spark plug qustion
Old May 25, 2011 | 10:51 PM
350z-900whp's Avatar
350z-900whp
Default spark plug qustion
So I wanted to change my spark plugs and I found plfr5a spark plugs in ! Isn't that the stock spark plug code ?
Now I bought iridium lfr6aix11 would it be same gap ? And what is the gap 40 ?
Old May 25, 2011 | 11:43 PM
tony530's Avatar
tony530
Old May 26, 2011 | 05:59 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Be real carefull when gapping them as they are easy to damage the electrode.
Old May 26, 2011 | 07:50 PM
binder's Avatar
binder
.044 for FI?
i would gap them down to .035 or even .030 depending how much boost you are running.
Old May 26, 2011 | 08:02 PM
str8dum1's Avatar
str8dum1
like mentioned, general rule is to not touch the gap on iridium plugs. i run the stock gap on my 2 step colder iridiums
Old May 26, 2011 | 08:12 PM
binder's Avatar
binder
did you upgrade your ignition system? i would almost expect blow out at your level of boost pressure with that huge gap
Old May 26, 2011 | 10:30 PM
ddc665350ztt's Avatar
ddc665350ztt
well i just get the one step colder iridiums for my z. i dont gap, just throw um in. i should double check though.
Old May 27, 2011 | 04:06 AM
midz350's Avatar
midz350
NGK Laser Platinum Spark Plugs
by NGK
Item#:
PLFR5A-11, 6240
Only Fits: 03-06; Gap .044 * OEM Heat-Range Number *
http://www.customcarscentral.com/ngk...ssan-350z.html
Old May 27, 2011 | 06:49 AM
str8dum1's Avatar
str8dum1
general consensus is to not use platinums on FI cuz you have higher chance of blowout due to the fact that the tip surfaces of a platinum spark plug is not large enough to make a good conductor in a rich, super high compression environment.
Old May 27, 2011 | 08:45 AM
binder's Avatar
binder
I use cheap coppers and gap them down to .030
I had misfires that wouldn't go away until the gap was down that far. Could just b my car though.
Old May 27, 2011 | 09:54 AM
str8dum1's Avatar
str8dum1
i'd use coppers but they dont make them in 2 step colder
Old May 27, 2011 | 04:02 PM
binder's Avatar
binder
that must be rough for you: "i have 1000hp but those bastards don't make 2 step colder copper plugs"
Old May 27, 2011 | 04:26 PM
winNvegas's Avatar
winNvegas
Binder --> random misfires? thats what im getting and im due for smog check soon. was wondering if a change in sparkplugs would help the cel go away.
Old May 27, 2011 | 06:39 PM
binder's Avatar
binder
not the CEL for random misfires. It was spark blowout but it didn't trip a code.
check out your plugs to see if they are worn or the gap is really large. it doesn't sound like the same issue though.
Old May 30, 2011 | 03:13 PM
tony530's Avatar
tony530
.044 is oem gap spec and the copper ain't the oem starndard for nissan!! Iridium or platinum is oem don't remeber which is??? I used the copper and in two year they open up to .050 and got fouled up mostly all of the sparks plugs! It's your car gap them where ever u want?? I'm just letting u know!!
Old May 30, 2011 | 09:44 PM
Honda2Nismo's Avatar
Honda2Nismo
FI isn't oem either..
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
