844whp@26.5psi
Old Oct 25, 2011 | 07:00 AM
  #121
binder's Avatar
binder
Originally Posted by meatbag
The cam timing adjustments help smooth out the boost curve as well.
any thoughts on sharing your ninja cam timing adjustments?
I haven't even started on cam timing yet. Still running it stock but i know it will probably help out.
also, are you going to update your timing thread with what you decided on using with this car on pump and on race?
Old Oct 25, 2011 | 10:09 AM
  #122
meatbag's Avatar
meatbag
I forgot about that timing thread. I stopped looking in at it when everyone cried that they should just go to a shop and not share any relavent information.
I left my damn osiris cable at home in the G35 so I will post the cam phasing maps tonight when i get home.
I kept the exhaust cams at 17deg and the intake cams at 30deg from 3000-5500 and then ramp down to 0deg by 7500rpm. This doesnt sounds like the ideal cam timing but its what provided the best compromise between midrange power and top end.
Old Oct 25, 2011 | 05:11 PM
  #123
str8dum1's Avatar
str8dum1
thanks for the info.
do you ramp into the 30*? i start my ramp ~1200, then full advance by 2500 to 5000 then ramp down to 0 by 7500.
none of my cam map is dyno tested though. didnt have any time.
YOu dont get this kinda cam jitter do you? My drivers side cam seems really jumpy. Thats the side that had my IVT solenoid wires all buggered up from when my vortech cog belt snapped.
The cam is still doing what its supposed to but just noisy.
Old Oct 25, 2011 | 06:46 PM
  #124
meatbag's Avatar
meatbag
Ah lucky bastard you get to do with proefi, im stuck with osiris so the logging isnt going to be pretty. I have mine set pretty much just like yours except with the exhaust cams advanced as well. I lost almost all my midrange when I zeroed the exhaust side out.
My DSS pro axles will be here this week so hopefully I can get it on the dyno to get the logs on the cams.
Im more worried about the exhaust cams being the problem since its electro-clutch based. Might just have to take them out for some cam gears if thats where i see the fluttering.
Old Oct 28, 2011 | 06:20 PM
  #125
meatbag's Avatar
meatbag
Pro axles came in and are on the car. One of my wheels is bent though and vibrating like mad so im on the hunt for a new set of 15x10 for my drag radials. Will have the car on the dyno tomorrow to try and clean up the curve some more.
Old Apr 7, 2012 | 06:57 PM
  #126
meatbag's Avatar
meatbag
Been busy over the past couple months with other projects but the axles are in. Looks like car will be headed in a different direction though and become a Texas Mile car.
Old Apr 7, 2012 | 07:10 PM
  #127
Classy's Avatar
Classy
Think you could hit the 200 mile club?
Old Apr 7, 2012 | 08:45 PM
  #128
Flo-ridaZ33's Avatar
Flo-ridaZ33
Your set up looks insane... just scary.
Old Apr 7, 2012 | 09:12 PM
  #129
graffkid732's Avatar
graffkid732
That looks like madness. Can not wait to see this.
Old Apr 8, 2012 | 06:08 PM
  #130
SH Luciano's Avatar
SH Luciano
i'd be inclined to think he'd get pretty close as the car sits with the greddy kit that's on it now.
Old Apr 8, 2012 | 07:39 PM
  #131
ace32x's Avatar
ace32x
im sure he easily could have, i did 195 with my 2871's and 670 whp/699 tq
Old Apr 9, 2012 | 08:49 AM
  #132
phunk's Avatar
phunk
CJ Motorsports
ahhh now i will be jealous... this is what i originally wanted to do with my 350z when I had the precision billet 62/65s hanging on it with a set of SFR long tube manifolds.
cant wait to see the finished job
Old Apr 9, 2012 | 09:00 AM
  #133
meatbag's Avatar
meatbag
We are building some some manifolds for precision 5858's right now that will keep them tucked next to the block but those 7168's will end up below the headlights on my car.
Old Apr 9, 2012 | 09:21 AM
  #134
phunk's Avatar
phunk
CJ Motorsports
Nice... we have a schedule 10 304L manifold for the passenger side, all tubular style with a billet collector... we havent had time to do the drivers side yet. We jigged it up as a bolt in replacement for Greddy manifolds but I havent tried to see if we could fit something larger up there if we changed out the flange.
Old Apr 9, 2012 | 10:45 AM
  #135
str8dum1's Avatar
str8dum1
twin 7168 is pretty nuts, even for me they are making 1000whp on just 1 of those on supras.
For a mile car, probably an appropriate choice though.
Old Apr 9, 2012 | 11:01 AM
  #136
phreaktor's Avatar
phreaktor
Design Engineer
Damn I want to feel what even half of that feels like. Anyone need a kidney?
Old Apr 9, 2012 | 01:26 PM
  #137
meatbag's Avatar
meatbag
I had to move the passenger side water pipe and some other stuff to make the 5858's work and keep the true 3" intake.
Old Apr 9, 2012 | 03:19 PM
  #138
GreenGoblin's Avatar
GreenGoblin
Thanks for the update, where did you move the water pipe, a hr style?
Old Apr 9, 2012 | 04:45 PM
  #139
str8dum1's Avatar
str8dum1
blah, i still have 3" intakes and didnt move any of that..
do you need to use a sump pump though?
Old Apr 9, 2012 | 05:19 PM
  #140
meatbag's Avatar
meatbag
They are in the same location as the greddy turbos so nope
