Vortech running lean. help please
Old Aug 21, 2011 | 03:48 PM
binder's Avatar
binder
Originally Posted by rx7/350z
Thanks but my friend had a new fmu that came with his kit he never used
there's a reason why he didn't use it
but i guess use it until you can upgrade. I will say that i was using the 2.87 pulley with DW 440 injectors, walbro, and CJM stage 0 return kit with no fueling issues at all if you needed advice on a cheap way to upgrade.
I actually still have the rear-rail adapter for that return kit. I can cut you a deal on it then all you would need is a 6an stainless line for the return, the correction kit, and a FPR and you will be in business.
Old Aug 21, 2011 | 07:59 PM
rx7/350z's Avatar
rx7/350z
He used an in tank fmu. Im happy with my car, I don't think I'll ever move to the 2.87.
I took the fmu apart and it looks like it failed due to water getting into the vent on top. There was a lot of rust in the center section that is open to atmosphere
Old Aug 22, 2011 | 12:44 AM
ESP350Z's Avatar
ESP350Z
Did your original fmu have a hose coming off the vent and curved downward?
Old Aug 22, 2011 | 02:26 AM
rx7/350z's Avatar
rx7/350z
yes, it wasnt there
Old Aug 22, 2011 | 02:30 AM
ESP350Z's Avatar
ESP350Z
Sounds like whatever happened, you are good to go with that new fmu. Ita nice to hear of a sc setup out of the box that has run like a champ for as long as yours has.
Old Aug 22, 2011 | 05:03 AM
Kwame's Avatar
Kwame
Good to hear your car is back on the up-and-up chump.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
