Forged Performance: FP S1 Shortblock TT Results
Old Jul 19, 2011 | 07:23 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Man you guys are harsh lol
Let me know if you need axles (you will break one eventually) I have my DSS pros for sale and I live in Indiana too
Old Jul 19, 2011 | 08:50 AM
str8dum1's Avatar
str8dum1
Originally Posted by CFZ
Thanks for the complements guys.
str8dum1, I checked my Haltech logs from the dyno session and boost curve is pretty simalar from 1 pull to the next +- 75 rpm. I will do some logs on the street and see what those look like. What does it mean if the boost curves are not similar ?
Thanks for the help
ya if you do 3-4 full pulls back to back and the boost logs look the same as the boost curve on the dyno, it could be a boost leak like has been suggested. but double check those logs by doing 3-4 full pulls.
Originally Posted by midz350
The GTM stage 2 turbo kit comes with GT2860rs .86 AR turbos.
You wanna bet money on that?
Its Garrett GT28RS (aka GT2860RS) Ball Bearing Turbo aka Disco Potato.
LOL! GTM has 2 stage 2 setups. So mid, unless you paid for this guys kit and has his invoice in your hands, i dont think you would wanna bet him any money.
http://www.gtmotorsports.com/product...cat=319&page=1
Old Jul 19, 2011 | 09:31 AM
CFZ's Avatar
CFZ
Yeah pretty much sure they are the gt2871. That's what I ordered and also checked the part # on the Garrett boxes to Garrett's web site.
Definitely going to do a leak down check just so I know.
A boost leak is very possible as the tubing in the GTM kit is not necessarily round at each end.
Yes you guys are kind of harsh but its ok I'm just trying to figure out if there is something wrong with my setup or if it just sucks?
Blackbird, may take you up on those axles once I get some time on the car and some of the other issues worked out.
Old Jul 19, 2011 | 10:04 AM
midz350's Avatar
midz350
Check this:
And this:
So, GTM only offers the GT2871's in the DE TUNER kit!!! but not in the DE TURN KEY kit!!!
Sorry CFZ for that
Old Jul 19, 2011 | 10:11 AM
XKR's Avatar
XKR
Check this:
And this:
Sorry CFZ for that
Okkkk.....so who is going to pay me
Old Jul 19, 2011 | 10:21 AM
str8dum1's Avatar
str8dum1
nightcrawler has the 2860s and they seems very laggy as well https://my350z.com/forum/forced-indu...-build-tt.html
Your powerband is right shifted by like 1000 rpms. Once that gets sorted, you're trq will be greatly improved.
Old Jul 19, 2011 | 01:55 PM
Blackbird CPV35
What part of Indiana are you from
Old Jul 19, 2011 | 03:03 PM
CFZ's Avatar
CFZ
In Evansville, southwest Indiana
Old Jul 20, 2011 | 08:43 AM
mx594's Avatar
mx594
FWIW I see about 8 psi on my HKS GTRS turbos (equivalent to a GT2871R if I recall, someone correct me if I am wrong) at about 4k RPM on a stock block VQ with a plenum spacer and ambient temps around 75 degrees.
The lower compression and I assume hot weather definitely dont help.
Old Jul 28, 2011 | 10:33 PM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
i would check the cam timing. something def. not right. setting up timing on vq's aint rocket science but there is a right way to time the motor correctly. you can check the timing on cipher by logging the intake cam advance from b1 and b2. if the numbers are not + or - .5 degrees with each other then you have a problem.
Old Jul 29, 2011 | 02:42 AM
derekinthez's Avatar
derekinthez
Originally Posted by Alberto
Lots of money on parts for not a lot of power.
agreed . . .
Old Aug 2, 2011 | 09:21 PM
rh_334's Avatar
rh_334
Lots of money for not a lot of power.
That should be Forged's slogan...
Old Aug 3, 2011 | 04:49 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Old Aug 3, 2011 | 05:15 AM
Cass007's Avatar
Cass007
Careful... unless you are speaking from first hand experience, don't start any drama.
I know you are affiliated with another shop from that area of the country.
Old Aug 4, 2011 | 05:55 AM
str8dum1's Avatar
str8dum1
huh? forged didnt build the car or suggest the parts. and it was a break-in tune.
go back under your bridge troll
Old Aug 8, 2011 | 02:33 AM
Resmarted's Avatar
Resmarted
but its still a new motor.
edit: where are updates (post break-in)
Sharif@Forged
Aug 14, 2007 05:46 AM
dmoffitt
Mar 10, 2006 07:14 AM
Superfly84zx
Mar 31, 2004 06:37 AM
TXSTYLE
Nov 20, 2003 02:14 PM
