Smoking like crazy on deceleration
Old Oct 4, 2011 | 06:26 PM
Fluid1's Avatar
Fluid1
Default Smoking like crazy on deceleration
The car's smoking like a chimney when in gear, but foot off the gas, decelerating. If I take it out of gear or push the clutch in, no smoke. No smoke in any other condition but as described. Oil is being burned at a large rate when I don't intentionally drive without ever letting the car decelerate in any gear....
TIA
built and tt'd
Old Oct 4, 2011 | 06:52 PM
djamps's Avatar
djamps
Install a new PCV valve along with a catch can.
Old Oct 4, 2011 | 06:57 PM
SH Luciano's Avatar
SH Luciano
what twin turbo kit?
Old Oct 4, 2011 | 06:59 PM
Fluid1's Avatar
Fluid1
I have a catch can. It's pretty empty. The PCV would be causing the extreme oil burn?
I still have normal power but I have been staying out of boost.
Custom TT kit based on greddy
Old Oct 4, 2011 | 07:16 PM
SH Luciano's Avatar
SH Luciano
not sure if this applies to you with a custom kit, but make sure your oil drain lines aren't kinked or otherwise somehow preventing oil from flowing back to the oil pan. that could be causing some smoking on decel for you.
Old Oct 4, 2011 | 07:21 PM
Fluid1's Avatar
Fluid1
Will do, thanks.
Old Oct 4, 2011 | 08:18 PM
mx594's Avatar
mx594
Where is your PCV tied into the intake system? Before or after the turbo? I plumbed mine into the charge pipe just before the throttle body one time - bad idea. Smoked like crazy. Its now on the intake of one of the turbos and it is much better!
Old Oct 4, 2011 | 08:22 PM
sk26dett's Avatar
sk26dett
How's the car running? My car was doing that too once and it turned out to be cracked ring lands on 2 pistons, but that was a different car and motor. Any other symptoms or abnormal things happening?
Old Oct 5, 2011 | 02:05 AM
djamps's Avatar
djamps
As others mentioned it could also be your turbo seals and/or a blocked or uphill path on an oil return from your turbos. I've seen this happen on grossly overfilled oil once, but it also ended up in blown turbo seals.
Old Oct 5, 2011 | 06:46 AM
thom000001's Avatar
thom000001
like said already, start with making sure oil is draining out of turbos and verify you catch can setup is plumbed properly.
Tom
Old Oct 5, 2011 | 02:32 PM
Fluid1's Avatar
Fluid1
Before I address this quote, I want to say I have never overfilled with oil (another comment)
The car is running great, no issues other than the normal slight blips in power because I'm running way more power than my engine management is really built for.
Car runs 100% like normal except when I'm in gear, off the throttle. I so much as push the clutch in or take it out of gear, or accelerate...no smoke.
Thanks to all so far
Fluid1's Avatar
Fluid1
Tom
Check and check.
Car's going into the shop for a complete tear apart and rebuild this Saturday.
Chris350z03
Oct 8, 2023 07:19 PM
Juztin
Nov 22, 2015 07:03 AM
Depravity
Oct 1, 2015 04:49 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
