_334's Avatar
rh_334
Hm, i don't know, update us with the results. I'm going to drive mine again try it at different speeds, but i know for a fact that it worked at 80mph.
edit: im not sure that it makes a difference but i run a 255/35/19 front
Old Feb 8, 2011 | 05:31 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Thats what I used to run in the front, now I run a 275/35
Old Feb 8, 2011 | 06:16 AM
ashtrojan2008's Avatar
ashtrojan2008
tire size shouldn't affect the fd/cruise issue, if the cruise was working before with that tire combo. But if you find anything out Alberto, let us know.
Old Feb 8, 2011 | 06:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Mine has never worked in 6th gear, you read that correctly looooong ago when I posted it, good memory.
I hardly drive my $hitbox, so I wont be able to try it with the new tires anytime soon.
Next time I drive it, I may put on a helmet and park it into a fawking wall, godd@mn love/hate with this fawking car its sick.
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
