I have been gone awhile, but I'm back....
Old Feb 11, 2011 | 04:31 PM
thawk408's Avatar
thawk408
Default I have been gone awhile, but I'm back....
Here is the new story on my car. Previously was a built motor greddy car with basicly just pistons and rods, put down 522@19psi on a DD. It was a blast to drive, but the HP bug bit me hard (damn bug!), so I contacted a local shop (Carma Performance in Nashville, TN) to help me get a "big twin" kit rolling.
We started the kit off with just a pair of SFR manifolds, that ended up having to be modified considerably to fit the bigger V-band exhaust housings. Everything else was fabricated in house by Erin@Carma. Final number is a safe 725rwhp@24psi on a DD using E85. We made a 800rwhp@26ish psi pass, but the injectors were simply maxed out on E85, so we backed it down some to keep the injectors in safe territory. I might push it more later with bigger injectors. E85 is pretty awesome, and with 2 pumps next to my house, its an obvious choice for fuel.
It has been a long road, but it is finally done. Here are the specs:
2005 Track with 26k on it.
Turbo kit:
Carma low mount twin kit
Twin precision billet 6062s, .63 V-band exhaust housings
5" thick intercooler
3" downpipes to 3" dual exhaust
38mm V-band Tial wastegates dumped
50mm Tial BOV
All piping is black powder coated
Coated hot sides
Engine:
CP pistons
Eagle rods
ACL race bearings
L19 Studs
HR headgasket
ARP mains
IP girdle
JWT C8R cams
JWT springs
Fully balanced
Crawford cast plenum
Koyo rad
Computer:
Flashed ECU
Haltech with 3.5 bar sensor
Boost solenoid
Innovate sensor wire into haltech for datalogging
Fuel:
120lb injectors
SP triple hanger
-10 feed -6 return
Altered rails
2 pumps run all the time, 3rd kicks in at 15psi
Drivetrain:
3.3 rear end
IP solid engine mounts
Solid diff mounts
Clutchmasters fx700 with twin iron disk
Update:
Here is a link for more pictures of the car. Once you select a picture, click it again for a bigger view.
http://www.flickr.com/photos/defcon8...7626270068820/
The car was shot by Chad Lunn from www.chadlunnphotography.com. He took LOTS of pictures and they will put up slowly once he is done checking them over. Check back for more pictures.
Here are some various pictures throughout the entire build. The tac signal was being weird, so no HPxRPM at this time. We are reving the car to 8k. I'm sure I am forgetting something, but this is the gist of things.
Old Feb 11, 2011 | 04:38 PM
GreenGoblin's Avatar
GreenGoblin
great stuff. Glad to see something not the run of the mill.
Old Feb 11, 2011 | 04:39 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Sick i wish E85 was available around here, but the starving kids in Africa are probably glad it is not
thawk408's Avatar
thawk408
I could of bought an SP kit and saved some head ache, but at the start of this project we were trying to use the Bullseye Power s262's. After fighting with the turbos to get them to fit, we scratched that idea and went with the tried and true Precisions.
Old Feb 11, 2011 | 05:00 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
NICE! Congrats!
What injectors do you currently have?
Old Feb 11, 2011 | 05:02 PM
Sylvan Lake V35
Originally Posted by RudeG_v2.0
NICE! Congrats!
I am curious as well I had to convert 120# to 1260cc, more info would be nice though
Old Feb 11, 2011 | 05:05 PM
thawk408's Avatar
thawk408
NICE! Congrats!
Thanks .
I bought the injectors awhile ago before I knew about the ID 2000s, or I would of gone with those. We flowed these, for the hell of it, and they all flowed insane. They looked like a water hose.
http://eficomponents.com/index.php?m...rpp5mpcb9fv5o7
Old Feb 11, 2011 | 05:40 PM
Russ@Z1's Avatar
Russ@Z1
The Z is awesome. Congrats!
Old Feb 11, 2011 | 05:49 PM
rcdash's Avatar
rcdash
Congrats - great power! Can you put some words to the driving experience before vs after this latest incarnation?
Old Feb 11, 2011 | 06:42 PM
thawk408's Avatar
thawk408
The car feels like a completely different animial. Lag is not as bad as I thought it would be, and the car physically feels more machine like (maybe from the solid mounts?). If that makes sense. The clutch is very tricky, but is manageable. Oh and then the way it sounds . Reminds me of a jet engine coming online.
I will get some videos here in the next week.
Old Feb 11, 2011 | 07:07 PM
NNOCENT's Avatar
NNOCENT
sick build!
you must have some deep pockets, what line of work are you in?
tig488's Avatar
tig488
glad to see you back and the car looks great. much props for a badass build.
Old Feb 11, 2011 | 07:23 PM
BornSlippyZ's Avatar
BornSlippyZ
Nice looking build!
Old Feb 11, 2011 | 07:50 PM
OldManZ350's Avatar
OldManZ350
Nice.....
Old Feb 11, 2011 | 08:39 PM
seymore4's Avatar
seymore4
Professional
filthy
Old Feb 11, 2011 | 08:51 PM
graffkid732's Avatar
graffkid732
Great build. In for vids.
Old Feb 11, 2011 | 09:37 PM
Augustus46's Avatar
Augustus46
That is frickin's awesome! May I ask how much you're into it?
Old Feb 12, 2011 | 01:03 AM
snobes's Avatar
snobes
700-800hp is quite high for the eagle rods, was the short block carried over from the previous build?
Old Feb 12, 2011 | 01:11 AM
Boostguru's Avatar
Boostguru
+1 for vids
Awesome build, congrats! What tires are those? Look like NT05's but my eyes could be playing tricks on me.
Old Feb 12, 2011 | 03:33 AM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
sick build!!!
