I've got a build or something *PICS*
Old Jul 23, 2012 | 10:42 AM
  #101
konrad's Avatar
konrad
Cam you post up the detailed pictures of the pump. maybe someone can make a separate thread just oil pump diacussion and move the related posts from here over to make it easier to find
Old Jul 23, 2012 | 12:24 PM
  #102
binder's Avatar
binder
Originally Posted by jerryd87
also never saw this before but
http://www.importperformanceparts.ne...mpsnissan.html
if i would have known about those i would have gotten that in a heartbeat vs the revup me loves high volume pumps.
anyone run this pump? seems almost too good to be true. For 179$ it's pretty cheap though!
Old Jul 23, 2012 | 12:57 PM
  #103
Resmarted's Avatar
Resmarted
Originally Posted by t6378tp1
rb are rated higher cause they're inline vs v which by design is smoother since all the cylinders are firing in the same direction
Exactly my point, rb harmonics>vq harmonics
Thanks for clearing that up meatbag
Old Jul 23, 2012 | 02:25 PM
  #104
konrad's Avatar
konrad
I'll get it and compare it to the revup my engine is still in peaces. If it looks better then revup I'll use it
Old Jul 23, 2012 | 04:29 PM
  #105
binder's Avatar
binder
Sweet. It sounds better than the rev-up. I'm currently using the rev-up but I don't feel like tearing apart the engine to change the oil pump unless it's going to be a big difference.
Old Jul 23, 2012 | 05:30 PM
  #106
Resmarted's Avatar
Resmarted
I'll be honest, looks like it's not going to be any improvement.
In general if it's too good to be true, then it is.
Probably is like a re-branded rev up pump (for that price).
Old Jul 23, 2012 | 07:03 PM
  #107
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Thumbs up
Cool! Please post up your findings with pics!
Old Jul 23, 2012 | 07:56 PM
  #108
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Ahhh... here's the most valuable post from that g35driver thread that jerryd87 posted earlier. The HR pump won't bolt up to a DE block. But he was able to swap the stronger dual pressure relief springs of the HR into the DE pump.
http://g35driver.com/forums/6496154-post7.html
That still doesn't address the aeration problem though.
Old Jul 23, 2012 | 08:49 PM
  #109
jerryd87's Avatar
jerryd87
err yah my bad thought i linked that, but he does mention that its just a little bit off and could rather easily be modified to fit. he called it "ghetto rigging" but i guess he would also consider swapping a 400 small block crank into a 350 for a 383 also ghetto rigging(talking about the first people to make it work not the easy turn key kits available now.)
as far as the pump i wouldnt really say so, that saying may old true in many instances but look at the pumps for small block chevys, a melling high pressure high volume is the same price as stock and vastly out performs it. so you can get better performance for the same price.
Old Jul 23, 2012 | 09:38 PM
  #110
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Looks like the TOGA HV oil pump is too good to be true. Follow the links to the other forums in that thread too.
http://board.tercelonline.com/viewthread.php?tid=44626
Old Jul 24, 2012 | 01:23 PM
  #111
2bad240's Avatar
2bad240
pretty sure imma steal this turbo setup with my long tubes and y pipe. but il probably try a comp oil-less turbo.
Old Jul 24, 2012 | 07:51 PM
  #112
Resmarted's Avatar
Resmarted
Good luck. This wasn't as easy as it looks.
Not sure about the oil less turbos yet. If you run a smaller turbo that needs smaller dp and charge-piping it shouldn't be too bad.
Old Jul 25, 2012 | 09:36 AM
  #113
str8dum1's Avatar
str8dum1
2bad240 if you want to make it easy, just make it a rear mount. Just buy your favorite 2.5" single exhaust, cut off the muffler, weld on a t4 flange and you are 90% done.
You already have nitrous, so you could run a huge rear mount turbo and just spray til you hit like 10psi then let the turbo take over.
Old Jul 27, 2012 | 05:07 AM
  #114
Resmarted's Avatar
Resmarted
i really gotta bump this.
met a dude at a party who thinks his STOCK m6 is going to sh*t on my car
Can not wait for closed track race...
He's willing to put money on it too.
#****yeamother****er
Old Jul 27, 2012 | 06:24 AM
  #115
bigcloud's Avatar
bigcloud
Let me guess the guy wants to do a highway pull? How about ask him to go to a track day then see who the better driver is.
Old Jul 27, 2012 | 06:35 PM
  #116
t6378tp1's Avatar
t6378tp1
glad I could bring you up to speed
Old Jul 28, 2012 | 01:10 AM
  #117
Resmarted's Avatar
Resmarted
I'm building my car for high speed on track roll on races (lol)... That's kind of where my mind's been for the past couple of years. (Want to keep up or beat liter bikes)
We're both pretty young so I doubt he's got any actual experience. That being said, not sure I want to go to a track and loose because I'm laggy, don't have brakes and not experienced enough to keep the damn thing spooled. I'm going for around 1000 @ the crank... Not really an auto x car lol. Eventually though I'd like to setup the car with coils, a proper aero system, full cage, brakes etc.
Old Jul 28, 2012 | 01:48 AM
  #118
Resmarted's Avatar
Resmarted
oh i meant that was what i said earlier, and i was saying meatbag as in the user on here (with a batshit crazy g35) who confirmed the oil pump breaks because of harmonics
didn't mean to call you a meatbag!
Old Jul 28, 2012 | 09:14 AM
  #119
binder's Avatar
binder
m6 isn't all that fast. I stomped one with my low boost setting effortlessly. The new m6 RECORD for 1/4 mile is 11.87@120mph and that was with stage 3 tune, intake, full exhaust, and drag tires. Stock they do mid/upper 12's. Not bad stock time but they are 150hp more than a slightly modified LS camaro that can run mid 11's.
Old Jul 28, 2012 | 07:52 PM
  #120
Resmarted's Avatar
Resmarted
They're fine but I was pretty sure they were a mid 12 car with driver. They weigh like 3800lbs if I recall corectly and those v10's really don't have that much torque (380 ish? vs 500hp).
I like them because they're a v10 otherwise they're kinda ugly, really heavy (I assume they handle well based off of bmw's history), but the kid has no idea about cars. Doesn't even know what a turbo is. I opened up the convo with telling him to get an exhaust and then he started talking about how it doesn't need one because it will beat everything.
I have no idea where he got the money for one, as we're in college and I really doubt he has a legitimate source of income that could provide for that kind of vehicle, but I'm not going to jump to conclusions.
