Z Down.. Read to help diagnose...
Old Jun 23, 2011 | 05:02 PM
k6750gsxr's Avatar
k6750gsxr
Default Z Down.. Read to help diagnose...
Background on car.
2004 350z 5at
Built Long Block
Twin GT30r's
Osiris/Utec EMU
I was driving the other day doing around 45mph when my car suddenly starts to stuttered and just shut off. I managed to get it pulled on to a small side street. I then tried to crank the car again. Car turned over but sounded as if it was only firing on 3 cylinders.. it had a distinct miss to it but not mechanical sounding issues of any sort. ( bearing noise or rod noise ). It is at my shop right now I have not had a chance to diagnose the problem. Here is a list of what I think it maybe....
No codes were thrown. I hooked my cipher cable to it and no codes were listed...
1. Im thinking it may be the crank sensor ?
2. My utec took a crap on me. ( I have osiris on the bottom with a base tune so I can check the utec by unplugging it and letting ecu run the car alone )
3. Timing chain Tension broke ?
I will be working on it either tomorrow or through out the week end, so if any one has any advice I am all ears. I will also keep updates on here of what I find while looking.
Thanks in advance to any of you that help.
Old Jun 23, 2011 | 05:54 PM
djamps's Avatar
djamps
Check your coil packs for the tell-tail melted bubble near the connector. UTEC has a tendency to blow coil packs.
Old Jun 23, 2011 | 06:04 PM
k6750gsxr's Avatar
k6750gsxr
I have changed out all coil packs with ones from another z that runs. Still has miss fire.
Old Jun 23, 2011 | 06:52 PM
str8dum1's Avatar
str8dum1
but it runs now?
does your CEL blink? no codes is not good. your reflash doesnt have them shut off does it? a bad crank sensor would pop a code.
i assume you aready pulled and examined all your spark plugs? no crap in the radiator fluid?
Old Jun 23, 2011 | 07:05 PM
djamps's Avatar
djamps
+1 I didn't see he had no codes... when I lost a single pack I got two misfire codes almost instantly. I keep saying this I sound like a broken record... check all your engine grounds make sure they are tight especially the two at the front on the timing cover. Make sure UTEC is grounded (black wire to ground). Lastly, make sure no water is leaking through the main boot onto either EMU.
Old Jun 23, 2011 | 11:50 PM
k6750gsxr's Avatar
k6750gsxr
Originally Posted by str8dum1
but it runs now?
Car will crank but idles rough and wants to shut off if no throttle is given. My osiris rom does not have the codes turned off. Nothing on dash as if the car is running fine.
I have only been able to check 3 plugs so far. All on the driver side. I will tackle the passenger side if needed tomorrow. Plugs look find. The top of the pistons look ok as well. No signs of steamed piston from lifted head gasket. Have not checked the actual rad fluid yet, but that is something else to add to the list tomorrow if my first ideas fail.
Checked all grounds first thing along with fuses just for peace of mind. I am going to check the ecu and emu tomorrow to make sure all grounds are still secure. I am seriously leaning towards utec going bad. I have diagnosed a utec going bad in the past on a different car. This is acting the same way. Fortunately i have a base rom on the osiris so the car will start and run if utec is not connected.
Thanks for all the help so far. I will let every one know as I continue. Hoping for easy solution but when it comes to this car there are never easy solutions....
Old Jun 24, 2011 | 06:39 PM
str8dum1's Avatar
str8dum1
your MAF sensor is plugged in properly and clean?
Old Jun 24, 2011 | 07:20 PM
rcdash's Avatar
rcdash
Was it raining when the problem started? I favor UTEC also...
Old Jun 24, 2011 | 08:54 PM
k6750gsxr's Avatar
k6750gsxr
Update...... had some spare time today. Took the utec out and plugged in ecu alone. Problem still there. Car will crank for 15 secs or so before shutting off. Car sounds like its only running on 3 cylinders.
Tomorrow I will replace crank sensor with a spare I have.
Old Jun 25, 2011 | 06:01 PM
k6750gsxr's Avatar
k6750gsxr
Ok so today I put the car on the lift and found this ....
Needless to say i cut the plug off and re connected it to another plug I had from a spare harness along with a new crank sensor. After that I then tried to crank the car. Now the car will not crank at all. It back fires really bad on start up.
No I feel that the plug fried my ECU ? Any one else think this ?
New question is I have a spare 04.5 manual transmission with osiris on it for my 6mt conversion I was going to do. Can I plug that ecu and try to start the car ? or will the fact its a 6mt ecu make it not work ?
Any advice would be good right about now.
Old Jun 25, 2011 | 10:42 PM
phunk's Avatar
phunk
CJ Motorsports
doesnt make sense. you should have got a crank trigger code. and aside from that, the car will run decent with no crank trigger, it will take longer to start while it looks for the signal and then default to run off cam triggers alone and give a check engine light. i could see that perhaps with the UTEC it might not do that as the UTEC is most likely intercepting the crank trigger signal and manipulating it, and the UTEC might not be able to run without it... but on stock ECU only i dont get it.
Old Jun 27, 2011 | 05:18 AM
k6750gsxr's Avatar
k6750gsxr
Update. I will be switching out ecu today at some point. Hope that fixes the problem. From what I have read seems to be a good bet.
Old Jun 27, 2011 | 07:46 AM
psychoballistic's Avatar
psychoballistic
Are you hearing any other abnormal noises form the engine as well? ticking, slapping, anything of the sort? You'll get the backfire if the cylinders aren't firing properly and fuel is being dumped into the exhaust.
Old Jun 27, 2011 | 09:50 AM
k6750gsxr's Avatar
k6750gsxr
This is correct. There are no abnormal noises at all.
About to change out the ECU now. Is there anything that I might be able to cipher ? to see whats going on...
Old Jun 27, 2011 | 10:10 AM
redline06's Avatar
redline06
compression test?
Old Jun 30, 2011 | 08:54 PM
k6750gsxr's Avatar
k6750gsxr
Waiting for jared from uprev to email me the Rom file so i can load my Rom on the new ecu i got.... So still no real results.
Old Jul 1, 2011 | 05:40 AM
djamps's Avatar
djamps
Good chance something fried in your ECU since it looks like all three wires on that harness got shorted to ground.
Old Jul 1, 2011 | 05:48 AM
k6750gsxr's Avatar
k6750gsxr
That's what i am thinking but when i called uprev and spoke with Roger? he said it was unlikely that the sensor fried the ecu. Which i think is bs due.
Old Jul 1, 2011 | 12:57 PM
nismonian's Avatar
nismonian
it needs more WIN.
Old Jul 1, 2011 | 02:51 PM
superchargedg's Avatar
superchargedg
Damn Noobs
That was a lotta help^^^
