opinions on compression
Old Jul 1, 2012 | 07:08 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
I am not trying to start anything here by asking. The hr is still "new" to many shops and the shops may still be trying to figure out the right formula.
Old Jul 2, 2012 | 05:04 AM
Frosty87's Avatar
Frosty87
It was a local shop had about 3k miles on it ....but as I stated before it was an oil issue not a build issue ....castrol gtx 10w40 completely broke down to an almost water consistency .the oil only had 300 miles on it as I change oil every 1200-1500 miles .
Old Jul 2, 2012 | 05:35 AM
rcdash's Avatar
rcdash
300 miles? Doesn't matter what oil - just not likely unless you superheated it. I believe the Castrol european formula has had very good UOA feedback.
EDIT: looks like some versions of Castrol are not so good (ref BITHOG). Nevertheless blaming oil in 300 miles, unless engine abused during that period (over heating) seems unlikely.
Old Jul 2, 2012 | 05:42 AM
Frosty87's Avatar
Frosty87
Yes the German gtx is great from what I heard ... It was extremely hot I was at a local drag event where they changed the setup from multiple staging lanes to an almost hot Lap setup 2 runs and there the knock was ..all oil pressure and temp gauges were normal. 95 degree day in an open field no breeze
So for the rebuild big oil cooler and misimoto rad
Old Jul 2, 2012 | 06:30 AM
binder's Avatar
binder
looking at those dynos you have AMAZING low end. 2500 rpms you have 300tq and ~4000 rpms you are 400tq. That's awesome low end into a very strong midrange. I wouldn't change anything on that setup unless it was to add some octane in order to up the boost for higher power levels. That doesn't always relate directly into faster car though so I'm not sure I would mess with it.
If you are running back to back in high heat the meth/h20 injections would add some safety octane and provide a great amount of knock protection due to lowering the combustion temps.
As for cams, i have nothing to add. I do know for the most part aftermarket cams will push your power curve to the right so make sure you talk to a few manufacturers and tell them you are looking to gain more power down low if that's your goal so you can get the best set. If you are launching at 3500rpms and probably not falling below 5500 when you shift I would be more concerned with what's up in the higher rpm range so you can maintain that nice torque curve up in the high rpms where you will be racing. So, for racing, cams would be a great idea.
Old Jul 2, 2012 | 09:32 AM
ace32x's Avatar
ace32x
Originally Posted by Frosty87
thanks for the input guys I've decided to stay with the cp pistons.....looking to cams now instead of the compression. On that note is anyone using the jwt c1 cams for the hr.
stock cams
Lift:
Intake/Exhaust : 10.5mm/10.5mm
Duration:
Intake/Exhaust: 248/248
Intake Open: 2º BTDC
Intake Close: 66º ABDC
Exhaust Open: 68º BBDC
Exhaust Close: 0º BTDC
Overlap: 2º
jwt
http://jimwolftechnology.com/custome...asp?PartID=489
i have cams in my built hr, called them and went over sizing for awhile. they thought the 262's would fit best with a built HR with twins. the cams made a great difference top end aswell. noticed a huge flow difference over 600whp
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
B Esquire
Sep 24, 2015 07:52 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
