Trying to reach goal got questions.
Old Jun 28, 2011 | 12:25 AM
brocw1093's Avatar
brocw1093
Default Trying to reach goal got questions.
So I just got my vortech kit installed and I want to reach my goal of 400whp. Iv been doing research and a bigger fuel system and the 3.12 pulley seem like a good idea. I was looking into 440cc injectors. But if I were to get these injectors do I need different fuel rails? Or can I just go with the injectors?I also know I'm going to need a good tune but will I need a different box other than the piggy back vortech came with? I'm sorry if these questions are stupid but it's my first car I have ever done this to and started having fun with. Thanks for any info
Old Jun 28, 2011 | 05:14 AM
Dan@Assaultech's Avatar
Dan@Assaultech
Hey easiest to just give me a shout.
For 400whp, you will want a number of things
1) 3.12 Pulley (& belt)
2) Fuel Pump (Walbro 255)
3) Injectors (DW 600cc, 440cc would be near maxed out and have to run to hard)
4) Clutch/Flywheel if you don't already have 1
5) Koyo Radiator to supply proper cooling for the setup
6) Oil cooler would also be ideal to provide enough cooling
7) Gauges to monitor your car, A/F, Boost & Oil Temp are most important
As far as the tune, you can reflash the box your Vortech came with, just need to find a shop that is able to do so. Please give me a call and we can get you setup with everything and would be happy to answer any other questions you have.
Thanks
Danny
(205)588-0960
AIM: AssaultechDan
www.assaultech.com
Like Us on Facebook
http://www.facebook.com/AssaultechPerformance
Old Jun 28, 2011 | 07:13 AM
DaveJackson's Avatar
DaveJackson
Master
These sound like Forced Induction questions to me. Perhaps this thread should be moved there.
Old Jun 28, 2011 | 07:53 AM
brocw1093's Avatar
brocw1093
Thanks
Danny
(205)588-0960
AIM: AssaultechDan
www.assaultech.com
Like Us on Facebook
Thank you! I have a heavy duty clutch, larger radiator And gauges. My vortech kit came with a 255 fuel pump if this is the one your talking about? Also with the 600cc will I need different fuel rails or are mine good?
Old Jun 28, 2011 | 08:16 AM
Dan@Assaultech
Stock rails will work. A nice RFS would be a good upgrade but not needed at 400whp.
Old Jun 28, 2011 | 09:26 AM
str8dum1's Avatar
str8dum1
all you need is 600cc injectors a smaller pulley (go right to the 2.87) and retune.
I was making close to 500 on my vortech on the stock block with that basic stuff.
Old Jun 28, 2011 | 10:18 AM
Dan@Assaultech
500whp? What kind of dyno? Mustang?
Old Jun 28, 2011 | 12:52 PM
str8dum1's Avatar
str8dum1
460DD, 500DJ
PharmD with a T-trim did 500+ on a DD
Old Jun 28, 2011 | 01:01 PM
Ruthless18x's Avatar
Ruthless18x
You had the older V3 blower right? Not the newer SCi?
Old Jun 28, 2011 | 01:55 PM
str8dum1's Avatar
str8dum1
V3 with SI trim impeller. not sure how different that is from the new SCi
Old Jun 28, 2011 | 06:54 PM
brocw1093's Avatar
brocw1093
So don't use the 3.12 pulley? I heard it's safer and can still achieve 400whp
Old Jun 29, 2011 | 03:10 AM
tonyzS/C03's Avatar
tonyzS/C03
it can be done, I made 368whp on the 3.12 pulley with the old V2 S/C and 440cc injectors, but i wish that i would have gone right to the 2.87 pulley and 600cc injectors
Old Jul 11, 2011 | 07:18 PM
show2nite's Avatar
show2nite
Default mmm
hard)
Dan what do you mean by "have to run to hard" when using DW 440cc?
Old Jul 11, 2011 | 07:22 PM
str8dum1's Avatar
str8dum1
means running an injector duty cycle>>90%. you dont wanna run over 80% or so for reliability. You want the biggest injectors your EMS can steadily control.
If I was to do my vortech setup all over again, I would go straight to the DW800 cc injectors no doubt. But then again I was maximizing my old V3 with ~500whp.
Old Jul 12, 2011 | 10:53 AM
show2nite's Avatar
show2nite
Would 380WHP be alluding to running over 80% of the 440cc injector cycle? Also what are the tell-tale signs of reliability issues.
Old Jul 12, 2011 | 11:23 AM
str8dum1's Avatar
str8dum1
injectors that are constantly over run with high IDC's will eventually freeze and fail. You'll know when that happens cuz your car will run like crap.
350Z_Al
Oct 29, 2020 07:44 PM
Li1ag
Sep 28, 2015 02:07 PM
