Mazworx | Anatomy of a 4.1L 1200+whp VQ Engine Build
Old Aug 17, 2011 | 01:37 PM
  #41
mazworxracing's Avatar
mazworxracing
Vendor - Former Vendor
Finally got some time to work on the engine block. The shop's been super busy and hectic plus expanded with more room now, but here are some work on the block.
Stock crank on the left, billet stroker crank on the right
After sleeve install, the block is then step decked. This helps concentrate the clamping force around the cylinders.
Boring the Darton Sleeves to 100mm.
Notching the bottom of the Darton Sleeve for oil squirter clearance
Oil squirter notched.
Machining 2 of the 4 main stud for 1/2" studs
More to come.....
Old Aug 18, 2011 | 06:31 AM
  #42
str8dum1's Avatar
str8dum1
are you gonna fill the block since its a race car?
Old Aug 18, 2011 | 07:20 AM
  #43
binder's Avatar
binder
no torque plate during the bore?
and 1/2" main studs?! that's insane
Old Aug 18, 2011 | 08:38 AM
  #44
Mazworx's Avatar
Mazworx
We will still run water in it. It's going to run on gasoline.
Old Aug 18, 2011 | 08:39 AM
  #45
Mazworx's Avatar
Mazworx
Torque plates are used during the honing process.
Old Aug 18, 2011 | 12:36 PM
  #46
GreenGoblin's Avatar
GreenGoblin
Thank you for the update Mark.
Old Aug 18, 2011 | 03:50 PM
  #47
binder's Avatar
binder
interesting. Never knew that. Any time i've sent a block to be bored they just ask if i want it bored with a torque plate and i always say yes. They never specified that it was a bore then hone with torque plate.
Old Aug 18, 2011 | 07:59 PM
  #48
Christian824's Avatar
Christian824
sub
Old Aug 19, 2011 | 03:18 AM
  #49
Resmarted's Avatar
Resmarted
you use a torque plate after bore, and during the hone.
looks dope, esp that crank. the oem crank is BEEFY. It weighs more than the block!
edit saw people already addressed @binder
The blades used for boring are different than the honing head.
The idea is to egg the hone job... the bores straighten out when under the torque of the head, and this egging is very small. You could do the torque plate on the block during boring but it would make little difference (until the honing stage). Shops will do the torque plate during the bore if you want, but they charge extra because its "more of a hassle" and not really worth the effort.
Old Aug 19, 2011 | 04:14 PM
  #50
binder's Avatar
binder
ya, after reading that checking the bore with and without the plate there was only about 1 thousandth of a difference then it makes sense to use it with the hone as 1 thousandth could easily be taken out with a hone. I guess since i never plan on doing any machining i just never asked. I just build the engines for the racers. I leave the machining to the professions.
Old Aug 20, 2011 | 07:13 AM
  #51
Cass007's Avatar
Cass007
Enough already... bicker in PMs or pollute your own threads. Fair warning to all has been given.
Old Aug 23, 2011 | 11:45 PM
  #52
midz350's Avatar
midz350
Update?
Also this version is cracking me up:
http://www.myg37.com/forums/3188977-post28.html
http://www.myg37.com/forums/3190074-post30.html
http://www.myg37.com/forums/3190240-post31.html
http://www.myg37.com/forums/3192058-post36.html
http://www.myg37.com/forums/3202513-post41.html
http://www.myg37.com/forums/3203899-post43.html
Old Aug 24, 2011 | 03:17 AM
  #53
abushong504's Avatar
abushong504
wow! they are retarded. Have they been living under a rock. The best is the all motor one lol
Old Aug 24, 2011 | 03:47 AM
  #54
tonyzS/C03's Avatar
tonyzS/C03
^+1 had to stop drinking my Monster as to not short out my computer at the all motor comment... This thread is full of EPIC WIN this thing is going to be a monster, i've very interested in what the results are going to be. keep up the awesome work guys, love to see this kind of work still happening.
Old Aug 24, 2011 | 09:20 AM
  #55
derekinthez's Avatar
derekinthez
i'll check you guys out soon!
Old Aug 27, 2011 | 05:30 AM
  #56
Mkriebs's Avatar
Mkriebs
Very nice work Mazworx. I am pretty interested in the Z with the same setup. Been considering modifying a kit to work much like that with the turbo right in the front of the engine...
Old Aug 30, 2011 | 11:14 AM
  #57
archangel0585's Avatar
archangel0585
I look forward to seeing the finished video, and seeing how you manage the heat. (heat being the opening of the season and the first set of races)
Old Aug 30, 2011 | 12:16 PM
  #58
str8dum1's Avatar
str8dum1
its a drag car, there isnt much need to manage heat. its got a 1/2 sized radiator
Old Sep 7, 2011 | 08:47 PM
  #59
meatbag's Avatar
meatbag
Bump for updates and cleaning the retard comments out.
Old Sep 8, 2011 | 11:05 AM
  #60
Mazworx's Avatar
Mazworx
We will start assembly tomorrow. Plan is to have it up on the engine dyno by the end of the month. More pics next week.
