Swapping Transmission's
Old Apr 5, 2011 | 03:38 PM
Turbo13's Avatar
Turbo13
Default Swapping Transmission's
Have an 05 touring auto, Wife's Car, which I will now be driving. I like the car but really want to boost it. My worry is the automatic transmission will not be up to the challenge and also really would prefer a 6 speed. Would it be possible to swap a 6 speed in my car, anybody done it? Thanks
Old Apr 5, 2011 | 04:18 PM
optimus350z's Avatar
optimus350z
Its been done on here but very costly
Old Apr 5, 2011 | 04:22 PM
NoQuestionZ's Avatar
NoQuestionZ
Transmissions isn't showing ownership.
I would suggest getting a different car with what you want ie MT-then boost that
Old Apr 5, 2011 | 05:03 PM
Turbo13's Avatar
Turbo13
Anyone built the automatic? What are it's limits in stock form?
Old Apr 5, 2011 | 05:12 PM
pmab9918's Avatar
pmab9918
Transgo I believe is a must if you are going fi on an auto
Old Apr 5, 2011 | 05:17 PM
Turbo13's Avatar
Turbo13
What is transgo?
Old Apr 5, 2011 | 05:19 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Best advise is to trade in wifey's car for a 6MT. Conversions are cost prohibitive and unnecessary since you haven't started the mod process. Hope that helps.
Old Apr 5, 2011 | 06:52 PM
drivessidewayz's Avatar
drivessidewayz
^^ Less money and less headaches. Also search; it will answer all of your questions and more.
Old Apr 5, 2011 | 11:51 PM
bbs350z's Avatar
bbs350z
i suggest the above said as well but if your deadset on this, youd need
mt trans/clutch/flywheel, all cylinders etc.
mt wiring harness
mt ecu
clutch line
mt pedal set
mt console trim piece (shiter area only)
mt driveshaft
mt gauge cluster (optional)
labor to do the job
*and if you notice under the shifter trim* is the trans tunnel, the auto has a different configuration, so you would have to cut out the old one and put in the mt version of it.
all in all, while its stock, trade it in for similar year mileage trim etc.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
