Another Bp single turbo kit!
Old Jun 12, 2012 | 04:02 AM
  #121
lowandsteezy's Avatar
lowandsteezy
People love me! Borrowing a friends car and someone breaks into it and my girlfriends car and steals the cd players!
Old Jun 12, 2012 | 05:26 AM
  #122
Johnnyone's Avatar
Johnnyone
ah so thats what they stole. didnt think ppl broke into ppls car anymore. sorry to hear man.
Old Jun 12, 2012 | 06:13 AM
  #123
ibelonginprison's Avatar
ibelonginprison
It comes in threes.
1. blown motor
2. friends car broken into
3. girlfriends car broken into
That's three. You're safe now.
Sorry to hear about your luck man.
Old Jun 12, 2012 | 11:42 AM
  #124
Eno's Avatar
Eno
holy crap...
Old Jun 12, 2012 | 02:13 PM
  #125
lowandsteezy
Just found a puddle of oil and metal chunks in the upper intake plenum
Old Jun 12, 2012 | 04:24 PM
  #126
F2CMaDMaXX's Avatar
F2CMaDMaXX
Up there!?
Er, anything identifiable? perhaps the pcv valve innards?
Old Jun 12, 2012 | 05:00 PM
  #127
lowandsteezy
I'll post a picture of my oil pan
Old Jun 13, 2012 | 06:46 AM
  #128
ibelonginprison
Wow. Damn son, talking about going all out. You went ALL OUT.
It sucks right now, so just make it through this. It gets better when you realize the possibilities that are open to you now.
But a year from now when some n00b says "I blew my motor, it's smoking out the left tailpipe." You can post up pics of your plenum and say "did you blow bits of piston ring to the farthest corners of every part of your motor? No? Then stfu." Everyone will see the pics and cringe... kinda like one of those "best battle scar stories at the bar" type thing where a guy shows up that only has one leg, and he lost it saving a handicapped child and puppy from a burning building. You win, every time.
Old Jun 13, 2012 | 06:56 AM
  #129
str8dum1's Avatar
str8dum1
hopefullly that metal isnt in your oil pan. if so, your turbo and entire motor is wiped.
Old Jun 13, 2012 | 07:05 AM
  #130
mgrotel's Avatar
mgrotel
pics? sorry to hear man, i still say get a dd
Old Jun 13, 2012 | 07:21 AM
  #131
lowandsteezy
I will have pictures soon. I hope the turbo is still good. But there's thousands of pieces of metal in the oil pan. A snap ring, pieces or ring. It's bad. So I'm getting a factory motor or lsx swap.
Old Jun 13, 2012 | 07:22 AM
  #132
mgrotel's Avatar
mgrotel
LSX!!!!
Old Jun 13, 2012 | 07:32 AM
  #133
faiz23's Avatar
faiz23
FEZZZZZZ
LSX (Truck IRON motor block) unless you want another blown built motor.
Old Jun 13, 2012 | 07:39 AM
  #134
ibelonginprison
6.0 LQ9. Only a little bit heavier, definitely cheaper, and.... when you decide you want boost again, that iron block will hold all the ***** you can throw at it! lol
Here's a friend of mine that's local that dropped one in his Sedan.
http://g35driver.com/forums/g35-seda...-lsx-swap.html
It's torn back down now for a turbo.
http://www.youtube.com/watch?feature...6AAumjG8#at=20
Don't be fooled though. These things are still quirky. He's had plenty of "troubleshooting" along the way.
Old Jun 13, 2012 | 08:00 AM
  #135
ace32x's Avatar
ace32x
l9h with a whipple and ls9 cam/valve springs ;D.
Old Jun 13, 2012 | 08:58 AM
  #136
mgrotel's Avatar
mgrotel
i would do the LQ9 if you plan to stay NA, but if you plan to boost do the LQ4
LQ9 comes with high compression, the LQ4 has lower compression better suited for boost
Old Jun 13, 2012 | 09:13 AM
  #137
ace32x's Avatar
ace32x
any stock block build would be good for most people on here. people push 600+ on the lq9's. and if you bump up to the l9h out of the newer ones those are holding 700. and can make them with a simple blower at like 10-12lbs
(been researching it thoroughly i recently picked up a new silverado with the l9h in it and ive been wanting to swap the cam and springs out and throw a blower on it and have a sleeper ;D)
Old Jun 13, 2012 | 09:54 AM
  #138
str8dum1's Avatar
str8dum1
turbo will be wiped as well. that metal is in everything that needed oil. AS long as its was a journal bearing, it is cheap to rebuild.
A LS swap will cost you around 10k as well and it definitely not straight forward yet.
Old Jun 13, 2012 | 04:37 PM
  #139
binder's Avatar
binder
+1
people are suggesting something that veteran builders have yet to perfect to a guy that said he won't even swap out his stock block for another stock block (direct replacement). I guess people don't listen.
I'd rather have a boosted stock block than screw with all the trouble members are having with doing the swaps. Every single thread with a "swap kit" has turned out to be a nightmare for the person and they spent months of work trying to get it working properly. So far it seems only a few people that are shop owners or have a fabrication shop access have full working lsx swaps.
Old Jun 13, 2012 | 06:30 PM
  #140
lowandsteezy
I'm buying a daily tomorrow or Friday. Sold my wheels. I know a lsx swap isn't cheap nor easy. But I have know where near enough to build a vq and keep the turbo kit. I'm not gonna just put another turbo kit on stock block. Nor do I want to just keep a stock motor in it and look at my turbo kit in the room. I'm thinking I can take my time on a lsx swap and get done within a month or so and have a daily a lsx 350z
