Vortech S/C Belt Snapped - HELP!
Old Nov 20, 2011 | 01:50 AM
wizard's Avatar
wizard
Default Vortech S/C Belt Snapped - HELP!
On the way home last night, pushed the car a little and the s/c drive belt snapped. Took out the alternator and the power steering pump with it.
Had to get the car recovered, a long ordeal.... but it's safe at a local garage now.
I'm not sure the exact cause of this, but as the belt doesn't seem to be catching on anything, I can only assume the belt was too tight... This is the second belt the vortech has chewed through in under 5k miles (both belts came with the kit, size not stated on belt).
Can someone just confirm that the correct belt for a 3:13 pulley should be:
GATES K060930
I can't find a dealer in the UK for GATES belts so will have to get an equivalent brand (Micro-v XF), but if that is the correct size then I should be able to get something similar.
Old Nov 20, 2011 | 05:00 AM
wizard's Avatar
wizard
Slight mistake on the last post, there is a part number on the belt.
I have not measured the belt yet (snapped off makes it a little difficult), but the part number is attached in one of the pics. Appears to be a NAPA belt 25-060785.
Attached Thumbnails Vortech S/C Belt Snapped - HELP!-grooved-idler.jpg   Vortech S/C Belt Snapped - HELP!-power-steering-pulley.jpg   Vortech S/C Belt Snapped - HELP!-pulley-pics.jpg   Vortech S/C Belt Snapped - HELP!-shredded-belt.jpg
Old Nov 20, 2011 | 05:59 AM
jpc350's Avatar
jpc350
My notes indicate the K 060930 fits the 3.12 pulley, however it might also fit the 3.33 with some additional tightening..
Old Nov 20, 2011 | 07:51 AM
wizard's Avatar
wizard
I just measured the belt that was on there below. It is 1990mm. The K060930 appears to be 2363mm. Surely that can't be right? Unless some of the length has chewed off in the process? Is this likely?
Old Nov 20, 2011 | 02:02 PM
str8dum1's Avatar
str8dum1
thats a 78.5" belt, hence the 785 as the last 3 digits. 78.5 inches = 1994mm
Old Nov 20, 2011 | 02:15 PM
tonyzS/C03's Avatar
tonyzS/C03
I have any extra belt in my garage from my 3.33 pully set up. i'll look at it tomorrow and see how long it is, pretty sure its 78.5 in...
Old Nov 20, 2011 | 03:14 PM
05Z33's Avatar
05Z33
FWIW I was using the 060795 with the 2.87 pulley and now I'm using the 060790. The 060785 might be to tight for your setup.
Old Nov 20, 2011 | 07:13 PM
350Z400rwhp's Avatar
350Z400rwhp
If you break your belt again in the future, you can still drive a good 20 or so miles without the alternator.
Old Nov 20, 2011 | 11:47 PM
350z006's Avatar
350z006
Really? Sorry OT but you can drive the Z without a belt for a little bit, and the only issue is the battery?
Old Nov 21, 2011 | 01:47 AM
wizard's Avatar
wizard
Think I'm going to go for 060795 belt and see how I get on.
I will report back when the belt has been fitted, etc...
Old Nov 23, 2011 | 02:16 AM
wizard's Avatar
wizard
Guys,
Just as an FYI, the tensioner was fully tightened on the 060795 belt but it's still too loose for a 3.125 pulley.
Have decided to go down to 2005mm belt. Just so you lot are aware! This should do the trick!
Cheers.
Old Nov 23, 2011 | 08:22 AM
350Z400rwhp
Yes you won't have power steering or an alternator. The water pump is chain driven.
Old Nov 23, 2011 | 11:06 AM
- bigc -'s Avatar
- bigc -
Its moot now, but its always a good idea to keep a spare serpentine belt in the car (or at least your old stock belt).
OP, hope you get up and running soon!
Old Nov 24, 2011 | 03:06 AM
wizard's Avatar
wizard
But I'm not sure what I'd do even if I did have a belt? How would I possibly be able to install it at the side of the road?
Old Nov 24, 2011 | 09:25 AM
str8dum1's Avatar
str8dum1
i always kept a 10mm, 12mm socket, 14mm open end wrench, my spare tire jack and a spare serp belt with me. Thats all you need to to do a belt swap on the side of the road.
I keep alot more tools and parts with my me now with my turbo setup. Most importantly, a fire extinguisher
Old Nov 24, 2011 | 09:50 AM
- bigc -'s Avatar
- bigc -
i'm the same way. i use the owners manual bag to hold a bunch of tools and misc nuts/bolts.
a good idea is to cut a hole in your undertray directly below the belt tensioners to make it easy to change/tighten a belt on the fly.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
